If a window blows out, everything that is not tied down will certainly be sucked out, and this could include people if they were small enough. Its my understanding that in an explosive decompression like this, the decompression will happen very fast. The Goldfinger episode goes on for 45 minutes of hanging on for dear life while the plane depressurizes. My un-educated guess is that this would happen in seconds or less. |
"Jeff Franks" wrote in message ... If a window blows out, everything that is not tied down will certainly be sucked out, and this could include people if they were small enough. Its my understanding that in an explosive decompression like this, the decompression will happen very fast. The Goldfinger episode goes on for 45 minutes of hanging on for dear life while the plane depressurizes. My un-educated guess is that this would happen in seconds or less. Witnessed the result of "Port Hole Window" on the starboard side of a C-5 blowing out during "Initial Factory Pressure checks" on a new C-5". The window itself went through the side of a "Tin Sided Building" ~ 200' from where the window/port hole came from. A substantial number of the insulation/batting blankets were torn from their normal place in the cargo bay & piled on the cargo bay floor near the opening. A large number of the insulation blankets/bats, along with seat cushions from the upper aft troop compartment were piled around the entrance to the stairs from the troop compartment down to the cargo bay, plus scattered along the cargo bay floor in the direction of the failed port hole/window. Seat cushions, mattresses from bunks, & insulation bats/blankets from the upper front area were piled against the exit stairs from the upper from lobe & along the cargo bay floor toward the failed port hole/window. A few of the insulation bats/blankets were blown out the failed port hole/window. A/C being tested were instrumented to record/document test protocols as appropriate. According to instrumentation on the A/C, at time of port hole/window failure the air pressure dropped from 14.5 lbs to 0 in .003 seconds. Factory Pressure Check on C-5's was 15 pounds, slightly over 1 atmosphere. This was worked up to in stages. This incident occurred. Ralph Nesbitt Professional FD/CFR/ARFF Type |
"Ralph Nesbitt" wrote in message m... "Jeff Franks" wrote in message ... Witnessed the result of "Port Hole Window" on the starboard side of a C-5 blowing out during "Initial Factory Pressure checks" on a new C-5". The window itself went through the side of a "Tin Sided Building" ~ 200' from where the window/port hole came from. A substantial number of the insulation/batting blankets were torn from their normal place in the cargo bay & piled on the cargo bay floor near the opening. A large number of the insulation blankets/bats, along with seat cushions from the upper aft troop compartment were piled around the entrance to the stairs from the troop compartment down to the cargo bay, plus scattered along the cargo bay floor in the direction of the failed port hole/window. Seat cushions, mattresses from bunks, & insulation bats/blankets from the upper front area were piled against the exit stairs from the upper from lobe & along the cargo bay floor toward the failed port hole/window. A few of the insulation bats/blankets were blown out the failed port hole/window. A/C being tested were instrumented to record/document test protocols as appropriate. According to instrumentation on the A/C, at time of port hole/window failure the air pressure dropped from 14.5 lbs to 0 in .003 seconds. Factory Pressure Check on C-5's was 15 pounds, slightly over 1 atmosphere. This was worked up to in stages. This incident occurred. Ralph Nesbitt Professional FD/CFR/ARFF Type This is not the same situation. First the preasurization was set to twice what it will be in flight. Second the preasure dropped because the engines were not pumping air in. Take a bicycle tire pump it up to 8psi (almost flat) and then let the air out. This it the same preasure differential. Mike MU-2 |
"Mike Rapoport" wrote in message link.net... "Ralph Nesbitt" wrote in message m... "Jeff Franks" wrote in message ... Witnessed the result of "Port Hole Window" on the starboard side of a C-5 blowing out during "Initial Factory Pressure checks" on a new C-5". The window itself went through the side of a "Tin Sided Building" ~ 200' from where the window/port hole came from. A substantial number of the insulation/batting blankets were torn from their normal place in the cargo bay & piled on the cargo bay floor near the opening. A large number of the insulation blankets/bats, along with seat cushions from the upper aft troop compartment were piled around the entrance to the stairs from the troop compartment down to the cargo bay, plus scattered along the cargo bay floor in the direction of the failed port hole/window. Seat cushions, mattresses from bunks, & insulation bats/blankets from the upper front area were piled against the exit stairs from the upper from lobe & along the cargo bay floor toward the failed port hole/window. A few of the insulation bats/blankets were blown out the failed port hole/window. A/C being tested were instrumented to record/document test protocols as appropriate. According to instrumentation on the A/C, at time of port hole/window failure the air pressure dropped from 14.5 lbs to 0 in .003 seconds. Factory Pressure Check on C-5's was 15 pounds, slightly over 1 atmosphere. This was worked up to in stages. This incident occurred. Ralph Nesbitt Professional FD/CFR/ARFF Type This is not the same situation. First the preasurization was set to twice what it will be in flight. Second the preasure dropped because the engines were not pumping air in. Take a bicycle tire pump it up to 8psi (almost flat) and then let the air out. This it the same preasure differential. Mike MU-2 Agreed. The purpose of the pressure test in question is to assure structural pressure integrity to 1 atmosphere above AGSL. Hopefully all realize when referring to "Air Pressure" at altitude this is an "absolute" pressure value inside the fuselage irrespective of ambient. When referring to air pressures at ground level the pressure reading is above unadjusted ambient barometric pressure. A/C pressure systems are set to operate from departure point. If set manually from info provided by ATC this is "Unadjusted Barometric Presser" read from an instrument at the base of the Tower, a specified height above the ramp. Most modern commercial A/C are equipped with automatic systems that capture relevant data upon command/that is reset for each flight. Ralph Nesbitt Professional FD/CFR/ARFF Type |
"Ralph Nesbitt" wrote in message m... Hopefully all realize when referring to "Air Pressure" at altitude this is an "absolute" pressure value inside the fuselage irrespective of ambient. When referring to air pressures at ground level the pressure reading is above unadjusted ambient barometric pressure. This is incorrect, pressurization is the differential between ambient and cabin preasure. Mike MU-2 A/C pressure systems are set to operate from departure point. If set manually from info provided by ATC this is "Unadjusted Barometric Presser" read from an instrument at the base of the Tower, a specified height above the ramp. Most modern commercial A/C are equipped with automatic systems that capture relevant data upon command/that is reset for each flight. Ralph Nesbitt Professional FD/CFR/ARFF Type |
"Mike Rapoport" wrote in message hlink.net... "Ralph Nesbitt" wrote in message m... Hopefully all realize when referring to "Air Pressure" at altitude this is an "absolute" pressure value inside the fuselage irrespective of ambient. When referring to air pressures at ground level the pressure reading is above unadjusted ambient barometric pressure. This is incorrect, pressurization is the differential between ambient and cabin preasure. Mike MU-2 Please reconsider your statement above as it applies to pressurization of A/C cabins at altitude. At altitude A/C cabins are like a pressure vessel. A/C cabins are pressurized to maintain ~ 12 PSI Gauge, ~ the same as normal atmospheric pressure @ 11,000' ASL, in the cabin irrespective of altitude above 11,000' ASL. Ralph Nesbitt Professional FD/CFR/ARFF Type A/C pressure systems are set to operate from departure point. If set manually from info provided by ATC this is "Unadjusted Barometric Presser" read from an instrument at the base of the Tower, a specified height above the ramp. Most modern commercial A/C are equipped with automatic systems that capture relevant data upon command/that is reset for each flight. Ralph Nesbitt Professional FD/CFR/ARFF Type |
"Ralph Nesbitt" wrote in message gy.com... At altitude A/C cabins are like a pressure vessel. A/C cabins are pressurized to maintain ~ 12 PSI Gauge, ~ the same as normal atmospheric pressure @ 11,000' ASL, in the cabin irrespective of altitude above 11,000' Actually, 8,000' (at least in US certificated transports). |
"Ralph Nesbitt" wrote in message gy.com... "Mike Rapoport" wrote in message hlink.net... "Ralph Nesbitt" wrote in message m... Hopefully all realize when referring to "Air Pressure" at altitude this is an "absolute" pressure value inside the fuselage irrespective of ambient. When referring to air pressures at ground level the pressure reading is above unadjusted ambient barometric pressure. This is incorrect, pressurization is the differential between ambient and cabin preasure. Mike MU-2 Please reconsider your statement above as it applies to pressurization of A/C cabins at altitude. At altitude A/C cabins are like a pressure vessel. A/C cabins are pressurized to maintain ~ 12 PSI Gauge, ~ the same as normal atmospheric pressure @ 11,000' ASL, in the cabin irrespective of altitude above 11,000' ASL. Ralph Nesbitt Professional FD/CFR/ARFF Type No, the cabin is not at a constant preasure above 11,000' (and the number that you are looking for is 8,000') unless the rate controller is set to a rate greater than the climb rate of the aircraft (which is never done). If what you say were true then the cabin altitude would not climb with the airplane above 11,000' (8,000') which it clearly does. If you doubt this, go buy an altimeter watch and see for yourself. Or you could buy a pressurized airplane. Mike MU-2 |
Hopefully all realize when referring to "Air Pressure" at altitude this is an "absolute" pressure value inside the fuselage irrespective of ambient. When referring to air pressures at ground level the pressure reading is above unadjusted ambient barometric pressure. In the Boeing aircraft that I flew (B-727,B-707,B-720) there were two gages on the FE's panel. One was a simple altimeter that indicated the cabin altitude at all times and the other, a differential pressure gage that indicated the difference in pressure between outside and inside. The maximum differential for those aircraft was around 8.6 psi. The only way to determine the absolute pressure inside the aircraft would be to use a graph to convert the altimeter indication to pressure. Bob Moore |
"Robert Moore" wrote in message ... "Ralph Nesbitt" wrote Hopefully all realize when referring to "Air Pressure" at altitude this is an "absolute" pressure value inside the fuselage irrespective of ambient. When referring to air pressures at ground level the pressure reading is above unadjusted ambient barometric pressure. In the Boeing aircraft that I flew (B-727,B-707,B-720) there were two gages on the FE's panel. One was a simple altimeter that indicated the cabin altitude at all times and the other, a differential pressure gage that indicated the difference in pressure between outside and inside. The maximum differential for those aircraft was around 8.6 psi. The only way to determine the absolute pressure inside the aircraft would be to use a graph to convert the altimeter indication to pressure. Bob Moore The protocols you reiterate above will translate to a ~ constant pressure of 12 PSI Gauge inside the cabin as the A/C moves through it's flight profile above ~ 11,000'. Ralph Nesbitt Professional FD/CFR/ARFF Type |
| Thread Tools | |
| Display Modes | |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 06:26 PM |
| Invest small Earn Large ($20 000+) | promethean | General Aviation | 0 | October 3rd 03 07:08 AM |
| Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 05:00 PM |
