Early 60's 182 numbers?
Old September 18th 04, 01:05 AM
Brinks
Default Early 60's 182 numbers?
I'm looking into an early '60's vintage 182. I was wondering what people
had for real world numbers on cruise speed and fuel burn. And if anyone has
any advice on particulars to look for during a pre-buy or anything else,
that would be helpful also. Thanks!
Chris
Old September 18th 04, 03:05 AM
Darrel Toepfer
A local '64 does 140 mph and 10 gallons per hour...
Old September 18th 04, 03:22 AM
Newps
Cessna went to the big tail on the 182's for 1965, these are better on
the wide bodies than the small tail 62-64 models. I have a 67 with big
tires, VG's and no speed mods or wheel pants. I get about 128 kts TAS.
I rarely indicate over 140 mph, it has to be pretty cold. You'll
get about 11.5-12 gph in cruise above about 8000. As to what to look for...
Engine and prop are standard items to look at. The engine mount needs
to be inspected. That vintage of 182 has to have heat shields or the
mount will corrode. Look at the firewall. Hopefully somebody after
about 1968 landed it on the nosewheel and wrecked the firewall. Then if
it was repaired right they will have put in the thicker firewall. This
is very desirable. Look at the main gear attach points. If somebody
lands really hard on the mains these can crack. Look inside the
airframe for corrosion, especially the attach bolts and other hardware.
You can total a 182 due to corroded fittings. Finally look at the
tail attach point. There is a recurring AD to inspect the tail attach
every 4000 hours. Look for leaking fuel from the bladders. If it's
leaking it will be obvious under the wing and down the fuselage, you
can't hide it. Everything else is nickles and dimes, relatively speaking.
Old September 18th 04, 05:07 PM
Rob Wren
I get pretty close to book numbers...158 mph TAS in my stock 61 182 at
13.5 GPH per my JPI fuel flow monitor. It's in the paint shop right
now so I expect to gain 15 - 20 mph with the new paint ;^)
Old September 20th 04, 08:21 PM
Alan Bloom
My '60 182-C regularly speeds along at 150mph and burns 12gph on
average. These numbers go down & up respectively when my dogs stick
their heads out the window.
Dogs can fly.
http://www.flyingmutts.com
On Fri, 17 Sep 2004 19:05:53 -0500, "Brinks"
Chris
Modern Inventions early Science 1900s airships FA LindaBeynon Aviation Marketplace 0 February 7th 05 12:41 AM
U.S. Nacy Null Numbers David R Townend Naval Aviation 0 September 2nd 04 04:57 PM
US Hull Numbers David R Townend Naval Aviation 0 January 26th 04 03:10 AM
1930s Navy side numbers. JDupre5762 Naval Aviation 3 September 24th 03 07:51 PM
Early morning hotel-to-airport Bob Fry General Aviation 21 July 25th 03 05:51 AM
