in talking about that, one of the people at my base....not at
"aces"... told me they have been hearing about faa looking into a structural problem with c-152 rudders. since they've got several and since i'm almost certainly going to be buying one in the next few months we're kinda curious about what might be going on. Of the thousands that have been built and flown hard as trainers, a few dozen have developed some cracks that were found on inspections (not by the tail coming off - that never happened on any C-150 or C-152) and there's going to be an inspection required for cracks (may already be out) on a periodic basis. This type of AD is very common on all-metal airplanes and not a big deal. BTW - you should consider the Tomahawk if you are in the market for a C-152. Generally more bang for the buck, roomier, better visibility, carries more fuel, and a bit faster. Not as good for soft/rough fields though. Michael |
tomahawk??? ya got me....i'll google it. thx
dan |
Oh, the Trauma-hawk. If there has ever been a plane plagued with AD's up
the ass, this is the one. -- www.geocities.com/ralphsnart2004/index.html "houstondan" wrote in message oups.com... tomahawk??? ya got me....i'll google it. thx dan |
ok, i found the tomahawk. nope, living in houston, i just think the
sun beating down on me thru that bubble would be too much. i've talked to people here who say it's pretty bad. it does look like a great a/c tho. dan |
sun beating down on me thru that bubble would be too much. Your call, of course, but before you make the decision, you might drive on over to Pearland Regional (formerly Clover) and fly one of Mike King's when summer comes around. I've never found it to be a problem because on the ground it's easy to keep the doors open, and once airborne the ventilation is excellent. I've seen Tommy's with low time engines and airframes and good IFR panels going for $20K. Michael |
i'll check it out. do apppreciate the input.
dan |
The vertical fin on a C-150 is held on to the fuselage with a welded
steel bracket riveted into the aluminum structure. The welds are in the corners where the stress is highest. The steel undergoes galvanic corrosion when it is close to aluminum. These aircraft are being used well beyond their original intended lifetime and this steel fitting was cracked in the welds on the two 150s I'm familiar with. I thought it was a recent AD or at least a recent service letter. They were certainly not airworthy. This should be checked at annual on any 150 since it is an area of known service difficulty. The 172s don't have this problem with the bracket as it is an aluminum forging - not prone to corrosion. It would be one thing to lose a rudder, but losing both the rudder and vertical fin would be pretty exciting. It would be even worse if the rudder cables kept the separated surfaces attached to the rest of the airplane. |
Which is what would happen. Any control surface falling off is a
death sentence. Besides, the rudder is part of the vertical surface contributing to lateral stability. The airplane would be inclined to fly sideways without the rudder. Some aircraft, like my Jodel and many of the Zenair airplanes, have no fixed vertical surface and rely almost entirely on the rudder for stability. Dan |
Any control surface falling off is a death sentence.
I know a pilot who lost a control surface in a 150 Aerobat who will be very surprised to hear it. Rumors of his death are highly exaggerated. Michael |
![]() wrote in message oups.com... Which is what would happen. Any control surface falling off is a death sentence. Not. Besides, the rudder is part of the vertical surface contributing to lateral stability. The airplane would be inclined to fly sideways without the rudder. Some aircraft, like my Jodel and many of the Zenair airplanes, have no fixed vertical surface and rely almost entirely on the rudder for stability. Dan |
B2 Split Rudder | Emilio | Military Aviation | 8 | April 12th 04 10:43 AM |
P-51 Rudder Aerodynamics | Hawkeye Hughes | Home Built | 1 | March 15th 04 09:24 AM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
Rudder cable - was The Little Wheel in Back | BD5ER | Home Built | 9 | September 11th 03 04:14 PM |
