Date: Wed, 22 Dec 2004 10:07:18 -0500 Local: Wed, Dec 22 2004 7:07=A0am Subject: Book Review:Maintenance/overhaul guide to This is typical "engineer" mentality. If a product can be made more complex, or if it can be squeezed for one more 1/2% of power, or if it could be installed in a smaller space or made smaller somehow, or if it could run off of some boutique fuel, it would absolutely obsolete everything coming before, regardless of the original product's history. There are enough engineering failures to underscore this mind set. I'll give you two..... Continental's Tiara engine and Lycoming's experience with the GSIO-720-A1A. Some of these engines may not be that far from a 1937 tractor engine, but, you know what? 65+ years later, we still haven't found anything affordable and reliable enough to replace them.... AND if they were sold for what they were *worth* they probably sell for less than $1000 per cylinder, new..... but that is another story.... The Continental Tiara was an example of ignoring the published literature. Any gear designer could tell them that 2:1 is the worst ratio because the same teeth see each other every other rev. It's in all the books. They tried to use the cam gear as a reduction gear, a stupid idea. I have no experience with geared 720s but I remember well the TIGO-541 and the GSIO-480, both of which were marvels of trouble. The 480 had an oddball mechanical injection system used nowhere else. If Lycoming or Continental had to make their ridiculous contraptions work in anything except an airplane, they would probably quit and go home. No one ever mentions that the reason the O-290-G engines were available cheaply until modern times is that they were an absolute pain in the ass in their original homes. Continental was smarter than to try to sell the IOL-550 as a sport boating engine, even though many custom Chevys sold for as much as the Continental did in aircraft trim. Twenty years of ski and fishing boat experience have convinced me that given a professionally engineered reduction drive a Chevy or Ford V8 is a lot more reliable than any engine with bolt on cylinders and a split crankcase. |
Book Review:Maintenance/overhaul guide to Lycoming aircraft engines, Christy | Paul | Home Built | 11 | December 26th 04 03:24 AM |
Data Recovery Book | Author Tarun Tyagi | Home Built | 1 | December 3rd 04 10:24 PM |
Book review:The Illustrated Buyer's Guide to Used Airplanes by Bill Clarke | Fred Collins | Owning | 0 | May 9th 04 02:16 AM |
FA: Vietnam The Helicopter War Large HC Book 189p | Disgo | Aviation Marketplace | 0 | February 6th 04 05:19 PM |
Announcing THE book on airshow flying | Dudley Henriques | Naval Aviation | 0 | January 7th 04 03:32 PM |
