"Peter Duniho" writes:
[...] I have seen and heard of too many oil leaks, fuel leaks, rubbing tubes and various parts coming loose or falling off...all caused by "maitenance". Well, granted, the engines on your plane require a much more specialized maintenance crew than the one Lycoming on mine. But in spite of the very real possibility of human error during maintenance, as far as I know more engine failures are prevented by maintenance than are caused by it. I would be very surprised if you could find statistics to the contrary. I'm a Lycoming-running statistic (n=1). I "lost" an engine because the throttle cable came off months after the engine was replaced at annual. Fortunately I noticed it on the runup. But it happened the night before when I was dodging lightning on the approach to Durango. (I didn't notice it then because I rolled in just ahead of the hail and was more interested in getting under cover than parking perfectly.) I have way too many examples of mechanics screwing up my plane. --kyler |
"Kyler Laird" wrote in message
... I'm a Lycoming-running statistic (n=1). I "lost" an engine because the throttle cable came off months after the engine was replaced at annual. Fortunately I noticed it on the runup. An engine failure on the ground isn't an engine failure. ![]() Seriously though, that's the whole point of preflight inspections and runups. The only question here is what's more likely to cause an *in-flight* engine failure. Is it maintenance? Or lack of maintenance? I too have had a variety of "failures" (engine-related and otherwise), some of which were a direct result of work done on the airplane. Fortunately, none happened in flight. But the fact that a mechanic is falliable does not mean that the engine is better off without the mechanic. If any of you "mechanics are bad for my airplane!" folks actually have some hard numbers to show that airplanes not given any maintenance are more reliable than airplanes that have received maintenance, by all means, show it (I don't believe you can). Otherwise, you are taking a cute joke WAY too far. Pete |
"Kyler Laird" wrote in message ... I'm a Lycoming-running statistic (n=1). I "lost" an engine because the throttle cable came off months after the engine was replaced at annual. Fortunately I noticed it on the runup. An engine failure on the ground isn't an engine failure. ![]() Like I said, I lost it in flight. I noticed it on the ground. --kyler |
... Like I said, I lost it in flight. I noticed it on the ground. I think you're missing the point (even ignoring the apparent inconsistencies in the event you're trying to describe). Pete |
V-8 powered Seabee | Corky Scott | Home Built | 212 | October 2nd 04 11:45 PM |
Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 09:36 PM |
My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 01:41 PM |
Engine... Overhaul? / Replace? advice please | text news | Owning | 11 | February 17th 04 04:44 PM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
