"BTIZ" wrote in message:
There are aircraft currently flying that qualify as a "light sport"..that fit just fine in the standard traffic pattern.. Agreed, but there will also be sport aircraft with approach speeds as low as 25 knots. At some point, the speed differential between aircraft in the pattern should become a concern. I see the potential for doubling the speed differential between aircraft at the extreme ends of the spectrum and I think this should be a concern. But I'm open to anyone that can show how an increase in speed differential won't increase the risk. I don't like the idea of a "lower altitude pattern" for a LiteSportAircraft, that may have a high wing, and the "regular" low wing ASEL aircraft above him. We have enough problems with Cessna's and Pipers mixing it up on final as is.. at least one or two a year.. and they "fly the same pattern" supposedly. I've never liked the idea of putting different aircraft with different performance at different pattern altitudes either (e.g. singles at 1,000 AGL and twins at 1,500 AGL). I can see how it would prevent faster aircraft from overrunning slower aircraft, but, from what I've read, mid-airs in the pattern are more typically the result of climbing/descending into blind spots. Perhaps different pattern altitudes based on aircraft wing position would work better, i.e., high wings fly a 1,500-foot pattern and low wings fly a 1,000-foot pattern. That still leaves other problems (where do biplanes fit in, for instance), but it might be better than the current situation. |
There are aircraft currently flying that qualify as a "light sport"..that fit just fine in the standard traffic pattern.. Agreed, but there will also be sport aircraft with approach speeds as low as 25 knots. At some point, the speed differential between aircraft in the pattern should become a concern. Agreed.. isn't that why they created an "Ultra light" pattern.. so if you are that slow.. fly the ultra light pattern.. if you can keep up with a J-3.. fly the regular pattern... and as for the SEL and MEL differences at some patterns.. I agree there can be problems... and "at most times but not always".. the MEL pattern if higher is also out farther from the runway so he can see the SEL downwind and base. BT |
Absolutely right, BT. At airports that have space for a separate
ultralight pattern and runway (typically grass), I think it is an ideal solution. But there are airports that don't have this luxury and all aircraft have to share the same runway. Putting the ultralights on the "inside and lower" from the regular (SEL) traffic pattern, which may be "inside and lower" the MEL puts the burden for see and avoid on the faster aircraft. As you point out, the MEL pattern is outside and above the SEL pattern so the MEL guy can see the SEL on downwind and base. However, the SEL will have a great deal of difficulty seeing the MEL that is overtaking him. Likewise, the ultralights will have difficulty seeing any SEL or MEL that are overtaking them. Is this system really the best way to minimize the risk in the traffic pattern? "BTIZ" wrote in message news:cqgUb.7670$IF1.5507@fed1read01... "BTIZ" wrote in message: There are aircraft currently flying that qualify as a "light sport"..that fit just fine in the standard traffic pattern.. Agreed, but there will also be sport aircraft with approach speeds as low as 25 knots. At some point, the speed differential between aircraft in the pattern should become a concern. Agreed.. isn't that why they created an "Ultra light" pattern.. so if you are that slow.. fly the ultra light pattern.. if you can keep up with a J-3.. fly the regular pattern... and as for the SEL and MEL differences at some patterns.. I agree there can be problems... and "at most times but not always".. the MEL pattern if higher is also out farther from the runway so he can see the SEL downwind and base. BT |
![]() "Ace Pilot" wrote in message om... But there are airports that don't have this luxury and all aircraft have to share the same runway. Putting the ultralights on the "inside and lower" from the regular (SEL) traffic pattern, which may be "inside and lower" the MEL puts the burden for see and avoid on the faster aircraft. Back when our airport had a fairly active ultralight activity. They flew the opposite pattern, obviously lower and tighter than the regular pattern. It was quite easy as a result for them to adjust on base leg to fit into the higher performance traffic. |
"Ron Natalie" wrote in message ...
"Ace Pilot" wrote in message om... But there are airports that don't have this luxury and all aircraft have to share the same runway. Putting the ultralights on the "inside and lower" from the regular (SEL) traffic pattern, which may be "inside and lower" the MEL puts the burden for see and avoid on the faster aircraft. Back when our airport had a fairly active ultralight activity. They flew the opposite pattern, obviously lower and tighter than the regular pattern. It was quite easy as a result for them to adjust on base leg to fit into the higher performance traffic. This sounds interesting. If I understand you correctly, everyone used the same runway, but higher performance aircraft flew a left-hand pattern while ultralights flew a right-hand pattern (or vice versa). This is contrary to what AC 90-66A suggests, i.e., different size and altitude patterns on the same side of the runway. Was there something that prevented the airport from following the 90-66A recommendation, or was this procedure deemed safer than what 90-66A recommended? I can see some of the advantages. While on downwind and base, traffic with significantly different speeds is more likely forward of you, enabling everyone to better see and avoid the traffic that is of most concern. Having different sized patterns on opposite sides of the runway means that traffic that overshoots final isn't flying head on into the other pattern's base leg traffic. Were there any disadvantages with this procedure? How was knowledge of this procedure disseminated? Thanks for the input, Ron. |
![]() Ace Pilot wrote: Were there any disadvantages with this procedure? How was knowledge of this procedure disseminated? Thanks for the input, Ron. One disadvantage is the fact that aircraft on the base leg of a reverse-direction pattern can't be seen by high-wing aircraft waiting at the runway. Couple that with a circling approach from 300' AGL, and you've got real problems. I was almost nailed on my solo flight by some A**hole doing this in a Breezy. Fortunately, a CFI flying the usual pattern with a student heard me announce departure and got on the radio. I was halfway out on the runway before I got stopped, though. His wheels were below the level of my instrument panel when he went by. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
"G.R. Patterson III" wrote in message
... One disadvantage is the fact that aircraft on the base leg of a reverse-direction pattern can't be seen by high-wing aircraft waiting at the runway. Huh? Left or right patterns are not chosen for the convenience of those waiting at the runway. At most airports, the pattern is all left turns or all right turns, and there is only one taxiway to the runway. There is almost always the potential for a high-wing airplane to not be able to see traffic on base leg without turning the airplane prior to entering the runway. This has nothing to do with having a "reverse-direction pattern". You can NEVER count on there not being an aircraft on base leg behind you as you enter the runway. That's why I ALWAYS turn the airplane so that I can see the base leg behind me, whichever base leg that is and whether or not it's part of the usual pattern, before I enter the runway. [...] I was halfway out on the runway before I got stopped, though. His wheels were below the level of my instrument panel when he went by. Sounds to me like you both screwed up. Before wandering onto the runway, you should've positioned your airplane so you could see traffic approaching the runway, and he should have gone around when you violated his right-of-way as landing traffic. Pete |
![]() "G.R. Patterson III" wrote in message ... One disadvantage is the fact that aircraft on the base leg of a reverse-direction pattern can't be seen by high-wing aircraft waiting at the runway Not at our field. The aircraft at the hold line actually has his back to his OWN base leg. He's looking at the ultralight base leg. You've got to turn towards final before you leave anyhow (or in the Navion slide the canopy back so you can see 360 degrees). |
![]() "G.R. Patterson III" wrote in message ... Ace Pilot wrote: Were there any disadvantages with this procedure? How was knowledge of this procedure disseminated? Thanks for the input, Ron. One disadvantage is the fact that aircraft on the base leg of a reverse-direction pattern can't be seen by high-wing aircraft waiting at the runway. I don't understand. I fly a high wing and have never had a problem seeing base leg traffic no matter the runway/taxiway configuration or traffic direction. The old 360 before taking the runway allows one to see all traffic no matter where it is coming from. Couple that with a circling approach from 300' AGL, and you've got real problems. I was almost nailed on my solo flight by some A**hole doing this in a Breezy. Fortunately, a CFI flying the usual pattern with a student heard me announce departure and got on the radio. I was halfway out on the runway before I got stopped, though. His wheels were below the level of my instrument panel when he went by. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
MEL that is overtaking him. Likewise, the ultralights will have difficulty seeing any SEL or MEL that are overtaking them. Is this system really the best way to minimize the risk in the traffic pattern? I don't think I'd be so concerned with a guy behind me... unless we both have an operating radio and make proper calls, I would not even know he is behind me. If I'm in a J-3 or a Champ or a Piper 140 or 180 or a C-210, and I think that "larger SEL or MEL" aircraft is going to crawl up my butt, I think a simple radio call asking if he can see me in front of him would suffice. If I'm in my J-3, NORDO, and I know I did not cut off a 5 mile straight in aircraft, could not see him and tell he was in the pattern. Then, he needs to be looking out the window. No, I am not standing on the, "I'm in front I own the runway" mentality, I'm just stating the way it is. I have not flown many aircraft where I can crank my head around to check 6 on final approach for that big bear that's gonna roll over me. BT |
Logging time on a PCATD | [email protected] | Instrument Flight Rules | 3 | December 18th 04 05:25 PM |
FAA Application -- kinds of time | Gary Drescher | Instrument Flight Rules | 5 | November 23rd 04 02:33 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 12:18 AM |
