can't quite grasp the "power available" curve
Old September 12th 04, 02:33 AM
John T Lowry
The graph you referenced involves three different power (throttle)
settings, all at sea level. Keep in mind the airplane will be in level
flight ONLY at the two intersections of the Pr and Pa curves; in between
(Pa Pr), it will be climbing. (Outboard of those intersections, it
will be descending, unless stall conditions intervene, in which case it
will REALLY be descending!) Keep at it; this stuff will eventually make
common sense.
John Lowry
Flight Physics
"xerj" wrote in message
news
Thanks to both of you.
I'm getting closer to understanding, but a couple of things are still
eluding me:-
1) What happens to the curve with constant speed props?
2) I don't exactly know how to put this, but if a curve labelled "65%"
showed, say, 100HP at 60 kts and135HP at 120 kts, that means that the
35HP
difference is due to prop efficiency? The reason I say this is because
if
the entire curve represents a 65% setting then the power shouldn't
have
changed, right?
Thanks in advance, and much appreciated for the answers so far.
"Todd Pattist" wrote in message
"xerj" wrote:
I understand the "power required" curve as plotted against
velocity, but
concept of "power available" plotted against velocity is escaping
me.
How is this curve derived? And why is it "curved"?
In the aircraft we fly, the Pa curvature comes about from
prop efficiency and engine limitations. A prop is most
efficient when the prop airfoil is operating at it's best
L/D angle of attack. Any RPM slower or faster than the RPM
needed at the current airspeed to produce that AOA reduces
prop efficiency. Of course, changing the engine RPM changes
the power available from the engine.
At the upper speed end of the scale, the engine is operating
at redline, and the prop AOA has dropped to zero producing
zero thrust and zero power. Any faster and the engine
either overspeeds or the prop begins producing negative
thrust.
Todd Pattist
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Old September 12th 04, 12:33 PM
xerj
Thanks, John!
I'm making a conscious effort to finally understand stuff that I should have
had a better grasp on. Knowing ~why~ things happen is much better than just
knowing that they do.
"John T Lowry" wrote in message
k.net...
common sense.
John Lowry
Flight Physics
news
eluding me:-
35HP
if
have
changed, right?
velocity, but
me.
thrust.
Todd Pattist
___
eScrew zen story [email protected] Owning 0 December 20th 04 07:19 AM
Funny story about naval [email protected] Naval Aviation 0 December 20th 04 03:37 AM
Power management on a O-300 Victor Piloting 0 July 9th 04 01:09 AM
Landing patterns m pautz Piloting 31 June 18th 04 03:29 PM
Piper Pathfinder Article john smith Piloting 24 March 14th 04 01:04 AM
