t-hangar and ice
Old October 16th 04, 05:07 PM
john smith
If you get crushed limestone, water and pressure (roll it) will cause it
to compact into a solid mass.
Jay Honeck wrote:
Get a couple bags of pea gravel and sand, spread it in the low spot to
deflect the water away from the hangar.
Under NO circumstances should you spread pea gravel or sand in front of your
hangar door.
Our hangar neighbor did that last year, and that damned stuff ended up all
over our tarmac. Can you say "sandblasted"?
You can get the same result with a few bags of asphalt patch, which is more
durable and won't blow away.
