Groundplane for transponder
Old February 4th 04, 07:50 PM
Mads
Default Groundplane for transponder
Anyone with depth knowledge of groundplanes for transponders?
- their mission (any theory would be appreciated)?
- required dimension
- required shape (is a cross OK or does it have to circular)
- material (is aluminium tape OK?)
- installation - follow the a/c body, or flat
- how critical is the above (loss of signal strength?)
regards
Jan Ivar
Old February 5th 04, 03:40 AM
Orval Fairbairn
In article , "Mads"
They complete the electronic circuit for the antenna.
1.5 feet from the center of the antenna should work fine. (1/4 wave)
Eight crossing strips of aluminum tape, about 3 feet long, should do
quite nicely.
Yes -- as long as you have electrical contact with the antenna base.
Remove the adhesive at the center so that the aluminum tapes all contact
each other.
Doesn't matter too much.
Keep it away from other antennae.
Old February 5th 04, 04:13 AM
A transponder antenna is only 2-3/4 inches long. That is a quarter wave
length at the transponder operating frequency. A disk as small 5-1/2 inches
in diameter will provide an adequate groundplane.
http://www.soaridaho.com/Schreder
"Orval Fairbairn" wrote in message
news
In article , "Mads"
quite nicely.
each other.
Old February 5th 04, 01:49 PM
Ron Natalie
"Orval Fairbairn" wrote in message newsrfairbairn_spam_sucks-
A quarter wave is only on the order of a few inches for a transponder.
Old February 5th 04, 06:14 PM
Jay
I'll throw in my 2 cents...
"Mads" wrote in message ...
To make an analogy, trying to use an antenna without a ground plane is
like trying to punch someone in the face whilst wearing ice skates.
Ya, just aren't going to get very much power out there because every
time you swing forward, your body moves back.
Larger in radius than the wavelength you are working with.
Round or bigger (ya know what I mean?)
Large difference in dielectric constant from the medium you are trying
to transmit into. Aluminium is great. My worry with tape is that the
adhesive will act as an insulator bewteen layers. The tape I'm
familiar with would seem to fatigue if its on anything that could flex
and might give an intermittant behaviour if it did. If you have to
use tape, maybe use copper tape and run a bead of solder along there
edge wherever one strip crosses the other.
Flat is best, but many parts of a metal airplane look flat at 1GHz.
Signal propogation at these frequencies is line of sight (much more so
than your VHF nav/com radio) so position the antenna such that it has
the fewest obstructions back to the surveillance radar.
The difference between a good and bad antenna installation can be
easily 6dB. You payed a lot of money for your 200W transmitter, don't
throw that power away on a bad antenna installation.
Regards!
Old February 5th 04, 07:57 PM
Mads
Thanks for the responce.
Do you know of any good websites with more indepth info on this?
Regards
Jan Ivar
"Jay" wrote in message
om...
Regards!
Old February 5th 04, 10:56 PM
Kevin Horton
like trying to punch someone in the face whilst wearing ice skates. Ya,
just aren't going to get very much power out there because every time you
I can tell you watched much hockey.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
e-mail: khorton02(_at_)rogers(_dot_)com
Old February 6th 04, 12:59 PM
Bushy
Is that why they all carry those sticks?
Peter
