#21
![]() "Cub Driver" wrote in message ... I use the rubber ducky antenna. These are rental planes, and neither has an outside antenna. I seldom use delta airspace, however. And I always behave as if I were NORDO. I am reasonably sure however that I am always heard in the pattern, not so sure that I am heard five or even three miles out. In my experiment using the Icom with it's helical rubber "ducky" antenna I contacted NY Approach 15 miles north of HPN (I was at 3000 and I believe they are down in Long Island somewhere) then was handed off to HPN tower at about 10 miles out and everything went smoothly. I used the Icom PTT button and held the radio with the antenna vertical. |
Jim Weir wrote:
When was the last time you did this for real? Had to do it to pick up an IFR clearance while on the ground last year. |
I am also looking for a portable, Sporty's seems to have some of the
best prices right now, especially for the Icom A23 @ $369 The Vertex 210 appears to have most of the A23's features, but is a lot less expensive ($279). Why? Also, with the A23, is a separate PTT necessary to use the headset adapter? I'm not really clear how the headset adapter works with my headset (DC H10-13.4) and the A23. Thanks, Tom On 03 Jul 2004 01:46:42 GMT, (Lockrdg) wrote: Having experienced and successfully survived my first complete electrical failure, hence no radios (at night mind you), I am looking for suggestions as to which hand-held transcievers I might looking into buying. All suggestions are welcome... Thanks in advance. |
On 6 Jul 2004 23:59:54 -0500, John Smith wrote:
Also, with the A23, is a separate PTT necessary to use the headset adapter? I'm not really clear how the headset adapter works with my headset (DC H10-13.4) and the A23. It was with my Yaseu (Vertex). I think. It's such a convenience, and I've used it for three years now, that I really can't remember. Previously, I tried used the radio as a handheld, which meant putting the engine to idle every time. Even then it didn't work worth a damn. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! weblog www.vivabush.org |
John,
The Vertex 210 appears to have most of the A23's features, but is a lot less expensive ($279). Why? Because someone wants to make a business through volume, not price? -- Thomas Borchert (EDDH) |
John Smith wrote in message . ..
I am also looking for a portable, Sporty's seems to have some of the best prices right now, especially for the Icom A23 @ $369 The Vertex 210 appears to have most of the A23's features, but is a lot less expensive ($279). Why? Because it's a free market and that's what they think they can get for it. My own experience with Yaesu is that performance leaves a lot to be desired. I've found that a Sporty's even with a rubber ducky works nearly as well as a panel-mount nav and Yaesu would only pick up a VOR when it was close enough that I could hit it by throwing the Yaesu at it. Due to the miserable nav performance, I sent the Yaesu back to the manufacturer and had them check and adjust it. Upon its return, I found it worked not the slightest bit better. When it finally disappeared at an air show, I was more relieved than angry and replaced it with an Icom A-5. Also, with the A23, is a separate PTT necessary to use the headset adapter? I'm not really clear how the headset adapter works with my headset (DC H10-13.4) and the A23. No external switch is needed. It's just a convenience to have a PTT on the yoke. |
For the occasion when all the electrons die at once, I have 2
portables. I bought the new ICOM sport model transceiver (small size, light weight). I keep alkaline batteries in it because they retain a charge better than rechargeables and I need it only for emergencies. I also have an antenna loop in my Com2 under the panel so that I can disconnect the panel receiver and connect the Icom to the external antenna. For navigation I have a Garmin Pilot GPS III that can sit on the glareshield and runs 8-10 hours on 4 AA alkalines. |
#28
#29
Last time I opened a VFR flight plan.
Jim Weir wrote in message . .. When was the last time you did this for real? -Except that here in the USA, it is sometimes necessary to talk to FSS on - a comm frequency and listen on the VOR frequency. |
#30
tony roberts wrote in message news:nospam-69B6F8.23552803072004@shawnews...
BUT - go to a third party vendor and buy the AA battery back. Icom only comes with a rechargeable battery pack - not much use if you are sitting halfway up a mountain waiting to be rescued - but if you have the pack, plus a decent supply of AA batteries, you now have yourself a good emergency radio - in addition to it's everyday uses. The rechargable is perfect for the daily J-3 Cub flyer who uses it as his primary radio (that's the reason I bought mine) but the AA battery pack is best for the emergency radio (why I use it now). |
Destination Suggestions | Matt Young | Piloting | 9 | July 5th 04 03:17 AM |
Spousal checkride -- any suggestions? | Eric Ross | Piloting | 41 | June 21st 04 06:58 PM |
Bend, OR (S07) to OSH route suggestions | Jack Allison | Piloting | 4 | April 12th 04 09:19 PM |
Portable oxygen system suggestions... | hnelson | Owning | 3 | August 11th 03 08:39 AM |
Demo Flight Suggestions | Ben Jackson | Owning | 6 | July 12th 03 01:16 PM |
