Are you saying they're better or worse? The numbers I've been using
for my calcs are 2 stroke (BSFC .6-.65) versus 4 stroke (BSFC .4-.5). Thats a worst case of 62% more fuel and a best case of 20% more ignoring my point that a lesser horsepower engine is needed to fly the same load. If you could fly the same payload with a 50hp 2-stroke powered purpose built plane as an 80hp 4-stroke powered plane, you'd be even on fuel consumption. Going on the other poster's 4 hour number assuming same plane weight, just different engine weight, the advantage of carrying fuel weight versus engine weight are several: 1) Flexibility of changing fuel load depending on flight plan (no option of carrying half an engine for 4 stroke) 2) Fuel load can be bore in wings, doesn't increase bending loads and require stronger/heavier structure. 3) Could theoretically be jetisoned in the event of a forced landing. 4) Lower average and landing weight as fuel is depleted during course of trip. 5) Lower initial investment (smaller engine plus fuel later vs. larger engine now, less fuel later) Matt Whiting wrote in message ... Jay wrote: Yes, the 2 stroke burns 50% more fuel for the same HP, but the point I was trying to make was that since the 2 stroke powered aircraft can be built lighter all around (on account of its lighter engine), you can use a smaller engine (which consumes less fuel) and still fly the same payload. This relationship is unique to aircraft since weight means SO much. Except that they don't burn 50% more fuel for the same horsepower. Matt |
Lowest cost per mile flown motor- 2 stroke | Bruce A. Frank | Home Built | 0 | July 2nd 03 06:25 AM |
