Handheld GPS auto mount OK?
Old June 16th 04, 03:29 AM
Newps
"Henry Kisor" wrote in message
I've just bought myself a new Garmin handheld GPS. I noticed that the auto
dash mount is stuck to the dashboard with some kind of double-stick stuff.
Is it OK by the FAA to stick the mount onto my airplane's glare shield
this
way, or do they consider it a permanent installation and require 337s and
stuff?
What about using strong Velcro? Will that pass muster with the FAA as a
temporary installation?
I've used velcro for my Garmin Pilot III for the last 5 years. I also
hardwired it into the aircraft. Couldn't possibly care less what the FAA
thinks.
Old June 16th 04, 04:27 AM
Dave S
You have an experimental or certified, newps?
this
stuff?
thinks.
Old June 16th 04, 11:41 AM
Kevin
auto
stuff.
this
and
stuff?
thinks.
Amen !
Old June 17th 04, 12:17 AM
Newps
"Dave S" wrote in message
news
I have a 182. You can't possibly be worried about velcro fer cryin' out
loud, can you? For the power I took the cig lighter plug and snipped off
the cig lighter end. Ran the two wires into the electrical bus and used a 1
amp fuse from Rat Shack. Had the mechanic sign off the power cord. My
setup is neat looking because I have an avionics access panel on the top of
the glareshield. The cord just disappears down there from behind the GPS,
you don't even see it from the pilots side.
Old June 17th 04, 04:47 AM
Jon Woellhaf
"Newps" wrote, "... I have an avionics access panel on the top of the
glareshield."
Please tell me more. I have a 182Q. Did you create the access panel
yourself?
Regards,
Jon
Old June 17th 04, 11:20 PM
Newps
"Jon Woellhaf" wrote in message
news:zv8Ac.62220$HG.3470@attbi_s53...
glareshield."
yourself?
No, I assumed it was standard for my year. I have a 67 182K. The panel is
about 12 inches wide and about 8 inches front to back. Held down with about
12 little sheet metal screws.
Old June 17th 04, 05:03 AM
Aaron Coolidge
Newps wrote:
: amp fuse from Rat Shack. Had the mechanic sign off the power cord. My
: setup is neat looking because I have an avionics access panel on the top of
: the glareshield. The cord just disappears down there from behind the GPS,
: you don't even see it from the pilots side.
I also have an avionics access panel in the top right side of the glareshield
of my Cherokee. I ran my GPS power cord through this opening, as well. It
looks very neat, the cord stays out of the way if I don't want to use the
GPS, and you don't see the cord at all. I glued velcro to the top of the
glareshield to hold my GPS (295) because the extra weight on the yoke annoys
my autopilot. The whole setup is very nice, IMHO.
Aaron Coolidge (N9376J)
Old June 16th 04, 01:44 PM
Henry Kisor
Yeah, but what happens if you get ramped? That's my concern.
"Newps" wrote in message
auto
stuff.
this
and
stuff?
thinks.
Old June 16th 04, 03:31 PM
Drew Dalgleish
On Wed, 16 Jun 2004 07:44:30 -0500, "Henry Kisor"
IF you get ramped and IF the inspector thinks the mount is permanent
grab it with both hands and rip it off. The 2 sided tape isn't that
strong that it can't be removed. I think they probably see an awful
lot of these mounts and won't be concerned about it. Better to have it
firmly attached than flying around the cockpit in turbulance.
auto
stuff.
this
and
stuff?
Old June 16th 04, 05:50 PM
Frank Stutzman
If you get ramp checked, what the heck is the inspector doing pawing
through your cockpit? Hand him the required paperwork and put the sun
screens into place. He has no business inspecting the inside of your
cockpit.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
FS: GPS - Handheld II Morrow - Apollo 920 Moving Map ft worth Aviation Marketplace 0 February 28th 04 08:33 PM
Handheld GPS For Auction ecktoeman Aviation Marketplace 0 July 28th 03 09:07 PM
FS: GPS - Handheld II Morrow - Apollo 920 Moving Map NRH, Texas Aviation Marketplace 0 July 24th 03 06:47 PM
