On Tue, 7 Oct 2003 23:03:16 +0100, "Mark Cherry"
wrote: In other words, you need to create a 'restore point' before starting the install procedure? Whenever I update XP it automatically creates a restore point. I find that I can back out of individual changes, even when they were done during the same update session. |
On Wed, 08 Oct 2003 03:06:05 GMT, ArtP
wrote: On Tue, 7 Oct 2003 23:03:16 +0100, "Mark Cherry" wrote: In other words, you need to create a 'restore point' before starting the install procedure? Whenever I update XP it automatically creates a restore point. I find that I can back out of individual changes, even when they were done during the same update session. So how do I create a restore point, if XP doesn't? |
On Wed, 08 Oct 2003 01:08:23 -0400, John Penta
wrote: So how do I create a restore point, if XP doesn't? Start, Programs, Accessories, System Tools, Restore System, Create Restore Point, Next ... |
On Wed, 08 Oct 2003 10:06:21 GMT, ArtP
wrote: On Wed, 08 Oct 2003 01:08:23 -0400, John Penta wrote: So how do I create a restore point, if XP doesn't? Start, Programs, Accessories, System Tools, Restore System, Create Restore Point, Next ... Thanks!:-) I now feel slightly less stupid and ashamed of myself for missing the utterly obvious.:-) |
In ,
ArtP wrote: On Tue, 7 Oct 2003 23:03:16 +0100, "Mark Cherry" wrote: In other words, you need to create a 'restore point' before starting the install procedure? Whenever I update XP it automatically creates a restore point. I find that I can back out of individual changes, even when they were done during the same update session. Thanks. I'm learning all of this, after shifting from Win98! Before I'd reached 'disaster area' point, culminating in returning the box to the shop for a full XP reinstall, I made numberous program and driver installs but, on peeking at system restore, only found restore points dating from where the retailer had done the initial installations. Is there a setting I'm missing somewhere? -- Happy landings Mark ~~~~~~~~~~~ MS FS2002 Pro Edition P4 3.06gHz (800fsb); 512Mb DDR non-ECC; Maxtor 200gb ATI Radeon 9200 256Mb dual head; 15" FST monitor all on a MSI 865PE Neo2 m/b Microsoft SideWinder Precision Pro (USB) CH Virtual Pilot Pro {*} Thrustmaster Elite Pedals {*} Quickshot MasterPilot CD-RW 52x..... DVD-ROM DX9.0 (not 9.0a or 9.0b) {* via a gampeport-USB adaptor, currently knobbled by XP and reduced to 4 buttons, instead of 14) Solutions welcome |
On Thu, 9 Oct 2003 19:51:20 +0100, "Mark Cherry"
wrote: Before I'd reached 'disaster area' point, culminating in returning the box to the shop for a full XP reinstall, I made numberous program and driver installs but, on peeking at system restore, only found restore points dating from where the retailer had done the initial installations. Is there a setting I'm missing somewhere? Start, Programs, Accessories, System Tools, Restore System, System Restore Settings |
There are programs, such as DirectXBuster, which will uninstall DX, then
install from your windows disk (or you can manually reinstalll) I needed to do this as something weird happended with my Dx9, HTH "ArtP" wrote in message ... On Thu, 9 Oct 2003 19:51:20 +0100, "Mark Cherry" wrote: Before I'd reached 'disaster area' point, culminating in returning the box to the shop for a full XP reinstall, I made numberous program and driver installs but, on peeking at system restore, only found restore points dating from where the retailer had done the initial installations. Is there a setting I'm missing somewhere? Start, Programs, Accessories, System Tools, Restore System, System Restore Settings |
In ,
Angus Lepper wrote: There are programs, such as DirectXBuster, which will uninstall DX, then install from your windows disk (or you can manually reinstalll) I needed to do this as something weird happended with my Dx9, HTH "ArtP" wrote in message ... On Thu, 9 Oct 2003 19:51:20 +0100, "Mark Cherry" wrote: Before I'd reached 'disaster area' point, culminating in returning the box to the shop for a full XP reinstall, I made numberous program and driver installs but, on peeking at system restore, only found restore points dating from where the retailer had done the initial installations. Is there a setting I'm missing somewhere? Start, Programs, Accessories, System Tools, Restore System, System Restore Settings Sounds a bit drastic but it obviously worked for you. I gather that there were some glitches in the first release of DX9, hence 9.0a & b. Does anyone know if these are incremental patches or whether 'b' also contains the fixes present in 'a'? -- Happy landings Mark |
Usually MS patches are not incremental - b should contain everything a had.
Mark Cherry wrote: In , Angus Lepper wrote: I gather that there were some glitches in the first release of DX9, hence 9.0a & b. Does anyone know if these are incremental patches or whether 'b' also contains the fixes present in 'a'? --? Happy landings Mark -- Brett I. Holcomb Microsoft MVP AKA Grunt Remove R777 to email |
In ,
ArtP wrote: On Thu, 9 Oct 2003 19:51:20 +0100, "Mark Cherry" wrote: Before I'd reached 'disaster area' point, culminating in returning the box to the shop for a full XP reinstall, I made numberous program and driver installs but, on peeking at system restore, only found restore points dating from where the retailer had done the initial installations. Is there a setting I'm missing somewhere? Start, Programs, Accessories, System Tools, Restore System, System Restore Settings Thanks, Art. I'll give it a try. -- Happy landings Mark |
