On Tue, 17 Feb 2004 23:23:50 +0100, Frank Ivo Streckebein
wrote: Hello to the group ! Does anybody use the VertexStandard Pilot VXA-210? My question: The manual says that the led on top of the unit will glow green if it is receiving a carrier and the color will change to red when transmitting. With my handheld the led is only glowing green when receiving; the led goes out when transmitting. Is this like your unit Two separate leds inside the lens, so could be a problem with one. Does the unit actually transmit? If so, may be simply in the led circuitry for the red led. While I don't have a VXA-210, I do have VX-5R (amateur radio ht) and there is indeed a method of enabling or disabling the led to save power, but that action, which is #17 BUSY/TX LED on my unit, affects both colors so probably isn't your problem. Even though different radios, Yaesu follows somewhat closely the menu system on their radios, so you probably have this setting also. You might cycle this setting to see if that affects the problem. ....Edwin ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~ Edwin Johnson ....... ~ ~ http://www.shreve.net/~elj ~ ~ ~ ~ "Once you have flown, you will walk the ~ ~ earth with your eyes turned skyward, ~ ~ for there you have been, there you long ~ ~ to return." -- da Vinci ~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
Edwin Johnson schrieb:
Two separate leds inside the lens, so could be a problem with one. Does the unit actually transmit? If so, may be simply in the led circuitry for the red led. Yes, the unit transmits correct. While I don't have a VXA-210, I do have VX-5R (amateur radio ht) and there is indeed a method of enabling or disabling the led to save power, but that action, which is #17 BUSY/TX LED on my unit, affects both colors so probably isn't your problem. Even though different radios, Yaesu follows somewhat closely the menu system on their radios, so you probably have this setting also. You might cycle this setting to see if that affects the problem. Sorry, but there is no such item in the setup menu for the vxa-210. Frank |
GPS Handheld | Kai Glaesner | Instrument Flight Rules | 2 | November 16th 04 04:01 PM |
Terrain-Aware Handheld vs. IFR GPS? | C Kingsbury | Instrument Flight Rules | 7 | November 14th 04 05:33 AM |
Upgrade handheld GPS, or save for panel mount? | [email protected] | Owning | 7 | March 8th 04 03:33 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
FS: GPS - Handheld II Morrow - Apollo 920 Moving Map | robert | Aviation Marketplace | 1 | February 6th 04 02:21 AM |
