Video Card overheating???
Old February 12th 04, 06:25 AM
Ludlow Johnson
Default Video Card overheating???
Posting ealier about FS04 pc choice.
Got new PC and then it started to crash (2days old)
Tech support says overheating......return for repair/replacement
Really ticked me off, becasue FS was just gangbusters on the new PC.
Rendering was really good and the controls were more realistic.
Is a frame rate of 60-65 about what you would expect??
Funny thing though, I found that night landings were much easier with
the new graphics.
I guess if spend enough $$$, things should get better.
This is my first pc with independant video/sound cards.
Is overheating an issue with these new powerful 3D type cards??
Old February 12th 04, 11:36 AM
Peter Hovorka
Hi Ludlow,
Energy consumptions of modern high end cards is really high - as is the
net amount of heat that must be lead away from the card.
Overheating is a problem - after failure of the cooling devices or in
systems which are generally designed 'on the edge'.
I can't determine the cause for your problems being remote from the
machine, but you generally do well buying non-discount PCs - their heat
management is - generally speaking - a lot better whilst producing less
noise emissions.
Best regards,
Peter
Old February 12th 04, 03:42 PM
Ed Medlin
Got new PC and then it started to crash (2days old) Tech support says
Rendering was really good and the controls were more realistic. Is a frame
rate of 60-65 about what you would expect?? Funny thing though, I found
that night landings were much easier with the new graphics.
This is my first pc with independant video/sound cards. Is overheating an
I would suspect that the overheating was probably CPU related rather than
video card related. Most all of the newer video cards have sufficient
cooling solutions and decent PCs will have good ventilation. If you are
getting 60-65fps, you might want to turn down the target frame rate and
turn up the video goodies. Crank up the eye-candy and set your target at
25fps or so and you will see a lot more of what FS2004 has to offer.
Ed
Old February 22nd 04, 01:02 AM
Debug
"Ed Medlin" wrote in message
news
Ed
It might not be overheating at all. Could very well be an insufficient
powersupply causing the crashing. When vid cards overheat you usually see
some screen artifacts first.
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 5th 04 12:55 AM
AOPA VISA card fraud via XM Radio? Dan Luke Piloting 5 July 5th 04 07:38 PM
Video and Memory Card upgrade? Dave Schwartz Simulators 3 January 3rd 04 01:14 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
Which Video Card? Anthony Acri Simulators 1 July 16th 03 04:12 AM
