![]() "Terry" wrote in message ... Now that the Garmin 296 has been out for a little while, anybody have comments good or bad? I am a little leary about spending $1800 on a new GPS that might have "bugs" that need to be worked out before it is a really good unit. So don't spend $1800 on it. The street price is more like $1700. Is it worth $400 more than the 295? I think so, just because of the marine and automobile capabilities, as well as the terrain avoidance feature. The chief bug is getting it to talk to Jeppesen FliteStar, which is more a feature of FliteStar's outdated communication capability than it is a problem with the GPS. FliteStar has never been able to really use other GPS units, either -- it sort of simulates talking to them and I consider some 'features' of this program to be actually dangerous. Even if the 296 could talk to FliteStar without problems you would still be left with FliteStar's inherent weaknesses, including the fact that FliteStar creates and substitutes user waypoints for the GPS unit's database waypoints, often misplacing them and losing essential information in the process. It is far better to enter your flight plan into a GPS manually. But, if you have a 295 already, is it worth upgrading to the 296? The 296 has somewhat better battery life, but uses a proprietary battery. If you already have a 295, the question is the 296 really worth $1700 more than the 295? I don't think so, not by a long shot. In fact, if you have a 196 it probably is not worth upgrading to the 296. The 296 is not worth $1700 more than the 196. The 296 should have full approaches in it, not just the final approach segments. Sure, it is not certified for IFR flight, but it would be a fine emergency backup tool in the event of the loss of primary aircraft systems. Garmin obviously has chosen not to include full approaches for several reasons: 1. It would compete with Garmin's panel mounts. 2. The FAA would object on the grounds that pilots would use handhelds to fly approaches even when there is not an emergency (the old "better that a few should die in real emergencies rather than let people get away with saving money" argument). 3. The people who buy the 296 probably would not keep the database updated. The last argument is probably both the weakest and the strongest. The 296 includes terrain and tower information, which means that the database should be kept current for the terrain avoidance feature to be anywhere near reliable. Since the database is only good for 28 days few people will subscribe to any sort of service to keep it current. The cost of database updates with approaches would exceed the initial cost of the unit in just a couple of years. One other argument, that the 296 does not have the memory to include IFR procedures, might also be valid, except there is no excuse for putting such a small memory in GPS units in the first place. For the money manufacturers charge for them, the things ought to have a gigabyte of memory. I make it a practice to play with every GPS I can get my hands on. The one I use is the 296. Overall, it is easy to use, has a very good display, and has reasonable battery life. I like its features and I really like the terrain awareness feature. The automobile navigation system is mediocre at best, but far better than what the 295 had. It is at least marginally useful. The marine system is pretty good. This is finally a GPS that is something I can actually use in my day to day work as a flight instructor. |
![]() Thank You Chris....just the kind of information I was looking for. Thanks for taking the time. Terry |
C J Campbell wrote:
: But, if you have a 295 already, is it worth upgrading to the 296? The 296 : has somewhat better battery life, but uses a proprietary battery. If you : already have a 295, the question is the 296 really worth $1700 more than the : 295? I don't think so, not by a long shot. In fact, if you have a 196 it : probably is not worth upgrading to the 296. The 296 is not worth $1700 more : than the 196. I have a 295 and concur. : The 296 should have full approaches in it, not just the final approach : segments. Sure, it is not certified for IFR flight, but it would be a fine : emergency backup tool in the event of the loss of primary aircraft systems. : Garmin obviously has chosen not to include full approaches for several : reasons: Until about 18 months ago, the 295 had full GPS approaches in it. When the GPS approach into 1B9 was changed, I updated my 295. Lo and behold, the approach was gone, leaving only one IAF and the FAF. It appears that Garmin or Jeppesen removed all intersections that are not either (1) on the en-route charts, or (2) the closest IAF and the FAF of an approach. : One other argument, that the 296 does not have the memory to include IFR : procedures, might also be valid, except there is no excuse for putting such : a small memory in GPS units in the first place. For the money manufacturers : charge for them, the things ought to have a gigabyte of memory. My 8 year old Northstar M3 has all of the GPS approaches, intersections, NDB, VOR, airports, and all of the appropriate frequencies for the US on its 2 MB data card (it does not contain SID/STAR, you have to generate those manually in a flight plan). The excuse that the 296 can't hold the approaches because of memory size is just that: an excuse. -- Aaron Coolidge (N9376J) |
The question really is, is the 296 worth $1700 minus the value of your
current GPS. I know my 196 is worth $700+ to tropicaero as a trade up, "value add" must only be $1000, not $1700. Despite the proprietary battery, the unit recharges itself while plugged in to the plane's DC power (and continues to function too), which I think increases its relative value if you have a power socket available. What I really want to know is whether they are going to add on XM satellite weather capability, like Lowrance is doing with their upcoming model. This would make it a no brainer for me. "C J Campbell" wrote in message ... "Terry" wrote in message ... Now that the Garmin 296 has been out for a little while, anybody have comments good or bad? I am a little leary about spending $1800 on a new GPS that might have "bugs" that need to be worked out before it is a really good unit. So don't spend $1800 on it. The street price is more like $1700. Is it worth $400 more than the 295? I think so, just because of the marine and automobile capabilities, as well as the terrain avoidance feature. The chief bug is getting it to talk to Jeppesen FliteStar, which is more a feature of FliteStar's outdated communication capability than it is a problem with the GPS. FliteStar has never been able to really use other GPS units, either -- it sort of simulates talking to them and I consider some 'features' of this program to be actually dangerous. Even if the 296 could talk to FliteStar without problems you would still be left with FliteStar's inherent weaknesses, including the fact that FliteStar creates and substitutes user waypoints for the GPS unit's database waypoints, often misplacing them and losing essential information in the process. It is far better to enter your flight plan into a GPS manually. But, if you have a 295 already, is it worth upgrading to the 296? The 296 has somewhat better battery life, but uses a proprietary battery. If you already have a 295, the question is the 296 really worth $1700 more than the 295? I don't think so, not by a long shot. In fact, if you have a 196 it probably is not worth upgrading to the 296. The 296 is not worth $1700 more than the 196. The 296 should have full approaches in it, not just the final approach segments. Sure, it is not certified for IFR flight, but it would be a fine emergency backup tool in the event of the loss of primary aircraft systems. Garmin obviously has chosen not to include full approaches for several reasons: 1. It would compete with Garmin's panel mounts. 2. The FAA would object on the grounds that pilots would use handhelds to fly approaches even when there is not an emergency (the old "better that a few should die in real emergencies rather than let people get away with saving money" argument). 3. The people who buy the 296 probably would not keep the database updated. The last argument is probably both the weakest and the strongest. The 296 includes terrain and tower information, which means that the database should be kept current for the terrain avoidance feature to be anywhere near reliable. Since the database is only good for 28 days few people will subscribe to any sort of service to keep it current. The cost of database updates with approaches would exceed the initial cost of the unit in just a couple of years. One other argument, that the 296 does not have the memory to include IFR procedures, might also be valid, except there is no excuse for putting such a small memory in GPS units in the first place. For the money manufacturers charge for them, the things ought to have a gigabyte of memory. I make it a practice to play with every GPS I can get my hands on. The one I use is the 296. Overall, it is easy to use, has a very good display, and has reasonable battery life. I like its features and I really like the terrain awareness feature. The automobile navigation system is mediocre at best, but far better than what the 295 had. It is at least marginally useful. The marine system is pretty good. This is finally a GPS that is something I can actually use in my day to day work as a flight instructor. |
Jeremy Lew wrote:
The question really is, is the 296 worth $1700 minus the value of your current GPS. I know my 196 is worth $700+ to tropicaero as a trade up, "value add" must only be $1000, not $1700. Despite the proprietary battery, the unit recharges itself while plugged in to the plane's DC power (and continues to function too), which I think increases its relative value if you have a power socket available. What I really want to know is whether they are going to add on XM satellite weather capability, like Lowrance is doing with their upcoming model. This would make it a no brainer for me. Do you have a URL about this? There is no mention of it on the website for the Airmap 2000... Although you'd need to fly quite a bit to justify the $50 a month subscription for that, plus the cost of the required XM gear... http://www.xmradio.com/weather/service_and_pricing.html |
Interestingly, the source where I first heard of this [1] is no longer
claiming XM compatibility. It used to say that both TAWS-like capability and XM weather would be supported via a free firmware upgrade some time after shipping . Now they only mention the terrain stuff. I'm in a 10-pilot club, so $50/mo. isn't a deal breaker. As far as the "XM gear" goes, the original claim was that it would all be built in to the airmap. Who knows now... [1] http://www.avshop.com/catalog/produc...productid=6054 "Darrel Toepfer" wrote in message ... Jeremy Lew wrote: The question really is, is the 296 worth $1700 minus the value of your current GPS. I know my 196 is worth $700+ to tropicaero as a trade up, "value add" must only be $1000, not $1700. Despite the proprietary battery, the unit recharges itself while plugged in to the plane's DC power (and continues to function too), which I think increases its relative value if you have a power socket available. What I really want to know is whether they are going to add on XM satellite weather capability, like Lowrance is doing with their upcoming model. This would make it a no brainer for me. Do you have a URL about this? There is no mention of it on the website for the Airmap 2000... Although you'd need to fly quite a bit to justify the $50 a month subscription for that, plus the cost of the required XM gear... http://www.xmradio.com/weather/service_and_pricing.html |
Try 256-319-9679 Huntsville, AL tech support.
I have never heard of the port to Lowrance. All I got from the AOPA show meeting with the owner was the G1000 project and then the GNS530's. I use the product on a laptop and NavAero TPad800. $50/mth is fair compared to the price of the other products that use sat phones & charge per download. I turn this thing on & get all the weather/winds/lightning/METAR/TAF/Fronts/ on & on.... -- Thx, {|;-) Victor J. (Jim) Osborne, Jr. take off my shoes to reply |
weather/winds/lightning/METAR/TAF/Fronts/ on & on.... Does the "on & on" include PIREPs ? I could never get a straight answer on that from Wxworx... |
No PIREPs at this time. I understand they ARE working on it. It's a matter
of them being made available in a form they can readily use. I know you can get PIREPS on line from http://adds.aviationweather.noaa.gov/pireps/ but the format isn't transferable at this time. (What I am told.) To me, the real 'straight answer' problem comes from 'sales' saying yes and 'IT' i.e. programmers, having to make it so. I made my living doing software for others for a few years. I learned the truth in the phrase "Do you know how to tell when a salesperson is lying? When their mouth is moving." Having said that, I have had good results from calling Huntsville and getting help from Lyle. -- Thx, {|;-) Victor J. (Jim) Osborne, Jr. |
![]() "Jeremy Lew" wrote: What I really want to know is whether they are going to add on XM satellite weather capability, The thought of this just makes me drool. I love WxWorx's XM satellite weather and I love the 296. Putting them them together would let me get rid of that damned notebook pc that's cluttering up my airplane right now. I hope Garmin is developing this. I've sent them an e-mail begging for it. -- Dan C172RG at BFM |
how much money have you lost on the lottery? NOW GET THAT MONEY BACK! | shane | Home Built | 0 | February 5th 05 07:54 AM |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Start receiving MONEY with this simple system. Guaranteed. | Mr Anderson | Aviation Marketplace | 0 | February 2nd 04 11:55 PM |
