Newps wrote :
Yeah, aircraft that fly thru the air are aircraft and thus regulated by the FAA. It can't be that simple. Don't radio controlled aircraft fly through the air (out of ground effect)? Just wondering, John Galban=====N4BQ (PA28-180) |
oups.com... Newps wrote : Yeah, aircraft that fly thru the air are aircraft and thus regulated by the FAA. It can't be that simple. Don't radio controlled aircraft fly through the air (out of ground effect)? Just wondering, John Galban=====N4BQ (PA28-180) John, IIRC, immediately after 9/11 there was some talk amongst the R/C folks that the FAA was looking at actually trying to regulate all R/C flying. Jay Beckman PP-ASEL Chandler, AZ |
Robert M. Gary wrote:
wrote: Newps wrote : Yeah, aircraft that fly thru the air are aircraft and thus regulated by the FAA. It can't be that simple. Don't radio controlled aircraft fly through the air (out of ground effect)? Just wondering, At best they would be "air vehicles" under FAR 103 since they carry less than 5 gals of gas and weighs less than 254 lbs. Basically this means you can't fly them over congested areas. Homemade rockets ARE regulated. Its been a while since I've launched rockets but I believe anything with an "H" engine or larger requires certification. There are examiners around that do the certifications. -Robert FAR 1 says "Aircraft means a device that is used or intended to be used for flight in the air." The term "flight" doesn't seem to be defined so you are left with the dictionary definition. FAR 1 also defines airplane, airship, balloon, rotorcraft, etc. FAR 103 only applies to manned operation. FAR 101 regulates moored balloons, kites, unmanned rockets, and unmanned free balloons. There does not seem to be a FAR that explicitly addresses unmanned airplanes, airships, rotorcraft, or powered lift aircraft. With the proliferation of UAVs these days, I would expect that to change in the future. -- Jim Pennino Remove -spam-sux to reply. |
My definition of airplane is: If the engine quits and you do nothing,
will you die? If the answer is yes, it's an airplane... Denny |
"Denny" wrote in message
oups.com... My definition of airplane is: If the engine quits and you do nothing, will you die? If the answer is yes, it's an airplane... Oh you're such a pessimist... http://www.ntsb.gov/ntsb/brief.asp?e...06X01568&key=1 |
Denny wrote:
My definition of airplane is: If the engine quits and you do nothing, will you die? If the answer is yes, it's an airplane... Denny That definition also fits helicopters, motorcycles and automobiles in many circumstances. Matt |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
ADV: World Air Power Journal collection on Ebay | Jeb Hoge | Military Aviation | 1 | March 16th 04 02:18 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
