"Ron Natalie" wrote in message ...
"Ace Pilot" wrote in message om... But there are airports that don't have this luxury and all aircraft have to share the same runway. Putting the ultralights on the "inside and lower" from the regular (SEL) traffic pattern, which may be "inside and lower" the MEL puts the burden for see and avoid on the faster aircraft. Back when our airport had a fairly active ultralight activity. They flew the opposite pattern, obviously lower and tighter than the regular pattern. It was quite easy as a result for them to adjust on base leg to fit into the higher performance traffic. This sounds interesting. If I understand you correctly, everyone used the same runway, but higher performance aircraft flew a left-hand pattern while ultralights flew a right-hand pattern (or vice versa). This is contrary to what AC 90-66A suggests, i.e., different size and altitude patterns on the same side of the runway. Was there something that prevented the airport from following the 90-66A recommendation, or was this procedure deemed safer than what 90-66A recommended? I can see some of the advantages. While on downwind and base, traffic with significantly different speeds is more likely forward of you, enabling everyone to better see and avoid the traffic that is of most concern. Having different sized patterns on opposite sides of the runway means that traffic that overshoots final isn't flying head on into the other pattern's base leg traffic. Were there any disadvantages with this procedure? How was knowledge of this procedure disseminated? Thanks for the input, Ron. |
![]() Ace Pilot wrote: Were there any disadvantages with this procedure? How was knowledge of this procedure disseminated? Thanks for the input, Ron. One disadvantage is the fact that aircraft on the base leg of a reverse-direction pattern can't be seen by high-wing aircraft waiting at the runway. Couple that with a circling approach from 300' AGL, and you've got real problems. I was almost nailed on my solo flight by some A**hole doing this in a Breezy. Fortunately, a CFI flying the usual pattern with a student heard me announce departure and got on the radio. I was halfway out on the runway before I got stopped, though. His wheels were below the level of my instrument panel when he went by. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
"G.R. Patterson III" wrote in message
... One disadvantage is the fact that aircraft on the base leg of a reverse-direction pattern can't be seen by high-wing aircraft waiting at the runway. Huh? Left or right patterns are not chosen for the convenience of those waiting at the runway. At most airports, the pattern is all left turns or all right turns, and there is only one taxiway to the runway. There is almost always the potential for a high-wing airplane to not be able to see traffic on base leg without turning the airplane prior to entering the runway. This has nothing to do with having a "reverse-direction pattern". You can NEVER count on there not being an aircraft on base leg behind you as you enter the runway. That's why I ALWAYS turn the airplane so that I can see the base leg behind me, whichever base leg that is and whether or not it's part of the usual pattern, before I enter the runway. [...] I was halfway out on the runway before I got stopped, though. His wheels were below the level of my instrument panel when he went by. Sounds to me like you both screwed up. Before wandering onto the runway, you should've positioned your airplane so you could see traffic approaching the runway, and he should have gone around when you violated his right-of-way as landing traffic. Pete |
![]() "Peter Duniho" wrote in message ... Sounds to me like you both screwed up. Before wandering onto the runway, you should've positioned your airplane so you could see traffic approaching the runway, and he should have gone around when you violated his right-of-way as landing traffic. I'm also not sure why traffic on base is an issue. How long does it take to depart? Around here there are typically people on final when you pull out. If you don't you'll never get off the ground on a busy day. |
. .. I'm also not sure why traffic on base is an issue. How long does it take to depart? Around here there are typically people on final when you pull out. If you don't you'll never get off the ground on a busy day. Maybe it's those fast slow ultralights? ![]() Seriously though, I have to assume it's a combination of a significantly smaller pattern flown (where final is very short) and the base leg visibility he's complaining about. The complaint still doesn't make sense, but at least I can hypothesize a pattern flown where traffic on base is still relatively close to landing. Who knows? Bottom line though is that one should not taxi onto the runway until one has made sure one is not pulling out in front of traffic, no matter where that traffic may be. Pete |
![]() "Peter Duniho" wrote in message ... Seriously though, I have to assume it's a combination of a significantly smaller pattern flown (where final is very short) and the base leg visibility he's complaining about. Of course, when they're coming in on the reciprocal runway at our field, you can't even see the base leg guys until right about when they turn final. |
![]() Peter Duniho wrote: Sounds to me like you both screwed up. Before wandering onto the runway, you should've positioned your airplane so you could see traffic approaching the runway, I did. The entrance for the end of runway 06 at Kupper is roughly at 45 degrees to the runway. He was doing a right hand pattern with a downwind at 300' AGL, using a circling downwind to final (ie. no base leg as such). Kupper uses a left hand pattern at 1000' AGL. He was still in his turn to final as he came over the tree tops. He was eventually banned from several local airports for his approaches, Solberg being one. Finally bought an airport so he could fly any way he wanted. and he should have gone around when you violated his right-of-way as landing traffic. He had no time to go around. In any case, if I can mix it with King Airs and KC-135s in a Maule, the sport plane pilots can damn well fly the same patterns as the rest of us. No way is it safe to have traffic running base legs from both directions. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
... Sounds to me like you both screwed up. Before wandering onto the runway, you should've positioned your airplane so you could see traffic approaching the runway, I did. So you saw the guy and still pulled out in front of him? That's pretty sad. That you did it, and that you're willing to admit it here. |
![]() Peter Duniho wrote: So you saw the guy and still pulled out in front of him? That's pretty sad. That you did it, and that you're willing to admit it here. No, I did not see him. I positioned the aircraft so that I could see others approaching. I put the plane in exactly the position that EVERY PILOT POSITIONS HIS AIRCRAFT FOR DEPARTURE FROM THAT RUNWAY. Nobody can see a plane that comes in from behind or is below the tree line. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
... No, I did not see him. I positioned the aircraft so that I could see others approaching. First, you claim you were positioned to see aircraft approaching the runway. The aircraft was approaching the runway. So either you are incorrect about how you positioned your plane, or you are incorrect about whether you saw the guy. Nobody can see a plane that comes in from behind or is below the tree line. Second, your story makes no sense. You've got an ultralight too slow to fly with the other aircraft in the usual pattern, but so fast that it can make it from the trees to the runway in the few seconds it takes for you to taxi onto the runway, and so fast that it can't even manuever to go around once the pilot sees you violating their right-of-way. That's one fast (but slow) ultralight. Pete |
Logging time on a PCATD | [email protected] | Instrument Flight Rules | 3 | December 18th 04 05:25 PM |
FAA Application -- kinds of time | Gary Drescher | Instrument Flight Rules | 5 | November 23rd 04 02:33 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 12:18 AM |
