LED tail strobe
Old April 25th 04, 04:14 AM
Jay
The advantage of putting your emmiters in series (rather than
parallel) is that you pull less current. The mark to space ratio
people have been discussing isn't that small. I don't think it would
be a problem, but if you wanted to reduce the surge you could charge
and discharge the gate of that big FET more slowly thus having a
slower turn-on speed. You could do that by putting a high value
resistor in series with the 555 output.
The high voltage switching supplies that power those flash tubes can
draw progressively more current as they degrade over time.
anonymous coward wrote in message e...
Something I've been pondering...
4 Luxeon star 1W emmitters in parallel will draw 1A or so. Your 555 based
timer circuit will draw large(ish) currents for short periods of time,
because of the small mark:space ratio. Might this interfere with other
systems powered by the battery?
The switching regulators for standard Xenon flash tubes draw a lower
but much more constant current (though goodness knows they can generate
radio noise if they're not shielded right).
AC
On Sat, 17 Apr 2004 23:25:24 -0700, Jay wrote:
I think someone may have already pointed this out, and maybe I didn't
make it as clear as I should have... I stacked the forward drop of
MULTIPLE LEDs up until I got somewhere near the bottom end of the
supply voltage. So for the example I gave, I got to 4 LEDS in series.
Why waste all that power as long IR (heat) off a big resistor when we
want red and green light right?
Regarding 2.8V- The forward drop of these devices now-a-days is all
over the place. The new chemistries seem to be making higher forward
drops, plus the trend is to package multiple die into one larger
device and this can effect the forward drop of the composite device.
By the way, anyone building my circuit should try one instance of it
(4 LEDS and resistor) on your bench supply before you go fly at night
cross country.
Jim Weir wrote in message . ..
Before everybody in the Western Hemisphere blows a bucket full of light emitting
diodes, would you care to calculate the resistor one more time? And perhaps
post a retraction?
(Jay)
-You can find examples on how to power the LEDs on the manufacturer web
-site.
-Having said that...
So lets say the recommended current for
-the LED is 20mA. Ohms law is R=E/I, so that gives you a resistor
-value of .3V/.02A=15 ohms.
Um, no. Suppose the diode has a forward voltage drop of 2.8 volts (that's not a
common value, but I'll give it to you for argument.
Now the power supply (battery) is a 12 volt supply, but 14.2 volts at full
charge with the alternator going, so the drop across the series resistor is
going to be
14.2 minus 2.8 equals 11.4 volts, which is the voltage across the resistor.
This current limiting resistor is going to have 20 mA flowing through it, so Ohm
tells us that resistance equals voltage divided by current. In this case, 11.4
volts divided by 20 mA gives us a resistor of 570 ohms (560 is the nearest
standard value).
You put your calculated 15 ohm resistor in series with this diode and I
guarantee you that the SNAP you hear is the gallium aluminum arsenide
semiconductor of the diode being sacrificed on Ohm's altar.
I'm serious. You owe the newsgroup a correction before somebody takes your
error and blows up a whole bunch of LEDs.
http://www.rst-engr.com
Old April 28th 04, 06:18 PM
Jay
"Blueskies" wrote in message . com...
Oh darn, you mean I'll only get about 50,000 hours???? or
Nope
...does it mean that the light output at 100,000 will be 1/2
the original level?
Ya that is right, thats how I understand it. Its the 3dB point. At
that time it won't appear to be half as bright to the human eye
because THAT sensor has a log response to give us all fantastic
dynamic range. Measured with a calibrated instrument, you'd see half
the output.
Theoretically, if you exactly met the spec at time zero, in 1 hour
you'd be under spec all other conditions being equal.
  #28
Old May 1st 04, 05:04 PM
BllFs6
The criteria I had when laying out my circuit was that the lights would
operate down to 10V and still not exceed the max current limit at 15V.
I'm working from memory here, but I believe the SuperBright LEDs I used
had a forward voltage of 3.5V.
Putting 2 in series with a 220ohm, 1/4W resistor maximized the
efficiency while maintaining the range I wanted.
Okay, thats not too bad because your using a resistor to cover HALF the voltage
drop....of course your losing half your power in the resistor rather than
having it produce light in the LED...
My previous post was more concerned with folks both running the LED at absolute
max power ratings,,,,and trying to use the LED voltage drop to cover something
like 80 percent or more voltage range...thats when you have to be a little more
careful...
Your 1/4 watt resistor is NOT high powered enough....youll be running it close
to or past its maximum power rating for normal voltages....
Get something more like 1/2 watt or 1 watt resistors....or use 2,3,or or even 4
of the 1/4 watt resistors with appropriate resistance values in series to
spread the power load....resistors are cheap and there AINT no harm in using
ones that can handle significantly more power than expected....while the risk
to benefit ratio of trying to push their limits seems rather high....
Also make sure the resistors can cool effectively.....their power ratings dont
mean diddly if they are well insulated or packed into a tight space and can
warm up...
take care
Blll
  #29
Old May 5th 04, 02:18 AM
anonymous coward
Nope
the original level?
dynamic range.
That wouldn't be true at threshold though. For example, if you moved the
LED away from the observer until it was only just visible then reduced
the brightness by half, it would become invisible and you'd have to move
it quite a long way back before the observer could see it again.
the output.
  #30
Old May 5th 04, 02:23 AM
anonymous coward
Have you considered using a constant current regulator, instead of a
resistor? I believe there is an example circuit given in the LM337/317
datasheet showing how to build one using only the LM337 (normally used as
a voltage regulator) & one resistor.
It would need to be bolted to a heatsink, like the Luxeon Star LEDs, but
IIRC the LM337 and cousins also shut down if they overheat.
AC
FS: RV-8 Tail Kit Mike Woodall Home Built 0 January 4th 04 03:38 AM
twin tail questions Kevin Horton Home Built 12 January 2nd 04 04:21 PM
tail buffeting and leading edge fillets, strakes Wallace Berry Home Built 1 September 26th 03 11:48 PM
LEDs with Strobe lights pekka1510 Home Built 11 September 1st 03 12:36 AM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Home Built 4 July 26th 03 12:34 PM
