Aluminum instrument panel finish?
Old February 2nd 04, 05:52 AM
Richard Riley
Default Aluminum instrument panel finish?
I've just finished machining my instrument panel. It is (I say with
no small pride) nice. Milled out of 2024T3 3" thick, reduced to .120
with .120 webs between each instrument and around the perimeter.
Now the question is: how should it be finished? Polished? Engine
turned? Anodized? Clear powder coat?
Old February 2nd 04, 07:17 AM
On Sun, 01 Feb 2004 21:52:15 -0800, Richard Riley
Time to get the budget under control, Richard. Rust-o-Leum.
Ron "It *is* a Fly Baby, ain't it?" Wanttaja
Old February 2nd 04, 06:59 AM
Del Rawlins
I think I would rather have a matte finish on mine, but ya gotta admit
that Pat Fagan's engine turned panel is a thing of beauty:
http://www.airbum.com/pireps/PirepPatFaganBH.html
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old February 2nd 04, 07:43 AM
guynoir
Here's my experience with Anodizing. I liked it a lot.
http://www.eaa292.org/noon_patrol/dec_00/p1010006.jpg
John Kimmel
I think it will be quiet around here now. So long.
Old February 2nd 04, 07:14 PM
B2431
Date: 2/2/2004 1:43 AM Central Standard Time
Message-id: . net
That's a thing of beauty. Leaving the rivets uncoloured was a good touch. How
will you keep them from corroding?
Dan, U.S. Air Force, retired
Old February 2nd 04, 12:09 PM
Scott
Well, mine started out as just a plain piece of 0.125 aluminum and I used a
fly cutter to cut out the instrument holes and I went to Menards (Home
Depot-like place) and bought countertop laminate to put over it. Drilled
through a few instrument mounting screw holes and used machine screws and
nuts to keep it in place and used a laminate cutting bit in my dremel to
"rout" out the instrument holes. Worked really nice. Do not glue the
laminate to the aluminum, just use the instrument and panel mounting holes
to keep the laminate in place. I have an open cockpit plane, so laminate is
good incase it rains while I'm at a fly in.
Scott
http://corbenflyer.tripod.com/
Building RV-4
Gotta Fly or Gonna Die
"Richard Riley" wrote in message
Old February 2nd 04, 12:38 PM
Stealth Pilot
it all depends on whether you are building a hangar queen or an
aircraft to fly.
a matte surface in a medium dark green works pretty well.
if you go with polished or a gloss surface try not to fly in bright
sun or with the sun behind you. one will have you looking at high
quality reflections of your shirt and the other might just blind you.
btw crinkle finish black is a traditional crappy looking option :-)
Stealth Pilot
oz.
Old February 2nd 04, 01:42 PM
Nathan Young
A flat finish is helpful for reducing glare on an instrument panel, so
I definitely would not go with polished.
-Nathan
Old February 2nd 04, 03:30 PM
Bill Chernoff
3 inches thick down to 0.120 ??!!!
How long did it take to machine?
Can you post a link to a photo?
thanks
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 09:27 PM
