Orval Fairbairn wrote in message .. .
This past Monday, a couple of my friends took off in a Bonanza with a 3-blade McCauley prop installed. At about 1000 feet, on power reduction, one of the blades came unhooked from its pitch change mechanism and went into "free pitch" mode. There is a composite material link between the pitch change mechanism and the blade acutator pin, which is on the circumference of the blade shank. It's about 2" long. This is a reason that McCauley specifically warns against pulling the airplane with the prop while on the ground. If you pull on the back edge of the blade, you can put enough torque on it to threaten the links. Ond does wonder how they were cared for because this is a very rare failure. It would be like a terrible mistrack on a helicopter rotor. Bill Hale BPPP Instructor |
McCauley prop blages | Cy Galley | Aviation Marketplace | 0 | January 25th 04 09:24 PM |
gpa a factor after graduation? | sibersmith | Military Aviation | 28 | November 26th 03 05:06 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Shortened McCauley Propeller on an O-300 | Larry Smith | Home Built | 12 | September 10th 03 01:40 AM |
