GEM 1200 Problem
Old February 17th 04, 05:31 PM
Newps
Jim Kaufeld writes:
Anyway, the GEM has an intermittently flaky display. Sometimes it goes crazy
and the bar graphs and digital temp readouts start fluctuating wildly. It
isn't just one engine and it isn't just one cylinder. Its all of them.
I have the EI US8A. When this happened on mine the first time I assumed
it was a bad probe, so I replaced it. Then after about 10 hours it
started doing it again, so clearly it wasn't the probe. Turns out it
was the electrical connection that is midway between the probe and the
firewall. If you simply took the connections apart and reconnected them
the unit would work fine for a few hours then go back to the same
problem. Making sure the connectors have a good electrical contact
solved the problem. I have had my EGT/CHT for about 5 years now and
still have not had a probe go bad.
Old February 17th 04, 10:03 PM
Dennis O'Connor
The best method I have found with milliampere instruments connections is to
place a stainless star washer with twisted teeth, between the two stake-on
connectors and which actually cuts into the metal both sides of the
connection when the screw is tightened, breaking through any oxide layers...
denny
"Newps" wrote in message
Jim Kaufeld writes:
crazy
It
A problem in the Military ? Nick Jade Military Aviation 54 March 15th 04 08:59 PM
Fiberglass Cowl Problem Boelkowj Home Built 6 December 20th 03 03:08 PM
Garmin fixes moving waypoint problem -- almost Jon Woellhaf Instrument Flight Rules 6 November 28th 03 06:29 PM
EGT Problem Dennis O'Connor Owning 4 August 27th 03 05:25 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 01:35 AM
