Maybe this topic has been brought up here before, But do
homebuilt/experimental aircraft have to comply with Airworthiness Directives set forth by the FAA? specifically, I have a lycoming O-290G model engine in my airplane and since that engine was not designed for aircraft use, I wonder If I have to comply with AD's on it. Also, other accessories and/or avionics in my plane are not TSO'd so therefore I guess there would not be any AD's on those either. Its all a little confusing to me. Maybe someone can provide a quick answer that makes it clear. Thanks. |
On Wed, 31 Mar 2004 23:36:21 -0500, "moby" wrote:
Maybe this topic has been brought up here before, But do homebuilt/experimental aircraft have to comply with Airworthiness Directives set forth by the FAA? specifically, I have a lycoming O-290G model engine in my airplane and since that engine was not designed for aircraft use, I wonder If I have to comply with AD's on it. Also, other accessories and/or avionics in my plane are not TSO'd so therefore I guess there would not be any AD's on those either. Its all a little confusing to me. Maybe someone can provide a quick answer that makes it clear. No certification, no ADs. Short and clear enough? Ron Wanttaja |
The one caveat I can think of is if you use a certified engine to get the 25
hour fly off time vice 40 hour time I think you'd probably be held to the AD. John Ron Wanttaja wrote: On Wed, 31 Mar 2004 23:36:21 -0500, "moby" wrote: Maybe this topic has been brought up here before, But do homebuilt/experimental aircraft have to comply with Airworthiness Directives set forth by the FAA? specifically, I have a lycoming O-290G model engine in my airplane and since that engine was not designed for aircraft use, I wonder If I have to comply with AD's on it. Also, other accessories and/or avionics in my plane are not TSO'd so therefore I guess there would not be any AD's on those either. Its all a little confusing to me. Maybe someone can provide a quick answer that makes it clear. No certification, no ADs. Short and clear enough? Ron Wanttaja |
On Thu, 01 Apr 2004 07:44:33 +0000, jp wrote:
:The one caveat I can think of is if you use a certified engine to get the 25 :hour fly off time vice 40 hour time I think you'd probably be held to the :AD. :John I've heard the same thing (though the version I've heard was certified engine *and prop*) But I've gotten a 25 hour fly off with a non-certified, modified Lycoming and non-certified composite/wood prop. It looks like it's whatever your DAR is comfortable with. I comply with all the engine AD's I can, or at least take them as serious warnings. Not because they're required, just because they might be good ideas. |
Ron Wanttaja wrote in message . ..
On Wed, 31 Mar 2004 23:36:21 -0500, "moby" wrote: Maybe this topic has been brought up here before, But do homebuilt/experimental aircraft have to comply with Airworthiness Directives set forth by the FAA? specifically, I have a lycoming O-290G model engine in my airplane and since that engine was not designed for aircraft use, I wonder If I have to comply with AD's on it. Also, other accessories and/or avionics in my plane are not TSO'd so therefore I guess there would not be any AD's on those either. Its all a little confusing to me. Maybe someone can provide a quick answer that makes it clear. No certification, no ADs. Short and clear enough? Ron Wanttaja I would think that ADs against transceivers would apply, especially if the defect would put the transmission parameters outside legal limits. Ditto for ELTs. In Canada, there's an AD that forces ALL aircraft owners to pressure-check the exhaust system yearly or every 150 hours, whichever comes first, if the system is used for cabin heat. No exceptions. Dan |
Richard Riley wrote:
I've heard the same thing (though the version I've heard was certified engine *and prop*) Like you say, it's *supposed* to be 25 hours for a certified engine *and* *prop*, but there seem to be a lot of cases where a certified engine alone gets you 25 hours. I also know of at least one case where a non-certified engine got 25 hours. Like everything else, it depends on the inspector. Personaly, I can't imagine feeling done after 25 hours. I've got at least 50 hours planned, and that would apply regardless of what engine and prop I used...but I can see the utility of being able to leave the flight test area with less. I've got a certified engine (an O320-D2C, apparently THE O320-D2C) and experimental prop (Aymar-Demuth). I'm also slow as molasses and only have about 5 hours on the airplane so far. I comply with all the engine AD's I can, or at least take them as serious warnings. Not because they're required, just because they might be good ideas. Same here on all counts. Dave 'creeper' Hyde RV-4 Builder, EAA Tech counselor |
homebuilt/experimental aircraft have to comply with Airworthiness Directives set forth by the FAA? snip No certification, no ADs. Short and clear enough? True for an airframe or experimental engine. But if the aircraft uses any component such as an appliance or propeller or engine etc. then the AD's against that comoponent would apply even if the aircraft it experimental. Appliance ADs most often use a phrase such as "..is applicable on any aircraft certificated in any category... That would cover the experimental category. John Dupre' |
No certification, no ADs. Short and clear enough? Ron Wanttaja Short enough. Clear enough. But WRONG - at least according to my local FSDO. Background: Last year I ground looped my experimental (looks like a piper pacer, but it's an experimental). Attracting the attention of the local FSDO. Bad move. They went over my paperwork, and cited me for not complying with the AD's on my Slick Mag and lift struts. I pointed out the little passage in part 43 that says - er...what you just said... Their reply was that even experimentals are required to be "Airworthy". Since an "AD" is an "Airworthieness Directive", it is declaring the affected part "non-airworthy". Therefore I gotta fix it! You see their logic. I even agree with it. (I have replaced the struts). But it still ****es me off! Is there an appeals process? |
"Ron Webb" wrote in
: No certification, no ADs. Short and clear enough? Ron Wanttaja Short enough. Clear enough. But WRONG - at least according to my local FSDO. Background: Last year I ground looped my experimental (looks like a piper pacer, but it's an experimental). Attracting the attention of the local FSDO. Bad move. They went over my paperwork, and cited me for not complying with the AD's on my Slick Mag and lift struts. I pointed out the little passage in part 43 that says - er...what you just said... Their reply was that even experimentals are required to be "Airworthy". Since an "AD" is an "Airworthieness Directive", it is declaring the affected part "non-airworthy". Therefore I gotta fix it! You see their logic. I even agree with it. (I have replaced the struts). But it still ****es me off! Is there an appeals process? Very ridiculous, since if you had used struts off a 69 ford fairlane, you would have had no problem.... If this indeed ends up to be true, I will endevour to use ZERO certified parts on my experimental. -- ET ![]() "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
| Thread Tools | |
| Display Modes | |
| Crashing Experimental on America's Funniest Home Videos | Jay | Home Built | 7 | March 10th 04 01:11 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 10:02 PM |
| Ultralight and Experimental aircraft pilots in Central Florida | Gilan | Home Built | 1 | December 12th 03 09:09 PM |
| A couple Questions-Ramp Checks and Experimental Operations | Badwater Bill | Home Built | 48 | October 8th 03 10:11 PM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
