Is it proper to multiply the mA rating x the number of batteries/cells?
like.. 2 1200 mA batteries would in theory take 12 hrs minimum? Dave Chris W wrote: RobsSanta wrote: My brain has totally gone blank for this simple question, I know I should have paid more attention in school !!!. I just was given a 12volt 1200mAh battery and a 200mh 3W wall charger by a friend who is quitting flying. It has been that long since he used the battery he doesn't remember charging times etc. For NiMH and NiCd, you take the battery capacity * 1.4 (I don't know where the 1.4 came from I just read it somewhere) and then divide it by the charge rate. That gives you the number of hours. So 1200 * 1.4 / 200 = 8.4 hours or 8 hours and 24 minutes. As others have said that is assuming the charger "really" puts out 200ma. If you have a good volt meter and can monitor the charge from time to time, when you slow charge a NiMH or NiCd battery the fully charged voltage should be about 1.45V/cell while it is on the charger. This voltage will drop to 1.3V/cell or so shortly after the charger is removed. So what I would do is record the voltage during charge every 20 or 30 min and if it reaches 1.45V/cell stop charging. If it seems to plateau at a slightly lower voltage then stop there. |
Dave S wrote:
Is it proper to multiply the mA rating x the number of batteries/cells? like.. 2 1200 mA batteries would in theory take 12 hrs minimum? if they hare in parallel yes the mAh rating goes up for the pack, but normally they are in series, so the pack voltage goes up and the mAh stays the same. -- Chris W Bring Back the HP 15C http://hp15c.org Not getting the gifts you want? The Wish Zone can help. http://thewishzone.com |
"Chris W" wrote in message
news:2n73d.69282$mu.28256@okepread07... if they hare in parallel yes the mAh rating goes up for the pack, but normally they are in series, so the pack voltage goes up and the mAh stays the same. He's asking about charging time, not battery life. |
Peter Duniho wrote:
"Chris W" wrote in message news:2n73d.69282$mu.28256@okepread07... if they hare in parallel yes the mAh rating goes up for the pack, but normally they are in series, so the pack voltage goes up and the mAh stays the same. He's asking about charging time, not battery life. I guess I wasn't very clear was I. If they are in parallel the mAh goes up and therefor the charging time when charging at a fixed mA rate. But in series the mAh doesn't go up so the charging time would stay the same. Of course your charger has to be able to put out a high enough voltage or the battery will never charge. -- Chris W Bring Back the HP 15C http://hp15c.org Not getting the gifts you want? The Wish Zone can help. http://thewishzone.com |
On Sat, 18 Sep 2004 23:46:03 -0500, Chris W
wrote: Peter Duniho wrote: "Chris W" wrote in message news:2n73d.69282$mu.28256@okepread07... if they hare in parallel yes the mAh rating goes up for the pack, but normally they are in series, so the pack voltage goes up and the mAh stays the same. He's asking about charging time, not battery life. I guess I wasn't very clear was I. If they are in parallel the mAh goes up and therefor the charging time when charging at a fixed mA rate. But in series the mAh doesn't go up so the charging time would stay the same. Of course your charger has to be able to put out a high enough voltage or the battery will never charge. This thread is getting confusing! EACH BATTERY (NiCAD or NiMH) requires to be charged at an equivalent to 40% to 60% more than their capacity, because they are not 100% efficient. As you have all the batteries in series you chage at about 1200/200 = 6 hours plus 40 to 60% = 2.4 to 3.6 hours extra. Personally I would use 40% to 50% since any battery overcharged will have a shorter life if charged at more than 10% of its rated capacity, i.e. greater than 120mA in your case. I seem to remember that Nicads can be overcharged for abut 100 hours as long as you don't exceed 7% of their capacity rating for charge current. That is not usually an option these days as many fast chargers have built in sensing to detect when fully charged. David E-mail (Remove Space after pilot): pilot |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
Battery Replacement and Cold Cranking Amps | O. Sami Saydjari | Owning | 27 | February 2nd 04 02:38 PM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
ICom A-5 Question - Battery Level Indicator | Harry Gordon | Piloting | 22 | December 5th 03 12:07 AM |
