![]() Ben Jackson wrote: I hear that potentiometer-based fuel senders can be revitalized by soaking them in a solvent to remove accumulated gunk. I'm wondering if they can be sprayed in place by running the tank dry and using a tuner cleaner (I think it's mostly dichlorofluoroethane). Will that stuff destroy fuel bladders or sealent? Ben, the problem that these things develop is that the phospor-bronze wiper contact wears down to the point that it looses contact with the wire-wound resistance card at certain points in the arc of travel. No amount of tuner cleaner will fix that... They have to come out of the tank. As soon as you can visualize the little wiper sliding on the resistance wire the problem will become painfully obvious. You can use an Ohmmeter to measure the resistance while you are moving the float. AFAIR, the resistance varies from 0 to ~70 Ohms. If at any point in the swing you read "infinity", you have found your problem spot(s) There is an outfit in Lock Haven that can o/h them for you. Be sure to use new gaskets when you reinstall them... MikeM Skylane 1MM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Cessna 172 with Wild Fuel Gauge Needle | jls | Owning | 26 | February 20th 04 05:56 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
