Piper Pathfinder Article
Old March 10th 04, 07:38 PM
Larry Dighera
On Wed, 10 Mar 2004 17:06:16 GMT, john smith wrote in
Message-Id: :
I don't think Jay is going to be flying over Pike's Peak (14,110 feet)
unless he gets a Cessna. :-)
Service Ceiling PA28-235 ... 13,550
Service Ceiling C182.........17,700
He should be glad he didn't purchase a Charger:
http://www.trade-a-plane.com/unprote...erf_1475B.html
Cessna doesn't reveal the Skylane's useful load:
http://skylane.cessna.com/spec_perf.chtml
Is the Piper or Cessna able to carry the most payload with full tanks?
Old March 10th 04, 08:40 PM
john smith
Message-Id: :
keeping in mind that these are 1974 models...
Pathfinder 182
average equipped new list price $36,490 $30,475
current values $63,000 $79,000
price appreciation factor 172% 259%
gross weight (lbs) 3,000 2,950
empth weight (lbs) 1,550 1,645
useful load (lbs) 1,450 1,305
horsepower 235 230
power loading (lbs/hp) 12.8 12.8
wing loading (lbs/sqft) 17.6 16.9
total fuel capacity (gal) 82 79
payload, max fuel (lbs) 958 831
cruise speed, 75% (kts) 133 139
best rate of climb SL (fpm) 800 890
Vso 52 50
takeoff run (ft) 850 705
landing run (ft) 1,040 590
Old March 10th 04, 09:25 PM
Jay Honeck
We've never had any reason to fly higher than 12,500 -- even when we flew to
the Grand Canyon. But we were still climbing pretty smartly when we leveled
off, so I wonder about that ceiling. (Doubt I'll be finding out anytime
soon, however. I don't have an oxygen system.)
Pfffft! What year are these prices from? I haven't seen a decent
Pathfinder go for less than $80K since we bought ours in 2002. There are
several for sale in T-A-P for $95K+.
Yep, that's what makes the Pathfinder such an awesome plane. To be able to
haul four 200 pounders, full tanks, AND baggage is a wonderful thing.
Totally bogus. We routinely see 1000+ fpm. Although, to be fair, our
Pathfinder has every speed mod ever made for it, so I don't know what a
stock bird would do.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 10th 04, 11:36 PM
Larry Dighera
On Wed, 10 Mar 2004 21:25:11 GMT, "Jay Honeck"
wrote in Message-Id:
XIL3c.100119$PR3.1812564@attbi_s03:
You don't need one below 14,500'.
Old March 10th 04, 11:42 PM
Larry Dighera
On Wed, 10 Mar 2004 23:36:31 GMT, Larry Dighera
wrote in Message-Id: :
.... for 30 minutes.
Old March 10th 04, 11:55 PM
David Brooks
"Larry Dighera" wrote in message
news
... for 30 minutes.
....on a day with low enough pressure to reduce the cabin altitude by 500'.
-- David Brooks
Old March 11th 04, 05:49 AM
Larry Dighera
On Wed, 10 Mar 2004 15:55:57 -0800, "David Brooks"
... for 30 minutes.
Thanks.
§ 91.211 Supplemental oxygen.
(a) General. No person may operate a civil aircraft of U.S.
registry—
(1) At cabin pressure altitudes above 12,500 feet (MSL) up to and
including 14,000 feet (MSL) unless the required minimum flight
crew is provided with and uses supplemental oxygen for that part
of the flight at those altitudes that is of more than 30 minutes
duration;
Old March 11th 04, 06:29 AM
Blanche
... for 30 minutes.
There's a really big difference between the FARs and your body's
requirements. Just because you are allowed doesn't mean you should.
Old March 11th 04, 01:46 PM
Larry Dighera
On 10 Mar 2004 23:29:43 -0700, Blanche
I'm sure you are correct about the difference between individual
tolerance to hypoxia. I recall reading that General Yeager was able
to withstand operating at 20,000' without oxygen.
Old March 10th 04, 11:30 PM
Larry Dighera
On Wed, 10 Mar 2004 20:40:26 GMT, john smith wrote in
Message-Id: :
Message-Id: :
Pathfinder 182
horsepower 235 230
Service Ceiling (ft) 13,550 17,700
Vso 52 50
The Skylane carries about 150 pounds less, at 4-1/2% greater speed, to
a 3,150' higher altitude, with a substantially shorter landing run due
to the Pathfinder's more pronounced ground-effect, and it has two
doors. If the Pathfinder were loaded 150 pounds lighter, it would
reduce the difference between it and the Skylane. If the performance
numbers were the sole criteria in selecting between the two, who could
argue against the Skylane? It even has better sagebrush clearance and
a rain porch, and for photography and pipeline work, ...
Have you got any cabin dimensions?
Piper Technical Publications List Jim Burns Owning 7 January 21st 05 03:27 AM
Anti collision light mod for Piper Arrow 1968 model? Frode Berg Owning 4 May 20th 04 05:16 AM
Piper Aztec and/or Apache owner groups? Ronnie D. Hughes Owning 3 April 1st 04 07:00 PM
Piper 6.00x6 Nose wheel and fork? mikem Owning 2 March 6th 04 07:23 PM
The Piper Cubs That Weren't Veeduber Home Built 5 August 28th 03 04:38 AM
