#11
Ken Duffey wrote: L'acrobat wrote: "Ken Duffey" wrote in message ... The Centurions had RR Meteor engines - and if they had only had a common parts nomenclature/numbering system, the Aussie could have supplied the Yanks with parts! It was not until the beginning of 1952 that the Australian Army finally received it's first Centurion tanks. These first tanks were given to 1 Armoured Regiment. How about the Comet tank - what engine did that have - and did the Aussies use it - and was it in Korea ?? Comet had the Meteor. -- Andy Breen ~ Interplanetary Scintillation Research Group http://users.aber.ac.uk/azb/ "Time has stopped, says the Black Lion clock and eternity has begun" (Dylan Thomas) |
"ANDREW ROBERT BREEN" wrote in message ... In article , Ken Duffey wrote: L'acrobat wrote: "Ken Duffey" wrote in message ... The Centurions had RR Meteor engines - and if they had only had a common parts nomenclature/numbering system, the Aussie could have supplied the Yanks with parts! It was not until the beginning of 1952 that the Australian Army finally received it's first Centurion tanks. These first tanks were given to 1 Armoured Regiment. How about the Comet tank - what engine did that have - and did the Aussies use it - and was it in Korea ?? Comet had the Meteor. Australia never used the Comet |
L'acrobat wrote:
"ANDREW ROBERT BREEN" wrote in message ... In article , Ken Duffey wrote: L'acrobat wrote: "Ken Duffey" wrote in message ... The Centurions had RR Meteor engines - and if they had only had a common parts nomenclature/numbering system, the Aussie could have supplied the Yanks with parts! It was not until the beginning of 1952 that the Australian Army finally received it's first Centurion tanks. These first tanks were given to 1 Armoured Regiment. How about the Comet tank - what engine did that have - and did the Aussies use it - and was it in Korea ?? Comet had the Meteor. Australia never used the Comet OK - some tank regiment somewhere, equipped with some tanks powered by RR Meteor engines, were stationed in the next valley to an air force squadron of planes powered by Packard Merlins. If only they'd known that it was essentially the same engine - they could have swapped parts and prevented the air force squadron from being grounded due to lack of spares. Will that do ?? ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ Ken Duffey - Flanker Freak & Russian Aviation Enthusiast Flankers Website - http://www.flankers.co.uk/ ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++ |
"Ken Duffey" wrote in message ... L'acrobat wrote: "ANDREW ROBERT BREEN" wrote in message ... In article , Ken Duffey wrote: L'acrobat wrote: "Ken Duffey" wrote in message ... The Centurions had RR Meteor engines - and if they had only had a common parts nomenclature/numbering system, the Aussie could have supplied the Yanks with parts! It was not until the beginning of 1952 that the Australian Army finally received it's first Centurion tanks. These first tanks were given to 1 Armoured Regiment. How about the Comet tank - what engine did that have - and did the Aussies use it - and was it in Korea ?? Comet had the Meteor. Australia never used the Comet OK - some tank regiment somewhere, equipped with some tanks powered by RR Meteor engines, were stationed in the next valley to an air force squadron of planes powered by Packard Merlins. If only they'd known that it was essentially the same engine - they could have swapped parts and prevented the air force squadron from being grounded due to lack of spares. Will that do ?? Yes thats accurate. but somehow the story lacks the same zing... |
Ken Duffey writes: L'acrobat wrote: Australia never used the Comet OK - some tank regiment somewhere, equipped with some tanks powered by RR Meteor engines, were stationed in the next valley to an air force squadron of planes powered by Packard Merlins. If only they'd known that it was essentially the same engine - they could have swapped parts and prevented the air force squadron from being grounded due to lack of spares. Will that do ?? Well, now that we've got that sorted out, No, I don't think that it would help, actually. Well, they may be able to trade Whitworth Thread bolts, but stuff like Carburetors, and the oterh accessory stuff would be differnt. (V1650s used Bendix-Stromberg Pressure Carbs, IIRC, the Meteor uses an SU. The Packard has a differnt back end, with the wheelcase for the blower on it, and a different front end with the propeller gearbox. The airplane engine had vacuum pumps, hydraylic pumps, and a 24V generator all hooked to the engine, and all of those would be different. Pistons, cranks, & conrods may be similar in dimension, but given Roll's penchant for sloppy manufacturing tolerances and hand-fitting parts, I don't know if Rover, who swapped Whittle Turbojet production to Rolls for the Meteor plant, improved that particular situation. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
"L'acrobat" wrote in message
... "Ken Duffey" wrote in message ... L'acrobat wrote: "ANDREW ROBERT BREEN" wrote in message ... In article , Ken Duffey wrote: L'acrobat wrote: "Ken Duffey" wrote in message ... The Centurions had RR Meteor engines - and if they had only had a common parts nomenclature/numbering system, the Aussie could have supplied the Yanks with parts! It was not until the beginning of 1952 that the Australian Army finally received it's first Centurion tanks. These first tanks were given to 1 Armoured Regiment. How about the Comet tank - what engine did that have - and did the Aussies use it - and was it in Korea ?? Comet had the Meteor. Australia never used the Comet OK - some tank regiment somewhere, equipped with some tanks powered by RR Meteor engines, were stationed in the next valley to an air force squadron of planes powered by Packard Merlins. If only they'd known that it was essentially the same engine - they could have swapped parts and prevented the air force squadron from being grounded due to lack of spares. Will that do ?? Yes thats accurate. but somehow the story lacks the same zing... BTW someone who owns a airworthy Merlin suggested the Meteor engine may contain steel parts. He didn't elaborate but there was a hint that the block may be something other than aluminum. |
Wasn't the Merlin an inline piston engine and the meteor engine a gas
turbine engine.the two have to be totally dissimilar....mjh -- "The Raven" wrote in message ... Can anyone tell me how similar these engines were to the Merlin? I know they were a derivative but being intended for ground use may be so totally different as to be useless for any aviation application. Why do I ask? An acquaintance has just acquired a complete Meteor engine and is looking to sell it off. I don't believe he wants to profit from it beyond recovering costs. If the engine is valueless or he can't find a buyer there is a possibility (slim) it may be scrapped. However, it would be better if someone would purchase the engine and put it back into one of it's intended applications. If anyone is interested in the engine, even for parts, please post a response here and I will pass it on to him. For those interested, the engine is in Canada (despite me being in Australia). -- The Raven http://www.80scartoons.co.uk/batfinkquote.mp3 ** President of the ozemail.* and uunet.* NG's ** since August 15th 2000. |
"Mike Hide" wrote in message
news:b0jXb.308382$xy6.1503503@attbi_s02... Wasn't the Merlin an inline piston engine and the meteor engine a gas turbine engine.the two have to be totally dissimilar....mjh The Rolls Royce Merlin (including all license built models) was a V12 engine. Used in such aircraft as the Lancaster and P-51 Mustang. The Rover Meteor engine is a derivative of that engine and saw application in the Centurion tank. I think you're associating the name Meteor with the Gloster Meteor jet aircraft (which had turbines). -- The Raven http://www.80scartoons.co.uk/batfinkquote.mp3 ** President of the ozemail.* and uunet.* NG's ** since August 15th 2000. |
In article b0jXb.308382$xy6.1503503@attbi_s02,
Mike Hide wrote: Wasn't the Merlin an inline piston engine and the meteor engine a gas turbine engine.the two have to be totally dissimilar....mjh The Rolls-Royce Merlin was a V12 piston engine, as was the (directly derived from the Merlin) Rover Meteor tank engine. The Gloster Meteor aeroplane was pwered variously by Rolls-Royce Welland or Derwent, Halford H1 (De Havilland Goblin) or Metrovick M2 turbojets or - in one case - Rolls-Royce Trent turboprops. -- Andy Breen ~ Interplanetary Scintillation Research Group http://users.aber.ac.uk/azb/ "Time has stopped, says the Black Lion clock and eternity has begun" (Dylan Thomas) |
"Mike Hide" wrote in message news:b0jXb.308382$xy6.1503503@attbi_s02... Wasn't the Merlin an inline piston engine and the meteor engine a gas turbine engine.the two have to be totally dissimilar....mjh You have misunderstood I fear. The Rolls Royce Meteor was a derivative of the Merlin inline piston engine abd was used in armoured fighting vehicles The GLOSTER Meteor used various engines including Rolls Royce Derwents Keith |
| Thread Tools | |
| Display Modes | |
| Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 04:27 PM |
| Diesel engine | Bryan | Home Built | 41 | May 1st 04 08:23 PM |
| Emergency Procedures | RD | Piloting | 13 | April 11th 04 09:25 PM |
| Rolls Royce Meteor V 2 engine from a Centurion tank | The Raven | Military Aviation | 18 | February 14th 04 09:04 PM |
| What if the germans... | Charles Gray | Military Aviation | 119 | January 27th 04 12:20 AM |
