Make templates from cardboard....get some 1'1/2" to 2' thick closed
cell foam.....put templates on foam and cut with sharp knife (or single edge razor) cutting slightly larger than templates so they will compress when installed and make snug fit.....make small slit and push poly rope thru.....make 2" square thin plywood (or metal) "backing block with hole for rope....put rope thru backing block and knot.....use long enough rope to connect both cowl plugs.....not fancy but cheap and they will work.... not hard to do. Or you can buy set from Sporty's............. A tip.....make connecting rope long enough to wrap once around prop....so that plugs will be pulled out if engine is started with plugs in place.....don't laugh, several years ago I made set of above described cowl plugs for club owned Champ. A major airline captain club member missed the cowl plugs on preflight (if he even did preflight?)....took off and flew for 1/2 hour with plugs in place....enough to cook and ruin the cylinders....after overhaul/rebuild of engine we made connecting ropes and policy to wrap the rope around the prop |
Modern Inventions early Science 1900s airships FA | LindaBeynon | Aviation Marketplace | 0 | February 7th 05 12:41 AM |
Mooney M20 Preflight and Cowl | Jon Kraus | Owning | 3 | November 24th 04 10:21 PM |
FS: 182 Cowl Plugs, Pitot Cover, Sunscreens | Robert Bullock | Aviation Marketplace | 0 | May 25th 04 05:05 PM |
Cowl / Engine Plugs for 1964 C172 Skyhawk - Any Recommendations ??? | Philip | Aviation Marketplace | 0 | April 23rd 04 01:32 PM |
Early morning hotel-to-airport | Bob Fry | General Aviation | 21 | July 25th 03 05:51 AM |
