Oil on the belly of the aircraft & the occasional streak around the cowl
, , , Bugs on the leading edge & struts . . . fingermarks around the baggage door . . . I use Turtlewax bug & tar remover in a trigger spray bottle - about $4.00. - spray on, leave one minute and wipe off. So far has worked really well and I haven't seen any negative side effects. What do you use? -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE |
I buy el-cheapo windshield washer fluid. Works well on the painted surfaces,
but I have not used it on the plexi. KB "tony roberts" wrote in message news:nospam-2C0656.22444731052004@shawnews... Oil on the belly of the aircraft & the occasional streak around the cowl , , , Bugs on the leading edge & struts . . . fingermarks around the baggage door . . . I use Turtlewax bug & tar remover in a trigger spray bottle - about $4.00. - spray on, leave one minute and wipe off. So far has worked really well and I haven't seen any negative side effects. What do you use? -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE |
On Tue, 01 Jun 2004 05:41:58 GMT, tony roberts
wrote: Oil on the belly of the aircraft & the occasional streak around the cowl , , , Bugs on the leading edge & struts . . . fingermarks around the baggage door . . . I use Turtlewax bug & tar remover in a trigger spray bottle - about $4.00. - spray on, leave one minute and wipe off. So far has worked really well and I haven't seen any negative side effects. What do you use? REJEX, but it's like 20 bucks a bottle because somewhere on the label it says "airplane". Works well as a preventative, but I'm trying the Turtle Wax this week!. |
In article nospam-2C0656.22444731052004@shawnews, tony roberts
wrote: Oil on the belly of the aircraft & the occasional streak around the cowl , , , Bugs on the leading edge & struts . . . fingermarks around the baggage door . . . I use Turtlewax bug & tar remover in a trigger spray bottle - about $4.00. - spray on, leave one minute and wipe off. So far has worked really well and I haven't seen any negative side effects. What do you use? My teenager. - - - - - - Al Gilson 1964 172E KSFF Spokane, WA -- Al Gilson Spokane, WA USA 1970 VW Convertible 1964 Cessna Skyhawk |
Plexiglas cleaner/ polish | eddie | Owning | 9 | August 1st 03 12:59 AM |
Wing cleaner | Viperdoc | Owning | 27 | July 15th 03 05:03 PM |
