Transition to PA-32R
Old December 21st 04, 05:17 PM
nobody
Mike,
I use another memory aid in addition to GUMPS.
PUF on final, which stands for:
Prop(s) - set for go around
Undercarriage - confirm it is down and locked
Flaps - final setting for landing
This "PUF on final" check saved me from a possible gear up landing (or
at least explaining to the instructore why I missed the gear check) during
the early days of my retract flying experience. This occurred after an
instructor pulled the gear pump circuit breaker while distracting me with
something else. I did the GUMPS check on downwind, and placed the
gear handle down, the gear dropped but did not fully extend and lock,
the noise picked up, I had extra drag, and it seemed like the gear was
in fact down. However, I failed to comfirm the green lights. After turning
final and doing the "PUF on final" check, I noticed the lights were not on.
Another technique taught to prevent the above senario is to leave your
hand resting on the gear switch until the down and lock indicators are
illuminated. If you don't move your hand off the switch until you confirm
the gear is down and locked, you will be less likely to overlook confirming
the locked status.
Have fun flying Saratoga.
Ron
"Mike Granby" wrote in message
Landing was, of course, the hardest bit. I never
came close to fogetting the gear, as I had my instructor shouting
GUMPS! GUMPS! every ten seconds, but I did realize when we did a
straight-in approach to a controlled airport how things like that can
shorten the accident chain...
Old December 21st 04, 07:27 PM
john smith
Good advice, thanks Ron.
the locked status.
Old December 21st 04, 08:22 PM
Jim Burns
Rather than resting your hand ON the gear handle, rest it just underneath
it. This will prevent any sudden turbulence from causing you to
accidentally rip the gear handle right out of the panel. Although the
handles in Pipers are quite hefty, Cessnas and others are not.... and that
would REALLY suck!
confirming
the locked status.
Ron
Fulcrum low transition MPG Pechs1 Naval Aviation 0 October 7th 04 02:14 PM
GPS and Beyond: The SatNav Transition for aviation Kevin Horton Home Built 1 September 22nd 04 09:34 PM
Florida Mil Acft Comms Log - Saturday 1 May 2004 AllanStern Military Aviation 0 May 2nd 04 07:49 AM
Mil Acft Comms Log, Florida - Friday 30 April 2004 AllanStern Military Aviation 0 May 1st 04 07:12 AM
Patrick AFB Area Log - Saturday 7 Feb 2004 AllanStern Military Aviation 0 February 8th 04 08:48 AM
