I recently had these symptoms, and it was a bad spark plug wire. It was
intermittently sparking between the center conductor and the sheathing braid, rather than at the plug electrode. Easily found with a cable tester, most mechanics should have one -- something like this: http://www.aircraftspruce.com/catalo...abletester.php "C Kingsbury" wrote in message om... Hi there, Googling past threads yielded nothing definitive so here goes: On runup today, noted the following: 1. RPM to 1700, switched to right mag, dropped ~150 rpm 2. Increased RPM to 2000, leaned back until I got a 100rpm drop and held for one minute to clear it. We've had to do this pretty regularly lately* 3. During the lean-out I started hearing a regular popping or clicking noise, clearly electrical in nature, about 1-2x/second on the intercom 4. After leaning out, throttle back to 1700, check right mag. RPM drop maybe 50-75, popping sound disappears 5. Switch to left mag, popping sound returns, rpm drops 200 6. Repeated leaning out at RPM, same result, i.e., left mag still dropping too much for me. I'm going to call the shop Monday to have the plugs checked, is there anything else this sequence of events suggests to anyone? Airplane in question is a 1979 C172N, engine tach time about 1800. We do have one cylinder that tested 63/80 at annual back in March. * We do lean for taxi, but probably not enough. It has required a burn-off more often than not the last few months, but one or two cycles has always cleared it up successfully. TIA, -cwk. |
burn-off more often than not the last few months, but one or two cycles has always cleared it up successfully. Probably not the case here but carburetor ice can build on a long taxi just like when landing. Might pull heat and see if it does anything. |
