#71
Oops, meant to say "the X-axis aligned at a 45 deg angle to the runway
centerline). "Jim Cummiskey" wrote in message news:3xqTc.37453$ih.9766@fed1read07... GB, the 45 degree cone Doug was referring to encompassed both sides of the extended centerline. Imagine a large X and Y axis superimposed on any airport (with the X-axis aligned with the runway centerline). There are thus four quadrants. If at any time I am moving in respect to the airport in one of those quadrants, I will either be in a "downwind" general direction, a "base" direction, a "final/upwind" direction, and a "crosswind" direction. The "Final/Upwind" direction represents the domain of what consitutes a "final" in my way of thinking (which appears to be shared by at least three ATC controllers). If you approach an airport at 30 degrees off the extended centerline (something that I'm sure most of you have done thousands of times--as I have), what leg are you flying? Regards, Jim "Flydive" wrote in message ... Jim Cummiskey wrote: (2) At Doug's airport, they consider every approach within a 45 degree cone of the centerline to comply with the "Make Straight In, Runway X" instruction. Clearly, there is NO OBLIGATION to intercept the centerline at any PARTICULAR point (although it must be intercepted at SOME point to land the plane; which I clearly did in this case--at ~1/2 mile from the numbers). Well if you were approaching with a 30 degrees angle you were in a 60 degrees cone, outside Doug's definition. GB |
#72
"Jim Cummiskey" wrote in message news:qHoTc.37435$ih.16698@fed1read07... Nope. I was at a position EXACTLY where I claimed to be. I was 5 miles from the airport, and I WAS on final. Thus "5 Miles Final." You're changing your story. In your initial message you wrote; "At 5 miles from the airport (still offset from the centerline), I report '5 mile final'." So which is it? Were you on final when you reported or were you offset from the centerline? As I have attempted to point out numerous times, the real issue is: "Must you be on the extended centerline to be on final?" You believe the answer is "Yes." I belive that the answer is "No." You say that like it's a matter of opinion. |
#73
"Jim Cummiskey" wrote in message news:g_oTc.37437$ih.15436@fed1read07... In respect to my sources, I believe the opinions of a Class C "ATC Procedures Specialist" at one of the business airports in Southern California, in conjunction with the Tower Manager at the airport where the supposed infraction took place trump any other source offered on this forum thus far. Indeed, the regulations (FAR and Order 7110.65) are often less than crystal-clear on sticky issues such as these (that's why the FAA publishes a FAQ to explain the FAR; if only we had a FAQ to explain the FAQ g). But the FAR and FAA Order 7110.65 are crystal clear on this issue. In short, both of these credentialed and informed gentlemen believe that you do NOT have to be on the extended centerline to be on "final." Everyone is entitled to their opinion, but I share their view. Pertinent documentation indicates that the three of you are wrong. |
#74
Appreciate the feedback, Maria. Good points, and I understand and agree
with your comments about the FARs and the expectations of pilots regarding position reports. However, a few comments: acknowledging WHY she felt it was important to do so, you are ticked-off that she mentioned it, concerned about not being "wrong", and playing semantics with the arguments. If this isn't just a great exercise in trolling, I hope, for the safety of everyone who shares the sky with you, that you get over it soon. Actually, ATC Doug has a theory WHY she felt it was important for her to call it to my attention. According to Doug, KPRC is a training facility, and they have a lot of inexperienced controllers there undergoing training. As I reported earlier, there was no radio traffic (to my recollection) within five minutes either side of my initial radio call and my wheels touching down. Since I was responsible for my own separation, I was quite attentive to traffic. I don't think there was any other traffic in the entire Class D airspace. Doug thinks the controller was "pulling my chain"--perhaps ensuring I understood the domain of her authority on a slow Sunday morning. But, according to ATC Paul, the Tower Manager, HIS controller was absolutely WRONG! Does his vote count? Or, am I still just a troller? So, yes Maria. I am very concerned about "not being wrong" when I fly. The consequences are too high. The point is: if it IS perfectly proper procedure to fly "angled finals" and report them as "finals," then shouldn't we pilots began to do a little better job of scanning the entire final quadrant vice only checking only the extended centerline? So, it has nothing to do with the "semantics of the arguments." It has to do with coming up with a common language so that when a Controller says X, the Pilot understands X (and vice-versa). The bottom line is that in this case we had a clear disconnect. And, three members of the ATC community agree that "flying directly to the airport, aligning myself with the runway, and landing" while reporting "5 miles final" at five miles offset from the centerline was PERFECTLY correct (indeed very COMMON behavior in the hundreds of airports I've experienced). Or maybe, you're saying I should have reported "5 miles" only? "5 miles NE?" How about "5 miles angled final?" Or, is your position, "You can't fly an angled final ever!?" If so, in the absence of a specific controller's "Report 'instruction,'" what are you proposing is the minimum distance every pilot should be on the extended centerline (less I spoil the the safety of the national airspace system for everyone)? And, what do I SAY to avoid crashing into someone? Gosh, all us people who have the arrogance to occasionally fly without radios must really upset all of you folks who's safety is compromised without continuous position reports. What happened to "See and Avoid" and "Keep that head on a swivel?" Regards, Jim "MariaSanguini" wrote in message ... IMO, you don't have to be an "expert" on interpreting the FARs ... the input, expert or not, of everyone who flies is important on this one. Obviously, we should always be scanning everywhere, but there *are* specific areas where majority of us *initially* look for traffic said to be in various stages of the traffic pattern, i.e., *on the extended runway centerline* for other "traffic on straight-in final", and it's important to your own safety and the safety of others that you *are* there when your position is announced, either by yourself or by an ATC. The issue isn't who is "right" or "wrong", but rather the arrogant, disappointing attitude that being "right" makes it okay to put yourself in a spot where you **KNOW** other pilots won't expect you to be if you are instructed to make "straight-in" final. The ATC thought it was enough of a concern to call it to your attention ... instead of understanding and acknowledging WHY she felt it was important to do so, you are ticked-off that she mentioned it, concerned about not being "wrong", and playing semantics with the arguments. If this isn't just a great exercise in trolling, I hope, for the safety of everyone who shares the sky with you, that you get over it soon. |
#75
miles from the airport (still offset from the centerline), I report '5 mile final'." So which is it? Were you on final when you reported or were you offset from the centerline? Both. I WAS on Final, and I WAS offset from the centerline. What a concept! You say that like it's a matter of opinion. It certainly appears to be on this forum (and unlike some of you "Final is A Single Degree" Club members, I at least understand your opinion). Do you understand mine? (as well as the opinons of those members of the ATC community that I am basing my position on)? Regards, Jim "Steven P. McNicoll" wrote in message ink.net... "Jim Cummiskey" wrote in message news:qHoTc.37435$ih.16698@fed1read07... Nope. I was at a position EXACTLY where I claimed to be. I was 5 miles from the airport, and I WAS on final. Thus "5 Miles Final." You're changing your story. In your initial message you wrote; "At 5 miles from the airport (still offset from the centerline), I report '5 mile final'." So which is it? Were you on final when you reported or were you offset from the centerline? As I have attempted to point out numerous times, the real issue is: "Must you be on the extended centerline to be on final?" You believe the answer is "Yes." I belive that the answer is "No." You say that like it's a matter of opinion. |
#76
"Jim Cummiskey" wrote in message news:ZspTc.37445$ih.14790@fed1read07... Thanks, Steve--you've made some good points. Interestingly, Doug quoted the exact paragraph, 3-10-1.g, to illustrate his point that it WASN'T standard phraseology. That would indicate he does not understand the paragraph. I think you have presented yourself as a working Tower ATC. If you don't mind, what class of Tower do you work at? Class of tower? Are you a "Procedures Specialist?" Nope. What's your contact information? I don't understand that question either. Not that I'm questioning you, but unfortunately, ATC doesn't have the same public-access database we can use to validate someone's expertise. I also know ATC has various levels of assignment, competency and experience (as obviously do pilots). Could you please describe yours for the group so we can assess your relative credibility to Doug and Paul? I work at Green Bay Tower/TRACON, the airspace is Class C. I've been here for twelve years, I was at Chicago ARTCC for nine years prior. Why is it a question of credibility? Anyone can come here and claim a high level of experience. The point is what Doug and Paul are telling you is contrary to the book. Steve, I would recommend you contact Doug and Paul directly (I will supply their contact info directly to you if desired). Perhaps you three could work it out and share what you discover with the pilots on this forum. It is distressing to me (although not unexpected) that something so fundamental as the question "Must a final approach be on the extended centerline to be considered a final?," is generating such confusion--especially in the ATC community. Let's work to get this resolved. There's nothing to be resolved. What Doug and Paul are telling you is contrary to FAA Order 7110.65. That makes them wrong. You wrote, "At 5 miles from the airport (still offset from the centerline), I report '5 mile final'." How did you measure your distance then? GPS in this case. The 5 miles I reported was accurate. The issue is whether I was "on final." No, it's not. You indicated in your first message that you were offset from the runway centerline by thirty degrees when you reported "5 mile final". You were not on final when you made that report. Do you consider yourself aligned with the runway when your nose is cocked 30 degrees from the centerline? Mabye. There is something called crab g. Let me rephrase the question. Do you consider yourself aligned with the runway when your track is 30 degrees from the centerline? Which means you haven't learned a thing from this discussion. So what then was your purpose in starting this thread? Well, please re-read my message again for my purpose. If your purpose was made clear in your message I wouldn't have had to ask the question. And, if you're implying that I can learn something ONLY if I agree with YOU, you're mistaken. Dare I say you might be able to learn something too? Gosh, how impudent of me. You insist your position is correct despite the fact that all pertinent documentation indicates you're wrong. That's why I asked. |
#77
"Jim Cummiskey" wrote in message news:XlrTc.37461$ih.19822@fed1read07... Actually, ATC Doug has a theory WHY she felt it was important for her to call it to my attention. According to Doug, KPRC is a training facility, and they have a lot of inexperienced controllers there undergoing training. As I reported earlier, there was no radio traffic (to my recollection) within five minutes either side of my initial radio call and my wheels touching down. Since I was responsible for my own separation, I was quite attentive to traffic. I don't think there was any other traffic in the entire Class D airspace. Doug thinks the controller was "pulling my chain"--perhaps ensuring I understood the domain of her authority on a slow Sunday morning. But, according to ATC Paul, the Tower Manager, HIS controller was absolutely WRONG! Does his vote count? Or, am I still just a troller? Some people just do not handle authority well, that may be the case with this controller. If there was no other traffic she had no reason to require you to adjust your flight path in any way. Perhaps that's what ATC Paul and ATC Doug mean when they say the controller was wrong. Nontheless, her instruction to report a five mile final was a valid one and you did not comply with it. So, yes Maria. I am very concerned about "not being wrong" when I fly. The consequences are too high. The point is: if it IS perfectly proper procedure to fly "angled finals" and report them as "finals," then shouldn't we pilots began to do a little better job of scanning the entire final quadrant vice only checking only the extended centerline? But it's not proper procedure to fly "angled finals" and report them as "finals". "Final" has a specific meaning and is defined in the Pilot/Controller Glossary to ensure pilots are on the same page when they use the term "final". So, it has nothing to do with the "semantics of the arguments." It has to do with coming up with a common language so that when a Controller says X, the Pilot understands X (and vice-versa). That's been done! It's in the P/CG! |
#78
"Jim Cummiskey" wrote in message news:3xqTc.37453$ih.9766@fed1read07... GB, the 45 degree cone Doug was referring to encompassed both sides of the extended centerline. A 45 degree cone encompassing both sides of the extended centerline would be offset 22.5 degrees from the centerline on each side. Your 30 degree offset put you outside of that. |
#79
"Jim Cummiskey" wrote in message news:YqrTc.37462$ih.26440@fed1read07... You're changing your story. In your initial message you wrote; "At 5 miles from the airport (still offset from the centerline), I report '5 mile final'." So which is it? Were you on final when you reported or were you offset from the centerline? Both. I WAS on Final, and I WAS offset from the centerline. What a concept! Impossible. If you're offset from the centerline you're not on final. You say that like it's a matter of opinion. It certainly appears to be on this forum (and unlike some of you "Final is A Single Degree" Club members, I at least understand your opinion). Do you understand mine? (as well as the opinons of those members of the ATC community that I am basing my position on)? It's not a matter of opinion. Others in this forum understand what "final" means, you clearly do not. |
#80
Oops, meant to say "the X-axis aligned at a 45 deg angle to the runway centerline). "Jim Cummiskey" wrote in message news:3xqTc.37453$ih.9766@fed1read07... GB, the 45 degree cone Doug was referring to encompassed both sides of the extended centerline. Imagine a large X and Y axis superimposed on any airport (with the X-axis aligned with the runway centerline). There are thus four quadrants. If at any time I am moving in respect to the airport in one of those quadrants, I will either be in a "downwind" general direction, a "base" direction, a "final/upwind" direction, and a "crosswind" direction. The "Final/Upwind" direction represents the domain of what consitutes a "final" in my way of thinking (which appears to be shared by at least three ATC controllers). If you approach an airport at 30 degrees off the extended centerline (something that I'm sure most of you have done thousands of times--as I have), what leg are you flying? Regards, Jim Ok, now you are saying 45 degrees each side of the extended centerline. So if then I call downwind the controller would say something like: " You are number 2, number one is a c172, between 10 and 2 oclock, 7 miles, do you have him in sight?" Well a pretty big slice of sky to look for you. Yes, you said there was no other traffic, but this is not the point. GB |
| Thread Tools | |
| Display Modes | |
| Emergency Procedures | RD | Piloting | 13 | April 11th 04 09:25 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| 12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 13th 03 12:01 AM |
| Rwy incursions | Hankal | Piloting | 10 | November 16th 03 03:33 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
