On Fri, 5 Nov 2004 at 11:16:17 in message
, Todd Pattist wrote: David CL Francis wrote: That does not answer the fact that the original statement by John appears to me to be wrong. It's not wrong. Nice to meet you here again Todd. I agree I was wrong, in that the problem he postulated was different from what I assumed. I think my calculations were right though. I apologise to those concerned However John's actual statement now I read it more carefully seems to imply that given the wind speed you must find the TAS at which you must fly to get there in an hour! Is this the calculation that is intended? Even more trivial than my calculations! John wrote: "A trip of 100 nm over the ground, in an hour, if into a 10 knot direct headwind, would be a trip of 110 nm relative to still air." Thus we have an unknown cruise TAS cruise speed Let that be V We have a 100 nm distance and a head wind of 10k We have a time of flight of exactly one hour Therefore 100/(V-10)= 1 and V -10 = 100 it follows that V = 110k So at a TAS of 110k you travel a ground distance of 100nm against a wind of 10k and surprise, surprise you than fly 110 'air' nm More or less self evident so I am unclear what that achieves? You're wrong, here's why: You wrote : "Aircraft flying at 200k effective speed over the ground 190 knots Time taken = 100/190 = 0.5263157 hours Effective distance at 200k TAS is 200*0.5263157 = 105 .26 nm" That is still mathematically correct I hope? John assumed an airspeed that would take 1 hour exactly to fly 100nm in one hour into a 10 knot headwind. During that hour, the air moved 10 nm so the aircraft covered 110nm of air and 100 nm of ground. So he did, but that means he is implying a cruise speed that will get you there in one hour. Perhaps I am naive but it seemed to me you needed to calculate the effect of head winds on a given cruise speed not a cruise speed to give constant time? So if your aircraft had to fly against a 50k wind it simply has to increase its cruise speed to 150k and it covers a 100nm in one hour just the same. Is that useful thing to know? In that case it is of course true that the aircraft would have covered 150 'air' miles. You assumed a speed that would take 1 hour to fly 100nm in no wind, and then calculated the time. (actually you chose 200 knots, I'm not sure why). The assumptions were different. For John's case, the aircraft was not flying 100 knots - it was flying at 110 knots and covered 110 air nm and 100 ground nm. I chose three different speeds I believe, 200k, 50k and 1000k just to show the differences. I apologise again to those concerned for my error in reading the original statement.. More interesting would be to know the galls per hour consumed at various speeds and then create a table of cruise speeds against head wind components (Positive or negative) and then determine the best cruise speed for each wind speed for minimum Gallons per mile perhaps? -- David CL Francis |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
JET99 is growing at an amazing rate! Join for CASH & Air Miles | PBoyd77443 | Home Built | 1 | July 18th 04 04:10 PM |
presidential TFR - 3,291 statute miles square! | Larry Dighera | Piloting | 47 | June 15th 04 06:08 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
metric system newsgroup call for votes #1 | Paul Hirose | Military Aviation | 72 | November 16th 03 06:59 PM |
