When Teflon burns it creates the same problems as PVC.
David D Cowell wrote: One good reason not to use it would be the PVC insulation. PVC when burned gives off toxic fumes. Not the kind of thing you want in the cockpit at altitude. I know you can't use PVC covered CAT 5 cable in common air passages/ductwork like above ceiling tile because of this. We use "plenum" cable that is Teflon coated I believe. -- David D Cowell Wildcat Computers, Inc. http://www.wildcatcomputers.net 800-686-4685 clare @ snyder.on .ca wrote in message ... I've come across a supply of wire at a reasonable price that I think I want to use to wire my plane. It is NOT aircraft wire, but I have all the spec on it. It is MTW (machine tool wire) AMW 1015/1230, FT1 and VM1 rated. The 18 guage is 16 strand. Insulation is PVC (not crosslinked) rated for -55 to 106C and 600 volts (1200 for electronics) Some also has TEW rating. It is wire designed for use in machine tool cabinets and appliances, and is oil and fuel resistant. Any reason not to use this? I have 3 colours of 18awg, 3 colours of 14awg, and 2 of 14awg. There is likely more available. It is non tinned wire. -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding While trying to find the time to finish mine. |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
Suitable coating for spring-steel wire? | Wright1902Glider | Home Built | 6 | February 9th 04 04:12 PM |
blue foam & cutting it | Richard Riley | Home Built | 6 | November 24th 03 01:53 PM |
Brace wire | Tom Mathes | Home Built | 5 | October 22nd 03 02:11 PM |
Tefzel Wire, RG400 Coax, Crimpers, Terminals, etc.. | Stein Bruch | Home Built | 0 | September 20th 03 04:35 AM |
