I'm wondering just how bad or how much hassle the oily belly is. I
guess it's a matter of personal tolerance. Am I correct in assuming that cost is the only "real" factor in deciding not to get a wet pump? Even at that, I'm surprised that so few wet pumps are apparantly in use, especially considering the risks associated with the dry ones. It seems that the safety difference as described in the common literature would so far outweigh the cost factor that cost can't be the only reason explaing why the dry pump is so prevalent. |
I have wet pumps... I have air/oil separators consisting of a one quart
mason jar, on each engine... Oil on the belly is not a major problem.. I see that there is once again an stc separator available (AirWolfe) denny "smackey" wrote in message m... I'm wondering just how bad or how much hassle the oily belly is. I guess it's a matter of personal tolerance. Am I correct in assuming that cost is the only "real" factor in deciding not to get a wet pump? Even at that, I'm surprised that so few wet pumps are apparantly in use, especially considering the risks associated with the dry ones. It seems that the safety difference as described in the common literature would so far outweigh the cost factor that cost can't be the only reason explaing why the dry pump is so prevalent. |
I've gone through 4 different air/oil setups, and finally settled on the
AirWolf. It works perfectly, unlike the others I've tried. I believe that historically the dry pumps were introduced because they are cheaper, lighter, and cleaner. But experience shows they're certainly not safer! Rip "Dennis O'Connor" wrote in message ... I have wet pumps... I have air/oil separators consisting of a one quart mason jar, on each engine... Oil on the belly is not a major problem.. I see that there is once again an stc separator available (AirWolfe) denny "smackey" wrote in message m... I'm wondering just how bad or how much hassle the oily belly is. I guess it's a matter of personal tolerance. Am I correct in assuming that cost is the only "real" factor in deciding not to get a wet pump? Even at that, I'm surprised that so few wet pumps are apparantly in use, especially considering the risks associated with the dry ones. It seems that the safety difference as described in the common literature would so far outweigh the cost factor that cost can't be the only reason explaing why the dry pump is so prevalent. |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Windmilling Prop & Vacuum Pump | Matt Young | Instrument Flight Rules | 14 | October 14th 04 08:08 PM |
Tiny vacuum pump | Jim Weir | Home Built | 41 | January 24th 04 05:42 AM |
Tiny vacuum pump | Jim Weir | Owning | 32 | January 21st 04 03:44 AM |
Battery and Vacuum pump | PaulaJay1 | Owning | 3 | January 16th 04 04:22 PM |
