What do I hear?
A little brat whining because he was looking for a cheap plane and found one. A statement to the effect that, "I'm not an airplane mechanic, but I like to play one in the newsgroups." Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
I'd pay good money for tickets to see Berle kick that wining Jim
Weir's ass at OSH. God knows he's had it coming for years. Would be great fodder for his next book, a best seller for sure. Maybe we can set it up as a charity event for the Poberesny benefit and award fund. The boys can never have enough personal funds nor awards for their work. On Fri, 18 Jun 2004 09:02:08 -0700, Jim Weir wrote: What do I hear? A little brat whining because he was looking for a cheap plane and found one. A statement to the effect that, "I'm not an airplane mechanic, but I like to play one in the newsgroups." Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Stu Gotts
shared these priceless pearls of wisdom: -I'd pay good money for tickets to see Berle kick that wining Jim -Weir's ass at OSH. God knows he's had it coming for years. Would be -great fodder for his next book, a best seller for sure. Maybe we can -set it up as a charity event for the Poberesny benefit and award fund. -The boys can never have enough personal funds nor awards for their -work. First of all, it is WHINING, not wining. Second, it is POBEREZNY, not Poberesny. Third, my schedule will be posted in the EAA Convention Guide; you know where to come find me. Let's examine the facts: Berle claimed that there were several "complex and expensive ADs" that had not been complied with. Nowhere in the body of the text does he describe or list these ADs. However, just to keep the record straight, here is my software's printout of the applicable airframe ADs on a Cessna 175. Since Berle did not specify 175, A, B, or C, I chose the earliest model to be sure I captured all of the old ADs as well. If anybody finds an AIRFRAME AD that my software missed, please post it here in the spirit of safety and completeness. We can do engine, too, if you like, but Berle's only squawks that I saw were airframe related. Company Manufacturer CESSNA AIRCRAFT CORP. Model 175 Tail # Serial # Tach Time A/C Cert. Date Total Time AD Number Description 62-22-01 VACUUM PUMP MODIFICATION/ *69-15-03 MUFFLER ASSEMBLY/ *71-22-02 CRACKS IN NOSE GEAR FORK/ 73-17-01 FUEL TRANSFER PUMP PLACARD/ *74-06-02 AVCON MUFFLERS/ 79-08-03 ELECTRICAL SYSTEM/ 79-10-14 R1 FUEL TANK VENTING/ 82-07-02 ENGINE CRANKCASE BREATHER/ 86-26-04 SHOULDER HARNESS ADJUSTER/ *87-20-03 R2 SEAT TRACKS/ 97-01-13 COLLAPSED HOSE/ 99-27-02 FUEL SELECTOR VALVE/ * Indicates possible recurring inspections Page 1 of 1 He also complains of a major repair that he was not told about. With all of his "experience", he didn't know that the first question out of the box on the phone should have been "what is the major damage history?" I think not, nor does he claim that the owner lied to him on the question that was not asked. Let's take a look at the specific items that Berle was not pleased with: Seat rails near or probably beyond the wear limit. Cessna did not build seat We do not deal in "probably" in this business. Nor can we demand that something be replaced when it is "near" a limit. Limits are just that...the point at which something has to be dealt with. The AD on seat tracks (*87-20-03-R2) is very specific. If Berle had his precision pin set with him, he could have been very specific that the rail was or was not within limits. Eyeball guessing doesn't cut it. Flap tracks worn to or beyond safe limits. There is a big AD on this. And Cessna's definition of safe limits is? You had the Cessna repair manual with you that gave the limits? And the AD number you refer to is? Frozen or over tightened aileron rod ball joints. Frozen? Probably. An airplane sitting outside, even in San Diego, gathers a bit of corrosion inside the mechanisms. That's why Mouse Milk and/or LPS-1 is a staple of any mechanic's chemistry shelf. Why don't you explain to us how you can overtighten a Cessna aileron ball joint and have it clamp down on the pivot bolt? Without chucking the ball joint up in a lathe and cutting another inch or so of threads on the ball joint, of course. If you are talking about tightening up the pivot bolt, you'd have deformed the aileron attach bracket so severely that it would have been obvious to the casual observer. Which was it? By the way, speaking of primary flight controls, I noticed that the pilot's side control yoke could be moved up and down a couple of inches in the instrument panel bushing. You may have one here, although I doubt (once more) you had a definitive answer as to how loose is too loose from an authoritative source (like the Cessna fixit manual). And, if you could move it UP and DOWN a couple of inches, you have a four inch total travel. Somehow I think the case is overstated here -- you'd be bumping the gyros going up and the radio stack going down with this much mickeymotion. The engine cowl was really shoddily repaired , using hardware store pop rivets and scab patches. Any decent repair would have used inside or flush patches, and regardless of where the patch is the FAR's REQUIRE the use of aircraft rivets. Shoddy and unairworthy are two separate and distinct conditions. One is subjective (eye of the beholder) and one is objective (written in precise language). Cessna allows scab (outside) patches on pretty nearly the entire sheet metal airframe, and who are you to say that a "decent" repair has to follow your personal desires when the manufacturer says different? And there ARE aircraft approved "pop rivets". Whether or not these are of that variety, I'd either have to see for myself OR look what the person who did the repair put in the logbook for materials used. I'd hardly call somebody a Bozo when you appear to be the Bozee. Finally, you decided that I didn't deserve to know that the whole airplane was windstorm-flipped out of the tiedown RECENTLY and an entire wing was replaced, nosegear mounts, and other parts. Any potential buyer would have wanted to know that kind of thing before they traveled any distance or burned up a very rare day off of work. Wings get replaced all the time, and if it's done right it's not a problem. But you OWE a potential buyer that information before they make arrangements to drive 250 miles round trip. And you owe the owner the simple question of major damage history on the phone before you set out on the trip. I stand by my original statement...you thought you were going to buy a creampuff for a lemon's price and you found that you had a lemon for a lemon's price. What's your squawk? Now, would I annual this airplane? Hell, I'm 600 miles north and not the least bit interested. However, from the words you wrote, I'd be hard pressed to find something unairworthy in your diatribe. You got suckered, plain and simple. Barnum was right. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
The misspellings were for your benefit. Thought you would understand
them better and I could give a **** about how da and lad spell their name. Thanks for the invite, tough guy and yes, maybe I will look you up and give you a bitch slap for all the time you spend trying to discredit everything Berle says or does. On Sun, 20 Jun 2004 10:30:08 -0700, Jim Weir wrote: Stu Gotts shared these priceless pearls of wisdom: -I'd pay good money for tickets to see Berle kick that wining Jim -Weir's ass at OSH. God knows he's had it coming for years. Would be -great fodder for his next book, a best seller for sure. Maybe we can -set it up as a charity event for the Poberesny benefit and award fund. -The boys can never have enough personal funds nor awards for their -work. First of all, it is WHINING, not wining. Second, it is POBEREZNY, not Poberesny. Third, my schedule will be posted in the EAA Convention Guide; you know where to come find me. Let's examine the facts: Berle claimed that there were several "complex and expensive ADs" that had not been complied with. Nowhere in the body of the text does he describe or list these ADs. However, just to keep the record straight, here is my software's printout of the applicable airframe ADs on a Cessna 175. Since Berle did not specify 175, A, B, or C, I chose the earliest model to be sure I captured all of the old ADs as well. If anybody finds an AIRFRAME AD that my software missed, please post it here in the spirit of safety and completeness. We can do engine, too, if you like, but Berle's only squawks that I saw were airframe related. Company Manufacturer CESSNA AIRCRAFT CORP. Model 175 Tail # Serial # Tach Time A/C Cert. Date Total Time AD Number Description 62-22-01 VACUUM PUMP MODIFICATION/ *69-15-03 MUFFLER ASSEMBLY/ *71-22-02 CRACKS IN NOSE GEAR FORK/ 73-17-01 FUEL TRANSFER PUMP PLACARD/ *74-06-02 AVCON MUFFLERS/ 79-08-03 ELECTRICAL SYSTEM/ 79-10-14 R1 FUEL TANK VENTING/ 82-07-02 ENGINE CRANKCASE BREATHER/ 86-26-04 SHOULDER HARNESS ADJUSTER/ *87-20-03 R2 SEAT TRACKS/ 97-01-13 COLLAPSED HOSE/ 99-27-02 FUEL SELECTOR VALVE/ * Indicates possible recurring inspections Page 1 of 1 He also complains of a major repair that he was not told about. With all of his "experience", he didn't know that the first question out of the box on the phone should have been "what is the major damage history?" I think not, nor does he claim that the owner lied to him on the question that was not asked. Let's take a look at the specific items that Berle was not pleased with: Seat rails near or probably beyond the wear limit. Cessna did not build seat We do not deal in "probably" in this business. Nor can we demand that something be replaced when it is "near" a limit. Limits are just that...the point at which something has to be dealt with. The AD on seat tracks (*87-20-03-R2) is very specific. If Berle had his precision pin set with him, he could have been very specific that the rail was or was not within limits. Eyeball guessing doesn't cut it. Flap tracks worn to or beyond safe limits. There is a big AD on this. And Cessna's definition of safe limits is? You had the Cessna repair manual with you that gave the limits? And the AD number you refer to is? Frozen or over tightened aileron rod ball joints. Frozen? Probably. An airplane sitting outside, even in San Diego, gathers a bit of corrosion inside the mechanisms. That's why Mouse Milk and/or LPS-1 is a staple of any mechanic's chemistry shelf. Why don't you explain to us how you can overtighten a Cessna aileron ball joint and have it clamp down on the pivot bolt? Without chucking the ball joint up in a lathe and cutting another inch or so of threads on the ball joint, of course. If you are talking about tightening up the pivot bolt, you'd have deformed the aileron attach bracket so severely that it would have been obvious to the casual observer. Which was it? By the way, speaking of primary flight controls, I noticed that the pilot's side control yoke could be moved up and down a couple of inches in the instrument panel bushing. You may have one here, although I doubt (once more) you had a definitive answer as to how loose is too loose from an authoritative source (like the Cessna fixit manual). And, if you could move it UP and DOWN a couple of inches, you have a four inch total travel. Somehow I think the case is overstated here -- you'd be bumping the gyros going up and the radio stack going down with this much mickeymotion. The engine cowl was really shoddily repaired , using hardware store pop rivets and scab patches. Any decent repair would have used inside or flush patches, and regardless of where the patch is the FAR's REQUIRE the use of aircraft rivets. Shoddy and unairworthy are two separate and distinct conditions. One is subjective (eye of the beholder) and one is objective (written in precise language). Cessna allows scab (outside) patches on pretty nearly the entire sheet metal airframe, and who are you to say that a "decent" repair has to follow your personal desires when the manufacturer says different? And there ARE aircraft approved "pop rivets". Whether or not these are of that variety, I'd either have to see for myself OR look what the person who did the repair put in the logbook for materials used. I'd hardly call somebody a Bozo when you appear to be the Bozee. Finally, you decided that I didn't deserve to know that the whole airplane was windstorm-flipped out of the tiedown RECENTLY and an entire wing was replaced, nosegear mounts, and other parts. Any potential buyer would have wanted to know that kind of thing before they traveled any distance or burned up a very rare day off of work. Wings get replaced all the time, and if it's done right it's not a problem. But you OWE a potential buyer that information before they make arrangements to drive 250 miles round trip. And you owe the owner the simple question of major damage history on the phone before you set out on the trip. I stand by my original statement...you thought you were going to buy a creampuff for a lemon's price and you found that you had a lemon for a lemon's price. What's your squawk? Now, would I annual this airplane? Hell, I'm 600 miles north and not the least bit interested. However, from the words you wrote, I'd be hard pressed to find something unairworthy in your diatribe. You got suckered, plain and simple. Barnum was right. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote in message . ..
What do I hear? A little brat whining because he was looking for a cheap plane and found one. A statement to the effect that, "I'm not an airplane mechanic, but I like to play one in the newsgroups." Jim I have a lot of respect for one that will blow the whistle when it needs blowing. I have no respect for someone that thinks he finds something wrong with it. Not a pilot No longer a student No longer an aircraft owner Just a retired mechanical inspector/machinist/gage technician that would probably have no problem making you very angry were I to inspect your work. I've done it to the best. |
Stu Gotts wrote in message . ..
Weir's work doesn't need inspecting, so you've ****ed him off already! Whether he's ****ed off or not is totally inconsequential. His comments about someone warning of safety problems and to look for them, says much for his character. THey tell me that I would definately NOT buy anything based on his signature. |
Lennie the Lurker wrote:
Jim Weir wrote in message . .. What do I hear? A little brat whining because he was looking for a cheap plane and found one. A statement to the effect that, "I'm not an airplane mechanic, but I like to play one in the newsgroups." Jim I have a lot of respect for one that will blow the whistle when it needs blowing. I have no respect for someone that thinks he finds something wrong with it. Not a pilot No longer a student No longer an aircraft owner Just a retired mechanical inspector/machinist/gage technician that would probably have no problem making you very angry were I to inspect your work. I've done it to the best. Does this make you more manly? Matt |
Matt Whiting wrote in
: Lennie the Lurker wrote: Jim Weir wrote in message . .. What do I hear? A little brat whining because he was looking for a cheap plane and found one. A statement to the effect that, "I'm not an airplane mechanic, but I like to play one in the newsgroups." Jim I have a lot of respect for one that will blow the whistle when it needs blowing. I have no respect for someone that thinks he finds something wrong with it. Not a pilot No longer a student No longer an aircraft owner Just a retired mechanical inspector/machinist/gage technician that would probably have no problem making you very angry were I to inspect your work. I've done it to the best. Does this make you more manly? Matt Probably not, Matt, since none of this has anything to do with "manliness," but this comment of yours sure does make you look rather foolish. |
You would probably find a lot to squawk about on my mechanical machine work. I never set myself out to be a machinist, nor a gauge tech, nor have I ever claimed to do flawless mechanical work. And I've been inspected by the best, and always learned a thing or two when somebody found an error in my work; I try never to make the same goof twice (two marriages notwithstanding {;-) ). Jim (Lennie the Lurker) shared these priceless pearls of wisdom: - - -Just a retired mechanical inspector/machinist/gage technician - -that would probably have no problem making you very angry were I to -inspect your work. I've done it to the best. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
| Thread Tools | |
| Display Modes | |
| Beware of the Bug (IWBTM) | pacplyer | Home Built | 0 | March 9th 04 07:33 AM |
| Cessna landing gear legs Reserve MET! | Bill Berle | Home Built | 1 | February 23rd 04 01:31 AM |
| Cessna Steel Landing Gears, J-3 Seat Sling For Auction | Bill Berle | Home Built | 0 | February 19th 04 07:51 PM |
| Cessna wheela and axles | clare @ snyder.on .ca | Home Built | 2 | January 10th 04 05:52 PM |
| Cessna 150 Overhaul | Brian Jones | Aerobatics | 0 | November 2nd 03 02:50 PM |
