Metal working...
Old February 24th 04, 11:51 AM
Blueskies
Default Metal working...
Any suggestions for a good text and/or discussions about metal shrinking, dinging, stretching, etc. I would like to
learn to form aluminum into scoops and other shapes. I know it is a practice, practice, practice (almost) art form.
Thanks all!
Dan D.
Old February 24th 04, 12:34 PM
Cam
Hi, Try to find an Old panel beater (car panel repairer)
I learnt alot with regard to shrinking panel steel useing a oxy/acc set.
Aluminium has a much higher coeficient of expansion with heat, but should
still apply. Just keep in mind that you will f**k any strength properties
the alu had from the process, but then again, there might be a work
hardening factor to your advantage.
If you just want to make spoons for your Grandmother, then just grind the
shape out of hardwood or cast a shape using concrete, anneal the aluminium
(marker pen ,heat till gone , no more) Then beat with copper drift and
hammer.
Don't practice too much, you'll get a saw arm!
Cheers Cam.
Art is in the eye of the beholder.
"Blueskies" wrote in message
.com...
Thanks all!
Dan D.
Old February 24th 04, 03:42 PM
Bob Kuykendall
I'd suggest a visit to Kent White's Tin Man Technologies:
http://www.tinmantech.com
Thanks, and best regards
Bob K.
Old February 25th 04, 02:39 AM
Randy Tait
Check out Metalshaping.com All the kinds on metal working stuff.
Randy
Bob Kuykendall wrote in message
om...
Bob K.
Old February 25th 04, 02:40 AM
Blueskies
Excellent, thanks!
Dan D.
"Randy Tait" wrote in message ...
Randy
om...
Bob K.
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Working Stainless Steel Bob Babcock Home Built 7 February 14th 04 04:12 PM
New JAR-VLA certified all metal basic trainer and quick build KIT plane. marcin Home Built 0 October 13th 03 12:32 PM
Sheet metal shear/press brake VideoFlyer Home Built 7 October 7th 03 07:08 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
