On Thu, 08 Apr 2004 20:01:51 +0000, Ernest Christley wrote:
Most of the fabric covered aiplanes I've seen didn't seem that hard. That is, you could walk up to them and push the fabric in with your hand. The way I understand the fabric process, it is basically a composite structure. You have a nylon cloth with a paint "epoxy". Could a much stronger and lighter covering be made by wetting out some 2.5oz glass cloth on plastic, waiting till it's tacky and then wrapping it around the airframe? The epoxy would be much lighter than paint, and fiberglass cloth is MUCH stronger than nylon. I've seen some places where builders used composites in place of fabric, and it seemed that they all aimed for a multlayer, stiff panel, putting the weight far above the original. I just don't understand why? The fabric must be quite taut so that the external surface of the aircraft maintains the correct shape, even when subjected to the force of the airflow. How would you achieve this with fibreglas without having excessive weight? -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ e-mail: khorton02(_at_)rogers(_dot_)com |
Fabric covering processes | Jerry Guy | Home Built | 2 | January 29th 04 06:49 PM |
Fabric Work | Doug | Home Built | 9 | January 26th 04 03:31 AM |
fabric and tube by the ocean. | Ed Bryant | Home Built | 5 | December 6th 03 07:00 PM |
Soliciting Testimonials on Covering Systems | Larry Smith | Home Built | 5 | August 18th 03 09:24 AM |
Glass Goose | Dr Bach | Home Built | 1 | August 3rd 03 05:51 AM |
