What route do you fly most often or feel most comfortable with? How
far could you wander from your home base without needing a map or even a compass to find all the cities and airports? -- Ben Jackson http://www.ben.com/ |
What route do you fly most often or feel most comfortable with? How far could you wander from your home base without needing a map or even a compass to find all the cities and airports? With 12 gal gas, the Cub has an effectived radius of one hour without refueling. I most often fly from Hampton NH up to Lake Winnipesaukee, touring Alton Bay and if the flight has gone quickly Wolfeboro also. (There's an airport at Wolfeboro, but no gas.) If I have the plane for more than two hours, I'll land and refuel at Moultonboro. The Big Lake is one of the loveliest places I know. A couple years ago I wrote a story about this route for the Wall Street Journal: www.pipercubforum.com/biglake.htm all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
"Ben Jackson" wrote:
What route do you fly most often or feel most comfortable with? How far could you wander from your home base without needing a map or even a compass to find all the cities and airports? I assume you're also excluding, GPS, VOR, etc. I suppose I could make it ok from Mobile to Houston without a map or a compass or even without following I-10 the whole way. After a couple dozen trips I probably have it wired - might be interesting to try it next time if the weather's nice. -- Dan C172RG at BFM |
Ben Jackson wrote: How far could you wander from your home base without needing a map or even a compass to find all the cities and airports? I could make it from Old Bridge, NJ to Atlanta, GA without a map or compass. It certainly wouldn't be a direct flight, and I wouldn't know *all* the airports, but it's pretty easy to do. My usual runs would be more like 60 miles from Old Bridge and return (Pocono Mountains). George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
I can think of several places out of Tacoma Narrows I could get to without
map or compass -- given good visibility. Hoquiam, Kelso, Port Angeles, even Friday Harbor (though I might not be able to find my way back). |
"C J Campbell" wrote in message
... I can think of several places out of Tacoma Narrows I could get to without map or compass -- given good visibility. Hoquiam, Kelso, Port Angeles, even Friday Harbor (though I might not be able to find my way back). Chris, I think you underestimate yourself. We have all those wonderful crinkly shorelines: Nisqually Reach coming from the south, and Whidbey shoreline from the north and northwest, are pretty good for orienting yourself back home. Personally, I might find it harder on the outbound to Kelso and FHR. -- David Brooks |
"David Brooks" wrote in message ... "C J Campbell" wrote in message ... I can think of several places out of Tacoma Narrows I could get to without map or compass -- given good visibility. Hoquiam, Kelso, Port Angeles, even Friday Harbor (though I might not be able to find my way back). Chris, I think you underestimate yourself. We have all those wonderful crinkly shorelines: Nisqually Reach coming from the south, and Whidbey shoreline from the north and northwest, are pretty good for orienting yourself back home. Personally, I might find it harder on the outbound to Kelso and FHR. Yeah, well, I have been lost twice crossing the Strait of Juan de Fuca, both times due to overconfidence bred of familiarity with the area. It is too darned easy to start following the wrong coastline. |
In article , C J Campbell wrote:
I can think of several places out of Tacoma Narrows I could get to without map or compass -- given good visibility. Hoquiam, Kelso, Port Angeles, even Friday Harbor (though I might not be able to find my way back). When going to Friday Harbor (FHR) from Boeing Field (BFI), I would just head north up the sound, along the east side to Paine, then turn NW to follow the long narrow peninsula that points directly to FHR. Not only does it make visual navigation easy, but it keeps you closer to land than you would be taking the direct path. Pretty much anywhere in the Puget sound area is trival pilotage. Unfortunately, I never got to practice much DR navigation. Of course, there was the time I was doing some night practice at Bremerton (PWT) and decided to go to Tacoma Narrows (TIW), which I knew from day trips is oh, about thataway from PWT. After about 3 minutes, I was hopelessly lost among the lights, and I didn't want to blunder into the Seattle Class B airspace (nor the McCord airforce base for that matter), so I did a 180 back to Bremerton. Then I looked at the map, estimated the distance and heading, and calculated an ETE. Worked beautifully. Morris (currently living on the wrong sound) |
Just about anyplace from Cheyenne, WY to ABQ, NM. No problems. Keep
the mountains on the west side. As a rule, if I can't see Pikes Peak from the house ('bout 60 sm) I don't head south. If I can't see Longs Peak (about 40 sm) I don't head north. And if the thunderboomers-fluffy white clouds are covering the entire east sky, I change my plans and go shopping. |
Just about anyplace from Cheyenne, WY to ABQ, NM. No problems. Keep the mountains on the west side. I do much the same thing. Fly north, ocean on right (starboard . Flysouth, ocean on left. The three most visible things when flying around southeastern New Hampshire a Boston, Mount Washington, and the concrete runways of the former Pease Air Force Base. Plus the Atlantic Ocean and Lake Winnipesaukee, of course. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
| Thread Tools | |
| Display Modes | |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
| filing IFR plan for VFR flight conditions | Paul Safran | Instrument Flight Rules | 53 | May 11th 04 04:07 AM |
| Seeking Route Advice - OH -> SD -> MT -> BC | Darrell Clay | Piloting | 0 | January 28th 04 02:20 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| My route to the 3rd annual ParasolAirplanes Fly In | Scott | Home Built | 1 | July 18th 03 08:28 PM |
