New Bombardier-Rotax engines
Old October 17th 03, 05:41 AM
rgb
Default New Bombardier-Rotax engines
Take a look at those 2 new V piston engines :-)
http://www.vaircraftengines.com/en/theConcept.asp
Not bad ! I might call for prices :-)
Old October 17th 03, 02:51 PM
Mike Rapoport
They won't give them to you.
Mike
MU-2
"rgb" wrote in message
Old October 17th 03, 06:39 PM
rgb
Neither Lycoming or Continental do :-( too bad !
Mike
MU-2
Old October 17th 03, 03:49 PM
Big John
rgb
We've had aluminum auto engines without liners and as I recall they
had a pretty high cylinder failure rate?
If they have solved that problem with their 'electro-deposit' coating.
fine, but I sure wouldn't be the 'first one' to buy.
Think one of the problems is that any coating of the aluminum cylinder
expands at a different rate than the aluminum and this starts the
failure?
Should be some experts on aluminum engines around here on rah that can
give good technical advice about what they are trying to do and
expected results and longevity.
Big John
Old October 17th 03, 05:20 PM
Thomas Borchert
Big,
Can you explain further? Are the engine blocks aluminum on the
Bombardiers? That's quite common in the auto industry, isn't it? Also,
do you have the feeling anything could be much worse with regard to
premature cylinder problems than current TCM/Lycoming stuff?
Thomas Borchert (EDDH)
Old October 17th 03, 06:25 PM
Pepperoni
"Thomas Borchert" wrote in message
Big,
They appear to be coated aluminum cylinders. The problem that I see is that
the engines run up to 6000 rpm, and are geared 3:1. This makes for a lot of
piston (wear) strokes, and also the added possibility of gearbox problems.
The FADEC engine controls eliminate some control complexity, but more
problems seem folded back in with the liquid cooling.
I don't see a lot of folks standing in line to replace their current engines
until someone *else* runs a few to TBO and publishes cost and performance
analysis.
I think everyone is waiting for a bulletproof JP fueled diesel.
Old October 18th 03, 04:07 PM
Thomas Borchert
Pepperoni,
Based upon what? Are you an engine construction engineer specializing in
aluminum engines? Or is it just "gut feel"?
Not in cruise.
but more
Again: Says who? Liquid cooling seems to be a total non-issue with the
Rotaxes, the new diesels and engines in general.
Old October 18th 03, 06:04 PM
Pepperoni
Not in cruise.
Even in cruise, the engine will run much higher rpms than your "usual"
engines. Your current engine will run 1200 rpm to spin the output shaft at
1200rpm, the new engine will be running 3600rpm to spin the shaft at
1200rpm. If you don't believe *Me*, ask someone competent to do the math
for you.
but more
........ Liquid cooling seems to be a total non-issue with the
Liquid cooling does become an issue when you run out of coolant. A 2 gallon
reservoir is fine on a test stand with 3 techs standing around to keep an
eye on the run, but at night in the clouds or mountains, you will be
wondering how long it will take the engine to overheat and time to an
airport when a hose or gasket lets go.
Will an "engine in general" run for more than 30 minutes without coolant,
and would you bet your favorite coon dog's life on it?
Old October 17th 03, 06:46 PM
rgb
I don't know alot about engines :-/ I'm still a little private pilot who
rent plane ...
Some folks seems to be pretty please with there Rotax 912S so I was
thinking those 2 new engines might give Lycoming and Continental a
little challenge, maybe not ...
For what I can see thoses good old Lycomings are quiet good, but kindof
expensive .
Big John wrote:
rgb
failure?
Big John
Old October 17th 03, 10:45 PM
John Galban
rgb wrote in message ...
expensive .
Liquid cooling looks like it'll make it difficult to retrofit to
existing designs. I wouldn't be surprised to see a company like
Diamond modify one of their designs for it.
How they can run a 10.8 to 1 compression ratio on 87 octane gas is a
neat trick. I'm sure temp stabilization from liquid cooling helps,
but that still seems like a very high ratio for the low octane fuel.
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
Questions Rotax Engines Mark Smith Home Built 2 August 13th 04 11:01 PM
Jabiru and Rotax engines Marco Rispoli Home Built 14 July 16th 04 07:23 AM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
