Pitot heat
Old November 5th 03, 12:17 PM
Paul Mennen
Default Pitot heat
Just saw in this month's AOPA (Fall flights):
"Most pilots slumming around the pattern on a hot summer day
will probably not flip the pitot heat on, but certainly anytime
you're flying in or near moisture - at any air temperature - It's
safest to use pitot heat." - Editor in Chief, Thomas B. Haines.
Well that would cover at least half the time. Probably more if
one forgets to turn it off when the clouds finally slip out
of sight. Does this seem preposterous to anybody else?
Maybe its because my instructor covered up the airspeed indicator
of the J3 cub for an entire flight during my private training
just to make sure I wasn't becoming too dependent on it. Frankly
it didn't seem too hard to fly without it. Since the cub had no
stall warning system, I did use up more of the dirt patch next
to the runway than usual. (My instructor never actually let me
use the runway. He said that was too easy.) In the past 20 years
of flying my C185, I've flown without the airspeed indicator
several times. Twice it failed to work because of stuff in the
pitot tube. Once I just couldn't see it because there was no moon
and I had a total electrical system failure. (Actually I did have
a flashlight in my pocket, but I didn't see a great motivation
for getting it out. I just landed in the dark.) Twice I saw the
airspeed indicator rapidly head to zero because of icing conditions.
(My icing early warning system With constant power, pitch, and
altitude indications from the other instruments it never crossed
my mind to make any control inputs in response. Flipping the
pitot heater on restored the airspeed indicator within seconds.
(Well airspeed is at least a nice convenience.)
So Mr. Haines' suggestion seems somewhat radical to me. (Ok, I guess
I would use it in the cold soup when I'm already dealing with a loss
of vacuum system emergency.) Just think of all that power wasted.
And is really safer? Perhaps having it on so often would mean that it
would more likely be burnt out one of those few times it would be really
nice to have. And maybe it would snuff out that last 10 minutes of
battery capacity that you needed to complete your approach, because it
took you awhile to recognize that the alternator went belly up.
But he certainly has more experience than my meager 3000 hours,
so what do I know?
Reminds me of the instructions in the POH of my Decathlon that says I
should leave the electrical fuel pump on during takeoff because gravity
feed alone is not sufficient to produce takeoff power in the event the
engine driven fuel pump fails. Gosh, what are we - like the
monkeys on the early space missions. Can't we just turn on the
switch when we need it? (I've already replaced that very expensive
electrical pump twice because me or one of my partners forgot to turn
it off after climbout. It is not robust enough to run it continuously.
I've since given up on following the POH exactly.)
~Paul Mennen
Burning out the pitot heat? Mitty Instrument Flight Rules 3 December 30th 04 05:04 AM
28 volt pitot heat B2431 Home Built 15 April 17th 04 03:25 PM
pitot heat question K. Ari Krupnikov Instrument Flight Rules 7 December 11th 03 01:51 AM
Pitot heat Paul Mennen Owning 10 November 6th 03 09:54 AM
Pitot Heat Roger Long Piloting 12 November 6th 03 02:01 AM
