Dear Bill (and the Group),
This isn't an answer to your questions. But maybe it is, in a way. When designing an optimized tube-frame structure such as a rocket mount or off-shore drilling platform you are allowed to let the task drive the properties of the material in that you can spec whatever alloy, diameter and wall-thicness that might be required. The assumption here is that the budget is large enough to allow you to let contracts to have the materials made to your specs. (Don't laugh. It got us to the moon & back.) But when applying the new software (ie, circa 1960's) to more mundane tasks, such as the engine mount for an R-2800... or the fuselage of a Formula One airplane, you were forced to use the materials that were commonly available. Then you ran into an interesting problem with tooling costs and fabrication skills, interesting in that in most cases, implementing your new, computer optimized structure will cost millions of dollars and several years, since it dictates the need for new jigs & fixtures, different welding & inspection procedures and retraining your work-force. Bottom line is that with an existing structure any benefit of structural optimization usual fails the Practical Factors test. Starting from scratch? Then that's a different story and there are some nice examples of steel-tube airframes, including square & rectangular tubing (!) that have taken full advantage of computer-aided design, MIG welding (it's faster) and so on. When applied to home-building I suggest you turn the equation around. Use CAD&D to come up with a welded tube structure that uses the LEAST number of different diameters and wall-thicknesses as well as the least amount overall, combined in a structure optimized for unskilled weldors working without elaborate jigs & fixtures. This speaks directly to the Practical Factors of one-off, home-built construction, the most critical of which is cost. The answer to your questions can be found in any number of airplanes flying today. Unfortunately, they start at about $100k and go up. Alas, such airplanes and the attention devoted to them virtually guarantee the demise of grass roots aviation in America. -R.S.Hoover |
Mr Hoover
Another good/interesting point by you as always and I "grok" what your saying.... Let me take another stab at this.... Take some "typical" rag and tube design that your "cost challenged" homebuilders are building these days with minimal tools and skills.... Most likely (IMHO) it is of a design that was not computer optimized....somebody long ago probably just eyeball/rule of thumb/comparision with previous successful designs engineered it till it seemed light enough, simple enough, and when given the static loads it was likely to encounter it didnt break.....at which point the designer said "praise the lord" and moved on to other tasks.... Now, take THAT design, and do the modeling (of course the modeler needs to KNOW what they are doing).... Look at the computer results....the model might show some areas that have ALOT of stress.....which at the very least tells the builder "make sure THOSE welds are damn good"....... or the model might show some tubes are under very low tension compared to its strength .....so you realize you can spec out those tubes one or two standard sizes down in diameter/thickness.....without any penalties Or the model might show an area prone to buckling which when fixed with an extra brace adds only a little weight to the overall structure but makes the entire structure significanty stronger (ie high rewards to cost ratio there)... Or by playing with the model you might find out that you can leave out this tube here, that tube there, and those over yonder and you've lost little or nothing in the strength of the design..... I understand what your saying about the big projects....you optimize the design in a biggggg way and then special material or sizes are no big deal..... I'm asking/proposing the opposite....take a standard design....and see if you can tweak it and still use standard materials and parts....and with a little luck you might end up with something that is a bit lighter or stronger or if you are really lucky has a lower part count.... The good thing about that kinda project is the only thing its gonna cost you is your computer time (assuming your using free software).... Just some wonderings on my part.... take care Blll |
I remember using one of the first finite element programs outside of the
aerospace industry. Back then, you did not have a nifty program to create all the "bricks" something was made up of. You had to define each node in three dimensions -- and then define the end conditions at each node in 9 ways (3 for each dimension). Took a lot of work. Then it was sent by telephone to St. Louis (to McDonnell-Douglas I believe) for processing. The results were sent back by telephone in one or two days. No graphs. No colors. Just numbers. The last finite element program I used was on a PC about 10 years ago. Much easier. As you may have guessed by now, I am a registered structural engineer. Anyway, to get back to your question, it depends. I have run some tube and fabric designs through finite element analysis. If you were to check the Tailwind design, you will not find ANY reductions in tube size or thickness. You will undoubtedly find some suggested tube increases. I checked the design on one of the later programs and also built a Tailwind airframe. I believe that he probably used every tube size and wall thickness there is available in that design. There are little itty-bitty tubes branching all over the place. I know Steve's design has a long history of troublefree use, so I would be suspicious of the finite element model. I did not have the inclination or time to refine the model any more. If you were to check just about any of the EAA airplanes (such as the EAA Biplane or the EAA Acro Sport), you will find many reductions in size or thickness. I believe that the Poberezny designed airplanes were made "hell-for-stout" for beginners and also to minimize the number of different tube sizes needed. BTW, I looked carefully at the designs for these, but did not do an analysis of them. I doubt that optimizing the EAA airframes (metal tubes only) would cut more than 10 pounds from them. If you were to race airplanes (like Wittman did), any improvement would be worth the work. If you don't, is it really that important? Each designer decides that himself. "BllFs6" wrote in message ... Mr Hoover Another good/interesting point by you as always and I "grok" what your saying.... snip Just some wonderings on my part.... take care Blll |
On Wed, 7 Apr 2004 18:29:03 -0500, "Harry O" wrote:
Anyway, to get back to your question, it depends. I have run some tube and fabric designs through finite element analysis. If you were to check the Tailwind design, you will not find ANY reductions in tube size or thickness. You will undoubtedly find some suggested tube increases. I checked the design on one of the later programs and also built a Tailwind airframe. I believe that he probably used every tube size and wall thickness there is available in that design. There are little itty-bitty tubes branching all It is interesting to look at the airframe of the nesmith cougar and the w8 tailwind together. as you say the wittman uses the one tube for each longeron. the nesmith steps down in diameter at every cluster. the tailwind looks to be about half the fiddle factor of the nesmith. in australia there was an eyeball designed high wing tube and fabric that was in the run up to production when it hit airworthiness snags. the CASA engineer determined (it I recall the secondhand info correctly) that in areas of the fuselage it did not have sufficient margins of strength. stress checking was then done (dont know what method was used) to correctly match the tube sizes to the loads. the second iteration of the design then went into production. design as I recall was a knock off clone of an avid flyer or a kitfox but I cant recall the design's name. so yes there is an instance where a design was optimised by structural evaluation after initial design. TLAR only gets it correct is the eye is exceptionally practised. (tlar - that looks about right) Stealth Pilot Australia |
I have never seen the plans for the Nesmith Cougar, but I pulled out my old
set of plans for the Wittman Tailwind to check tube sizes. BTW, in talking with Mr. Wittman, I quickly learned that you don't even mention the Cougar. He was very sensitive about someone who wasted a lot of his time asking questions, then stole his design, and then ruined it with bad modifications. Anyway, there were 22 different sizes and/or wall thickness of tubing listed in the Tailwind plans. That is a lot more than I remember seeing in the plans for the others I mentioned. The did step down the further back they got. I doubt that anyone ever did a stress analysis for the Tailwind (at least before it was built) and it was done by "eyeball". However, I have a lot more faith in Mr. Wittmans eyeball than the numbers from some structural engineers I know. Another off-topic comment about the Tailwind. I talked to Steve Wittman several times. One time was about the engine. I bought a Lycoming 0-290-D2. He looked down on that. He used an "85hp" Continental at the time. Much lighter and delivered as much power (?). I asked about the pitch of the propeller and the speeds he was getting. They did not match. I talked to him again. I found out that he was running the little engine at about 3,200rpm. Way, way over the manufacturers "redline". The propeller pitch and speeds he was getting matched at the higher rpm. He did say that he only got about 400 hours from the engine between rebuilds, though. Since he did them himself, he did not think that was much of a problem. No doubt he balanced and blueprinted the engines, too. "Stealth Pilot" wrote in message ... On Wed, 7 Apr 2004 18:29:03 -0500, "Harry O" wrote: Anyway, to get back to your question, it depends. I have run some tube and fabric designs through finite element analysis. If you were to check the Tailwind design, you will not find ANY reductions in tube size or thickness. You will undoubtedly find some suggested tube increases. I checked the design on one of the later programs and also built a Tailwind airframe. I believe that he probably used every tube size and wall thickness there is available in that design. There are little itty-bitty tubes branching all It is interesting to look at the airframe of the nesmith cougar and the w8 tailwind together. as you say the wittman uses the one tube for each longeron. the nesmith steps down in diameter at every cluster. the tailwind looks to be about half the fiddle factor of the nesmith. Stealth Pilot Australia |
Steve did more than just "eyeball" engineering. He had some contacts at the
University of Wisconsin that he sent his drawings and parts down to have them analyzed. "Harry O" wrote in message ... I have never seen the plans for the Nesmith Cougar, but I pulled out my old set of plans for the Wittman Tailwind to check tube sizes. BTW, in talking with Mr. Wittman, I quickly learned that you don't even mention the Cougar. He was very sensitive about someone who wasted a lot of his time asking questions, then stole his design, and then ruined it with bad modifications. Anyway, there were 22 different sizes and/or wall thickness of tubing listed in the Tailwind plans. That is a lot more than I remember seeing in the plans for the others I mentioned. The did step down the further back they got. I doubt that anyone ever did a stress analysis for the Tailwind (at least before it was built) and it was done by "eyeball". However, I have a lot more faith in Mr. Wittmans eyeball than the numbers from some structural engineers I know. Another off-topic comment about the Tailwind. I talked to Steve Wittman several times. One time was about the engine. I bought a Lycoming 0-290-D2. He looked down on that. He used an "85hp" Continental at the time. Much lighter and delivered as much power (?). I asked about the pitch of the propeller and the speeds he was getting. They did not match. I talked to him again. I found out that he was running the little engine at about 3,200rpm. Way, way over the manufacturers "redline". The propeller pitch and speeds he was getting matched at the higher rpm. He did say that he only got about 400 hours from the engine between rebuilds, though. Since he did them himself, he did not think that was much of a problem. No doubt he balanced and blueprinted the engines, too. "Stealth Pilot" wrote in message ... On Wed, 7 Apr 2004 18:29:03 -0500, "Harry O" wrote: Anyway, to get back to your question, it depends. I have run some tube and fabric designs through finite element analysis. If you were to check the Tailwind design, you will not find ANY reductions in tube size or thickness. You will undoubtedly find some suggested tube increases. I checked the design on one of the later programs and also built a Tailwind airframe. I believe that he probably used every tube size and wall thickness there is available in that design. There are little itty-bitty tubes branching all It is interesting to look at the airframe of the nesmith cougar and the w8 tailwind together. as you say the wittman uses the one tube for each longeron. the nesmith steps down in diameter at every cluster. the tailwind looks to be about half the fiddle factor of the nesmith. Stealth Pilot Australia |
Steve said that. However, he also said that it was done many years after
the plans were first offered for sale. I believe it was about the time he changed it from the W-8 to the W-10. There were a few tube sizes that were increased in size then, particularly at the top, front of the cabin to carry the spar loads. Of course, it was because of the heavier Lycoming engines being used rather than from failures. "Cy Galley" wrote in message news:1uJdc.117$xn4.5040@attbi_s51... Steve did more than just "eyeball" engineering. He had some contacts at the University of Wisconsin that he sent his drawings and parts down to have them analyzed. |
![]() "Stealth Pilot" wrote in message .. TLAR only gets it correct is the eye is exceptionally practised. (tlar - that looks about right) Stealth Pilot Australia I do love TLAR, but where does one find figures needed for things like downforce required by the tail, gust factor loadings, lft distributions for varios airfoios and configurations, ect? -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.651 / Virus Database: 417 - Release Date: 4/5/2004 |
Morgans wrote:
"Stealth Pilot" wrote in message . TLAR only gets it correct is the eye is exceptionally practised. (tlar - that looks about right) Stealth Pilot Australia I do love TLAR, but where does one find figures needed for things like downforce required by the tail, gust factor loadings, lft distributions for varios airfoios and configurations, ect? -- Jim in NC It's all in the numbers, Jim. Your teachers always told that math would come in handy someday. Well, take tail loads? We start with the wing airfoil performance curves. One curve plots section lift at any given angle of attack. One curve plots section drag " Back in the slide rule days the third curve represents "center of pressure" location (again, per angle of attack but expressed in percent chord. i.e.: where the summed center of the pressure field is in relation to the section chord. Makes an easy model to visualize what's happening. Now days, the third curve is the Coefficient of Moment, or the rotational force the airfoil generates at that angle of attack. No as touchy feely, but I gotta admit that the coefficient method is easier to calculate with. Next, there is the CG question. For a pitch stable airplane, the center of lift will be behind the center of gravity. If you visualize this, the nose falls. A down load on the tail lifts the nose. How much down load? Just enough to bring the nose back level. Knowing where the CG and CL are physically located we also know the distance between them (the Arm). For straight and level flight, we know the lift (equal to weight). So we can do a little arithmetic and find the pitch moment for our hypothetical airframe. (We'll skip the airfoil CM for now, ok? The CG/CP moment is by far the greater issue of the two. But in reality ALL moments get included.) So, take that pitching moment and divide it by the Tail Arm (distance from CG to elevator?) to find out what the load on the tail will be (pounds). It's really fairly simple arithmetic so far. The biggest surprise is how small the actual control loads are. Some 10 feet back to the elevator makes a very long Arm. Ten pounds back here can have more impact on CG location than 100 pounds in the back seat. In fact, it better, or the back seat might be the way wrong place! Bounds checking shows that many airfoils have a higher CM at higher AOA. I think that implies that at low speeds, tail loads are actually higher? Why? More force is needed on the tail to hold the nose up that high. :^) At higher speeds the CM is generally lower because the AOA is lower. Ok, too many blank looks again... Visualize it this way? At high AOA the center of pressure is generally forward some. The air is attached to the front third of the wing (or less?), so the lift force is transferred to the wing in that area only. (drag too) As the AOA comes down (and speed is higher to make same lift) the center of pressure is "blown" aft. (?) It just makes an easy mental image to help remember how it all\ fits together. So a steep CM curve (old style) or a larger range of CM values indicate an airfoil with an active center of pressure. (also ?) As for the other specific things you mentioned? Lift distribution is more of a plan form thing but there are other considerations as well. One aspect is the planform shape. Rectangle (Hershey Bar), Elliptical? Delta Another aspect is wing twist. Twisting the tips down makes less lift at the tips. Take a rectangular wing and wash the tips down a bit and you get can a nice elliptical lift distribution from a Hershey bar. Do the same thing to an elliptical plan form and it might not even fly. (washed the lift right off the back of the wing!) I'm still working on gust loads... They are described as so many feet per second of gust but I have trouble wrapping that up neatly. My best guess for a reasonable approximation is this... Do a vector diagram with the airplane's forward speed (in fps) on the X axis, and the gust vector pointing doen (vertical at xxx fps) and note the angle of the resultant. Go back to the airfoil performance data and recalculate how much lift will be generated at that speed if the AOA suddenly increased by that angle. Divide that lift number by the flying weight to get the G load that would be imposed. There is a lot more to it, of course. More than I know for sure. But it's a start. Richard |
