Jay Honeck wrote:
However, how is it that you can up the RPM limit of a given engine simply because you want to keep the prop tips subsonic? You would decrease the RPM limit, not increase it, to keep the tips subsonic. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
simply because you want to keep the prop tips subsonic? You would decrease the RPM limit, not increase it, to keep the tips subsonic. Understood. If you lengthened the prop, you'd have to decrease the RPM redline to keep the tips subsonic. However, the part of the question I was referring to was if you *shortened* the prop. Part of the original post implied that you would be able to simply *increase* the engine's redline RPM if you shortened your prop, regardless of engine limitations. I don't believe this is true. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Mon, 14 Jun 2004 19:39:46 GMT, "Jay Honeck"
wrote: However, how is it that you can up the RPM limit of a given engine simply because you want to keep the prop tips subsonic? You would decrease the RPM limit, not increase it, to keep the tips subsonic. Understood. If you lengthened the prop, you'd have to decrease the RPM redline to keep the tips subsonic. However, the part of the question I was referring to was if you *shortened* the prop. Part of the original post implied that you would be able to simply *increase* the engine's redline RPM if you shortened your prop, regardless of engine limitations. I don't believe this is true. It isn't true. Theoretically, you could increase the redline rpm providing you don't exceed the limitations of any other part of the "system", such as the engine. The redline would have to be based upon the most restrictive component. Rich Russell |
Found the source, sort of...
http://www.airweb.faa.gov/Regulatory...rgAdvisoryCirc ular.nsf/0/c2f903127f0f41e4862569ae006d44d7/$FILE/AC20-88A.pdf ANNOUNCEMENT OF AVAILABILITY OF ADVISORY CIRCULAR 20-88A; LINES ON THE MARKING OF AIRCRAFT POWERPLANT INSTRUMENTS (DISPLAYS) g. Tachometer (Reciprocating Engine Aircraft) Red Radial - At maximum permissible rotational speed (rpm). Green Arc - From maximum rotational speed for continuous operation to minimum recommended for continuous operation (except in the restricted range, if any). For propeller driven small airplanes which must meet the requirements in Appendix F to Part 36 of the FAR at maximum normal operating power, from the corrected rotational speed used to establish the aircraft noise level to the minimum recommended for continuous operation (except in the restricted ranges, if any). Yellow Arc - From maximum rotational speed for continuous operation to maximum permissible rotational speed. Yellow Arc (Offset) - Conditional operating range for one engine inoperative flight that exists above the normal takeoff rating limit (if applicable). Red Arc - Range(s) in which operation is restricted, except to pass through, for all operating conditions because of excessive stresses, etc. |
Jay Honeck wrote:
However, the part of the question I was referring to was if you *shortened* the prop. Part of the original post implied that you would be able to simply *increase* the engine's redline RPM if you shortened your prop, regardless of engine limitations. I don't believe this is true. I think at that point, you'd be getting into limitations of the engine components (with some tolerance). -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
| Thread Tools | |
| Display Modes | |
| Are You Flying a "Beater?" | Jay Honeck | Piloting | 90 | June 16th 04 12:38 PM |
| Contract Tower Program - Discussion Thread | running with scissors | Instrument Flight Rules | 6 | April 22nd 04 05:04 AM |
| Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 03:56 AM |
| Fuel line thread sealant | Paul Lee | Home Built | 7 | February 26th 04 01:44 AM |
| recovery from inverted IMC (a propos of "backup gyros" thread) | Sydney Hoeltzli | Piloting | 4 | July 15th 03 03:00 PM |
