			 Does anyone know the exact conversion in feet for a minute of latitude and longitude? I find this on the web: Latitude: 3.64 feet per 0.00001 degree, 6.06 feet per 0.001 minute, 10.10 feet per 0.1 second, 101.1 feet per second, 6066.7 feet per minute. Longitude: 3.04 feet per 0.00001 degree, 5.07 feet per 0.001 minute, 8.45 feet per 0.1 second, 84.5 feet per second, 5066.7 feet per minute. But I am scratching my head over the longitude! Doesn't a minute of longitude depend on your location between the pole and the equator? all the best -- Dan Ford email: (put Cubdriver in subject line) Warbird's Forum www.warbirdforum.com Piper Cub Forum www.pipercubforum.com the blog www.danford.net  |
			 Okay, here's a more convincing exegesis, also found on the web (Google is your friend!): ************************************************** ************************** A degree of latitude is 60 nautical miles, or 69.04 statute miles. A minute of latitude is equal to one nautical mile, or 6076 feet; thus, a second of latitude (6076 divided by 60) is 101 feet, 3 inches. Conceptually and practically, latitude is the same no matter where you go on earth; however, in reality it varies from 69.41 statute miles per minute at the poles to 68.70 statute miles per minute at the equator due to the earth bulging slightly from its rotational spin. Longitude, of course, varies in length according to degree of latitude. The following is a sampling of longitude lengths for selected latitudes, beginning in the southern US and working north. 30 degrees North, (approximately Houston, Texas) a degree of longitude is 59.96 statute miles, 5274 feet per minute (almost equal to a statute mile), 88 feet per second. 35 degrees North, (approximately Albuquerque, New Mexico) a degree of longitude is 56.73 statute miles, 4992 feet per minute, 83.2 feet per second. 40 degrees North, (Kansas/Nebraska border), a degree of longitude is 53.06 statute miles, 4669 feet per minute, 77.8 feet per second. 45 degrees North, (Montana/Wyoming border), a degree of longitude is 49.00 statute miles, 4312 feet per minute, 71.87 feet per second. 49 degrees North (US/Canada national boundary), a degree of longitude is 45.40 statute miles, 3995 feet per minute, 66.59 feet per second. 50 degrees North (approximately Powell River, BC, Medicine Hat, Alberta, and Winnipeg, Manitoba), a minute of longitude is 44.55 statue miles, 3920 feet (1195 meters) per minute, 65.34 feet (19.9 meters) per second. 55 degrees North (approximately Ketchikan, Alaska and Dawson Creek, BC) a degree of longitude is 39.77 statute miles, 3500 feet (1066.8 meters) per minute, 58.33 (17.78 meters) per second. Finally, 60 degrees North (southern border of the Northwest Territories), a degree of longitude is 34.67 statute miles, 3051 feet (930 meters) per minute, 50.85 feet (15.5 meters) per second. Whew! (grin) Had enough? I know I have! Hope this helps. ************************************************** ******************** A tip of the virtual hat to "Senty" at http://www.hypernews.org/HyperNews/g.../1.html?nogifs On Mon, 08 Nov 2004 06:30:33 -0500, Cub Driver wrote: Does anyone know the exact conversion in feet for a minute of latitude and longitude? I find this on the web: Latitude: 3.64 feet per 0.00001 degree, 6.06 feet per 0.001 minute, 10.10 feet per 0.1 second, 101.1 feet per second, 6066.7 feet per minute. Longitude: 3.04 feet per 0.00001 degree, 5.07 feet per 0.001 minute, 8.45 feet per 0.1 second, 84.5 feet per second, 5066.7 feet per minute. But I am scratching my head over the longitude! Doesn't a minute of longitude depend on your location between the pole and the equator? all the best -- Dan Ford email: (put Cubdriver in subject line) Warbird's Forum www.warbirdforum.com Piper Cub Forum www.pipercubforum.com the blog www.danford.net all the best -- Dan Ford email: (put Cubdriver in subject line) Warbird's Forum www.warbirdforum.com Piper Cub Forum www.pipercubforum.com the blog www.danford.net  |
Cub Driver ) wrote:
	: : Does anyone know the exact conversion in feet for a minute of latitude and : longitude? : : But I am scratching my head over the longitude! Doesn't a minute of : longitude depend on your location between the pole and the equator? You plug the latitude into the cosine function and that gives you a factor to tell you how short the longitide is. cos(0)=1 cos(90)=0 cos(60)=.5 So if one minute (1/60th of a degree) is one nmi at the equator, then at poles its 1*cos(90)=0 or at 60 degrees north (or south) its 1*cos(60)=.5 Google claims 1 nautical mile = 6 076.11549 feet so at 60 degrees it should be about 3038 feet. -tim http://web.abnormal.com  |
On Thu, 11 Nov 2004 at 06:35:23 in message
	, Tim Hogard wrote: Google claims 1 nautical mile = 6 076.11549 feet so That's right it is the international nautical Mile, which is exactly 1,852 metres I am not sure if the UK nm still exists - that was 6080 ft. Does anyone know how the UK came to have their own version? I assume it has disappeared but I am not sure when it did. -- David CL Francis  |
			 David CL Francis wrote: I am not sure if the UK nm still exists - that was 6080 ft. Does anyone know how the UK came to have their own version? I assume it has disappeared but I am not sure when it did. According to a reference I found on British measurements, the nautical mile is -- "Unit of length, normally at sea or in the air. Originally, the Admiralty fixed it at 6080 feet. This unit is universally used by international law by ships and aircraft, as is the derived unit of the knot. In the 20th century, an international nautical mile was defined as 1852 metres, and so you will sometimes see the 6080ft nautical mile called the British nautical mile." So it would seem that the international nautical mile is not used for navigation. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it.  |
| Thread Tools | |
| Display Modes | |
| Reno Air Races -- 2600 Miles in 2 Days! | Jay Honeck | Piloting | 88 | September 25th 04 04:48 PM |
| Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 03:54 AM |
| Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) | Peter Stickney | Military Aviation | 45 | February 11th 04 05:46 AM |
| Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 09:52 PM |
| Ta-152H at low altitudes | N-6 | Military Aviation | 16 | October 13th 03 04:52 AM |
