Boundaries of airspace?
Old January 4th 05, 08:04 AM
Anti-Death-Spec
I was bored tonight and did a search and look what I found.
http://ntl.bts.gov/lib/000/200/254/911.pdf. I didn't even know this existed.
pretty cool!!
A
"Paul Tomblin" wrote in message
Is there a file (other than DAFIF) which has the coordinates of the
boundaries or extents of class B, C, D, E airspace? I can't find anything
in the FAA standard data files. SUA.txt only seems to have things like
MOAs and restricted areas.
Paul Tomblin http://xcski.com/blogs/pt/
Do you have a point, or are you saving it for a special occasion?
-- David P. Murphy
Old January 4th 05, 12:15 PM
Paul Tomblin
pretty cool!!
But nothing in a machine readable format, eh? That's what I figured.
I don't see what C++ has to do with keeping people from shooting themselves
in the foot. C++ will happily load the gun, offer you a drink to steady
your nerves, and help you aim. -- Peter da Silva
Old January 4th 05, 04:31 PM
Stan Prevost
Great! Thanks for finding the link.
I wrote down the procedure I used to find updates to a specific airspace
entry. I haven't checked to see if the link is still correct. Too bad the
FAA won't keep a current copy available.
All changes to airspace must be published in the Federal Register, so you
can find any updates there. .
Go to http://www.access.gpo.gov/su_docs/aces/aces140.html to search the
Federal Register.
Check all the FR volumes, check "Final Regulations". In the Date field, use
"Before" 01/01/2100. In the Search Terms box I used
"14 CFR Part 71" AND Huntsville
(substitute for Huntsville the city or airport or airway you are searching
for information about. If it's more than one word, enclose in double quote
marks).
I believe this will find all changes to the Order for the entity you are
concerned with.
"Anti-Death-Spec" wrote in message
news:e6sCd.12326$sf5.3753@lakeread05...
existed. pretty cool!!
A
anything
-- David P. Murphy
Negative XPDR - under the outer ring of Class C bcjames Piloting 8 August 30th 04 11:49 PM
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Piloting 12 April 26th 04 06:12 PM
Violating Airspace with GPS John Bell Piloting 57 November 5th 03 08:25 PM
