![]() "Peter" wrote in message ... "Denny" wrote N registered aircraft are required to have all work recorded in the airframe and powerplant logs, what you apparently call maintenance records... I have no idea why you would think otherwise... My 1957 Apache came with an armload of logbooks going back to day one... In this country a plane that does not have a complete set of logbooks suffers a significant drop in the value of the aircraft... Logbooks yes. I have the logbooks. But logbooks don't contain the *details* of work done. They should contain references to other documents. For example a logbook might say that a 100hr check was done. What it won't say (unless the engineer felt like writing it in there) is that the landing gear gas seals had to be replaced and two instrument panel light had to be replaced, etc; that will be in a separate file which is referenced in the logbook. It sure should say that. In fact, very often light bulbs and other things are replaced with no log entries, either at the FBO or anywhere else. Sometimes the owner replaces light bulbs. There is usually no written entry anywhere when someone adds a quart of oil, either, or if they put air in the tires, or clean bugs off the prop. At the very least, though, the logbooks should contain the same details as any records kept by the FBO, such as they are. Mine do. |
Owner's right to maintenance records? | jls | General Aviation | 15 | January 24th 05 10:18 PM |
Owner's right to maintenance records? | jls | Owning | 0 | January 20th 05 12:57 PM |
USS Liberty Challenge/Reward | Issac Goldberg | Naval Aviation | 75 | July 16th 04 09:28 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
