Well, it's not an 'award' that I particularly relish, to be sure, but
when one does dumb things, hey, you pass on the experiences when the zeal to get going totally overrides both common sense and the HITK [read: Head In The Keester!] syndrome. Recognizing that the RAS newsgroup has both experienced old-hands --and-- most likely new folks to the hobby, well, if I save the newbies some grief I'll do a form of active penance so to speak...which is of interest in itself since I'm a agnostic! Anyway, to business: I already mentioned the Nvidia driver thing and I'll repeat that this was 'not' a matter of making any technical declaration! I don't know why it worked [tinkering with the drivers as explained in the post] and thus I could only speak positively about the 'results' and not the 'why' of it! So here goes... First 'bonehead' move in terms of flight sim zeal to get going taking precedence over common sense: For some time I was using the CH Virtual Pilot Pro yoke with excellent results. Then comes the advent of the newer motherboards offering support for 800MHz FSB and related updated goodies but what's this after I put the thing together [with a now greatly reduced in price P4 Intel 3.02 gig [w/800 FSB] CPU with hyperthreading ], where's the 15 pin gameport 'socket' in which to connect the yoke? Yeah...various of the updated mb's don't have them in favor the latest thing, USB slots! So, ahhhhhh, why not go for the equally updated CH USB yoke with the 3 levers for throttle, prop and mixture! So I did and caught a great sale to boot and XP recognized the yoke instantly. Box comes with a driver disk for those 'not' using Windows XP [I use XP-Pro] and that's it....no other instructions no doubt on the theory that one savvies the controls. Cutting to the chase...6 take-offs, ALL aborted because of engine failure! Hours of checking and re-checking as to what possibly could be wrong! Are you ready? And THIS from someone who can trace his sim roots back to FS5 for crying out loud...take a wild guess who stupidly...yes, STUPIDLY, forgot to ADVANCE both the prop and mixture levers on the yoke! Even in the real McCoy, it should have dawned on me immediately that the throttle is a 'push' and the prop/mixtures are a 'pull' ! Hence, and with the prop and mixture levers 'not' being placed 'to the wall' as they say or pushed FORWARD before flight, the plane simply died from sim pilot error! In effect, when I advanced the throttle to take off, the plane labored because the prop pitch was 'reversed' and the mixture was 'lean' and so it sputtered out shortly after take-off! Dumb, yes? Yes. :-( So, newbies, throttle lever back and the other two [prop and mixture] fully forward! Talk about haste and zeal taking over! Whew! And this! Periodic system shutdowns no matter where from program to Internet to whatever! Baffling! Things checked out OK including any heat issues with the CPU, coolers, etc. Sometimes a plane simply sitting on the runway for perhaps 5 minutes or so [hey, when nature calls!], come back, system restart! So I finally decided to READ all that fancy system program data that breaks down with facts and data on literally everything from CPU to CD to DVD to machine memory to you-name-it and while reviewing my memory [two PC3200 3.0 CAS DDR 184 pin modules] I read in the data area, "...does NOT support Bank 4 Interleave...] although I had it set for 'Bank 4' in BIOS because most places you go suggest to use that [versus Bank 2 or disabled] for 'faster response' but the memory was 'not' [per the data] Bank 4 Interleave [whatever that does!?] compliant and when I disabled the interleave, I've had no problems since 'nor' any disernible loss of overall machine speed whatsoever. As a check, I fired up FS04 and left the plane just sitting there running for 20 minutes or so...fine...where before the machine would have re-started within 10 minutes. Cure? I simply remained within the specs of my memory...while awaiting, BTW, for April 14 for the release of Kingston's 'PC3200' DDR HyperX memory which they ran a 'promo' and $50 off because 'PC3200' HyperX DDR memory , specifically, at 'that' speed, will not be available from Kingston until April 14th while other memory speeds have already been on the market. And finally this...do NOT trust those clamps [metal or plastic] on the CPU/Heat Sink thing. BE ABSOLUTELY SURE the heat sink FULLY makes contact with the CPU and 'then' apply the normal requisite pressure to seat the fan/heat sink and metal/plastic clamp assembly! If the heat-sink does not sit perfectly square on the CPU, you're just begging for heat issue troubles...and a high reading for CPU temps! If you're in the 50's [degrees] CELSIUS range or over 115+ degrees FAHRENHEIT, check your heat-sink seating [might be worth another dose of Arctic Silver or whatever you use between the CPU and heat-sink] and the CPU fan RPM! And careful with the Intel supplied plastic clamp to hold everything in place ..they snap 'VERY' easily or usually one of the L/R retaining levers pops out and then you get uneven pressure on the CPU [if you're tempted to let it go figuring one lever 'looks' secure enough] and heat-sink! Careful! There you have it! Doc Tony |
Some people like to see themselves "in print".
Some people shouldn't be allowed to have computers. |
![]() Greasy wrote: Some people like to see themselves "in print". Some people shouldn't be allowed to have computers. Then again, some folks are immune to errors, even dumb ones, which they feel are for the others...you know, the great unwashed as they perceive them. Explains too why certain of the flock who 'do' know better view errors as 'so' elementary as to be unworthy of comment! It happens! These types are found mostly in the blowhard and, shall we say, Ex Cathedra category who would deign to figure it out themselves over days if necessary rather than ask or, gasp, publicly look like the proverbial uninitiated. Their usual claim is that their savvy comes from books and tinkering because admitting to the helping hand is both beyond their personality or they take the position that 'they' figured it out so let others follow the same course. A matter of philosophy actually. Now me, hey, if ONE passing soul gains from the info, why not! And you? I mean other than belching and wallowing in same forthwith. Perhaps that goes with the moniker, yes? Doc Tony ;-) |
Dr. Anthony J. Lomenzo wrote:
Greasy wrote: nothing worth repeating. Perhaps that goes with the moniker, yes? Parry & touche' monsieur Pussacat!! Score at the end of the half: Doc Tony 1 Greasy 0 Cheers'n Beers.. [_]) Don |
Greasy wrote: Some people like to see themselves "in print". Some people shouldn't be allowed to have computers. Then again, some folks are immune to errors, even dumb ones, which they feel are for the others...you know, the great unwashed as they perceive them. Explains too why certain of the flock who 'do' know better view errors as 'so' elementary as to be unworthy of comment! It happens! SNIP He had no idea what you just said. ![]() -- |
Hi Doc,
Hehe, always an adventure redaing your posts, and, BTW, great to see you posting again! :-) Are you sure you weren't tempted to have a crack at o/clocking your new system just a "tad', just to see how far she'd go, and you're just not admitting it to us all here? :-)) Regards, John "Dr. Anthony J. Lomenzo" wrote in message ... Well, it's not an 'award' that I particularly relish, to be sure, but when one does dumb things, hey, you pass on the experiences when the zeal to get going totally overrides both common sense and the HITK [read: Head In The Keester!] syndrome. Recognizing that the RAS newsgroup has both experienced old-hands --and-- most likely new folks to the hobby, well, if I save the newbies some grief I'll do a form of active penance so to speak...which is of interest in itself since I'm a agnostic! Anyway, to business: I already mentioned the Nvidia driver thing and I'll repeat that this was 'not' a matter of making any technical declaration! I don't know why it worked [tinkering with the drivers as explained in the post] and thus I could only speak positively about the 'results' and not the 'why' of it! So here goes... First 'bonehead' move in terms of flight sim zeal to get going taking precedence over common sense: For some time I was using the CH Virtual Pilot Pro yoke with excellent results. Then comes the advent of the newer motherboards offering support for 800MHz FSB and related updated goodies but what's this after I put the thing together [with a now greatly reduced in price P4 Intel 3.02 gig [w/800 FSB] CPU with hyperthreading ], where's the 15 pin gameport 'socket' in which to connect the yoke? Yeah...various of the updated mb's don't have them in favor the latest thing, USB slots! So, ahhhhhh, why not go for the equally updated CH USB yoke with the 3 levers for throttle, prop and mixture! So I did and caught a great sale to boot and XP recognized the yoke instantly. Box comes with a driver disk for those 'not' using Windows XP [I use XP-Pro] and that's it....no other instructions no doubt on the theory that one savvies the controls. Cutting to the chase...6 take-offs, ALL aborted because of engine failure! Hours of checking and re-checking as to what possibly could be wrong! Are you ready? And THIS from someone who can trace his sim roots back to FS5 for crying out loud...take a wild guess who stupidly...yes, STUPIDLY, forgot to ADVANCE both the prop and mixture levers on the yoke! Even in the real McCoy, it should have dawned on me immediately that the throttle is a 'push' and the prop/mixtures are a 'pull' ! Hence, and with the prop and mixture levers 'not' being placed 'to the wall' as they say or pushed FORWARD before flight, the plane simply died from sim pilot error! In effect, when I advanced the throttle to take off, the plane labored because the prop pitch was 'reversed' and the mixture was 'lean' and so it sputtered out shortly after take-off! Dumb, yes? Yes. :-( So, newbies, throttle lever back and the other two [prop and mixture] fully forward! Talk about haste and zeal taking over! Whew! And this! Periodic system shutdowns no matter where from program to Internet to whatever! Baffling! Things checked out OK including any heat issues with the CPU, coolers, etc. Sometimes a plane simply sitting on the runway for perhaps 5 minutes or so [hey, when nature calls!], come back, system restart! So I finally decided to READ all that fancy system program data that breaks down with facts and data on literally everything from CPU to CD to DVD to machine memory to you-name-it and while reviewing my memory [two PC3200 3.0 CAS DDR 184 pin modules] I read in the data area, "...does NOT support Bank 4 Interleave...] although I had it set for 'Bank 4' in BIOS because most places you go suggest to use that [versus Bank 2 or disabled] for 'faster response' but the memory was 'not' [per the data] Bank 4 Interleave [whatever that does!?] compliant and when I disabled the interleave, I've had no problems since 'nor' any disernible loss of overall machine speed whatsoever. As a check, I fired up FS04 and left the plane just sitting there running for 20 minutes or so...fine...where before the machine would have re-started within 10 minutes. Cure? I simply remained within the specs of my memory...while awaiting, BTW, for April 14 for the release of Kingston's 'PC3200' DDR HyperX memory which they ran a 'promo' and $50 off because 'PC3200' HyperX DDR memory , specifically, at 'that' speed, will not be available from Kingston until April 14th while other memory speeds have already been on the market. And finally this...do NOT trust those clamps [metal or plastic] on the CPU/Heat Sink thing. BE ABSOLUTELY SURE the heat sink FULLY makes contact with the CPU and 'then' apply the normal requisite pressure to seat the fan/heat sink and metal/plastic clamp assembly! If the heat-sink does not sit perfectly square on the CPU, you're just begging for heat issue troubles...and a high reading for CPU temps! If you're in the 50's [degrees] CELSIUS range or over 115+ degrees FAHRENHEIT, check your heat-sink seating [might be worth another dose of Arctic Silver or whatever you use between the CPU and heat-sink] and the CPU fan RPM! And careful with the Intel supplied plastic clamp to hold everything in place ..they snap 'VERY' easily or usually one of the L/R retaining levers pops out and then you get uneven pressure on the CPU [if you're tempted to let it go figuring one lever 'looks' secure enough] and heat-sink! Careful! There you have it! Doc Tony |
![]() John Ward wrote: Hi Doc, Hehe, always an adventure redaing your posts, and, BTW, great to see you posting again! :-) Are you sure you weren't tempted to have a crack at o/clocking your new system just a "tad', just to see how far she'd go, and you're just not admitting it to us all here? :-)) Regards, John Hello John! You know, the thing 'was' dumb because like yourself and a few others here in RAS, we've flown the real thing and here I was soooooo anxious to get going, I simply didn't stop for the millisecond it would take to apply the real McCoy itself to the 3 lever yoke! Dumb and so admitted! Then I figured, like ALL of us once were, hey, newbies to the hobby ad perhaps they'll be going nuts trying to figure out what's the 'problem' with the new USB yoke when often it's just a matter of zeal versus prudence. Hey, WHO among us hasn't been 'under the hood', machine or sims, and when the machine didn't work, we stare at it, claim that that there is no earthly reason why I shouldn't be humming along ...only to find out we forgot a simple power connection in a maze of drives ...or whatever setting in the sim. Hey, even ol' Dean B. admitted to forgetting the AP was still engaged...as MOST of us have on occasion! I won't even mention wheels-up landings! It happens! Ditto with the Intel clamp...2 of which cracked in my hand until I moved to the metal CPU/heat-sink hinges. And so it goes. Hey, has Al B. been around? The helo instructions still beckon! You know my luck with those egg beaters...to wit...whoop,whoop,whoop...CRASH...[RESET] Whoop,whoop,whoop....CRASH! Doc Tony ;-) "Dr. Anthony J. Lomenzo" wrote in message ... Well, it's not an 'award' that I particularly relish, to be sure, but when one does dumb things, hey, you pass on the experiences when the zeal to get going totally overrides both common sense and the HITK [read: Head In The Keester!] syndrome. Recognizing that the RAS newsgroup has both experienced old-hands --and-- most likely new folks to the hobby, well, if I save the newbies some grief I'll do a form of active penance so to speak...which is of interest in itself since I'm a agnostic! Anyway, to business: I already mentioned the Nvidia driver thing and I'll repeat that this was 'not' a matter of making any technical declaration! I don't know why it worked [tinkering with the drivers as explained in the post] and thus I could only speak positively about the 'results' and not the 'why' of it! So here goes... First 'bonehead' move in terms of flight sim zeal to get going taking precedence over common sense: For some time I was using the CH Virtual Pilot Pro yoke with excellent results. Then comes the advent of the newer motherboards offering support for 800MHz FSB and related updated goodies but what's this after I put the thing together [with a now greatly reduced in price P4 Intel 3.02 gig [w/800 FSB] CPU with hyperthreading ], where's the 15 pin gameport 'socket' in which to connect the yoke? Yeah...various of the updated mb's don't have them in favor the latest thing, USB slots! So, ahhhhhh, why not go for the equally updated CH USB yoke with the 3 levers for throttle, prop and mixture! So I did and caught a great sale to boot and XP recognized the yoke instantly. Box comes with a driver disk for those 'not' using Windows XP [I use XP-Pro] and that's it....no other instructions no doubt on the theory that one savvies the controls. Cutting to the chase...6 take-offs, ALL aborted because of engine failure! Hours of checking and re-checking as to what possibly could be wrong! Are you ready? And THIS from someone who can trace his sim roots back to FS5 for crying out loud...take a wild guess who stupidly...yes, STUPIDLY, forgot to ADVANCE both the prop and mixture levers on the yoke! Even in the real McCoy, it should have dawned on me immediately that the throttle is a 'push' and the prop/mixtures are a 'pull' ! Hence, and with the prop and mixture levers 'not' being placed 'to the wall' as they say or pushed FORWARD before flight, the plane simply died from sim pilot error! In effect, when I advanced the throttle to take off, the plane labored because the prop pitch was 'reversed' and the mixture was 'lean' and so it sputtered out shortly after take-off! Dumb, yes? Yes. :-( So, newbies, throttle lever back and the other two [prop and mixture] fully forward! Talk about haste and zeal taking over! Whew! And this! Periodic system shutdowns no matter where from program to Internet to whatever! Baffling! Things checked out OK including any heat issues with the CPU, coolers, etc. Sometimes a plane simply sitting on the runway for perhaps 5 minutes or so [hey, when nature calls!], come back, system restart! So I finally decided to READ all that fancy system program data that breaks down with facts and data on literally everything from CPU to CD to DVD to machine memory to you-name-it and while reviewing my memory [two PC3200 3.0 CAS DDR 184 pin modules] I read in the data area, "...does NOT support Bank 4 Interleave...] although I had it set for 'Bank 4' in BIOS because most places you go suggest to use that [versus Bank 2 or disabled] for 'faster response' but the memory was 'not' [per the data] Bank 4 Interleave [whatever that does!?] compliant and when I disabled the interleave, I've had no problems since 'nor' any disernible loss of overall machine speed whatsoever. As a check, I fired up FS04 and left the plane just sitting there running for 20 minutes or so...fine...where before the machine would have re-started within 10 minutes. Cure? I simply remained within the specs of my memory...while awaiting, BTW, for April 14 for the release of Kingston's 'PC3200' DDR HyperX memory which they ran a 'promo' and $50 off because 'PC3200' HyperX DDR memory , specifically, at 'that' speed, will not be available from Kingston until April 14th while other memory speeds have already been on the market. And finally this...do NOT trust those clamps [metal or plastic] on the CPU/Heat Sink thing. BE ABSOLUTELY SURE the heat sink FULLY makes contact with the CPU and 'then' apply the normal requisite pressure to seat the fan/heat sink and metal/plastic clamp assembly! If the heat-sink does not sit perfectly square on the CPU, you're just begging for heat issue troubles...and a high reading for CPU temps! If you're in the 50's [degrees] CELSIUS range or over 115+ degrees FAHRENHEIT, check your heat-sink seating [might be worth another dose of Arctic Silver or whatever you use between the CPU and heat-sink] and the CPU fan RPM! And careful with the Intel supplied plastic clamp to hold everything in place ..they snap 'VERY' easily or usually one of the L/R retaining levers pops out and then you get uneven pressure on the CPU [if you're tempted to let it go figuring one lever 'looks' secure enough] and heat-sink! Careful! There you have it! Doc Tony |
Hi Doc,
Good points, and well made. No he hasn't, for a while now. Regards, John "Dr. Anthony J. Lomenzo" wrote in message ... John Ward wrote: Hi Doc, Hehe, always an adventure redaing your posts, and, BTW, great to see you posting again! :-) Are you sure you weren't tempted to have a crack at o/clocking your new system just a "tad', just to see how far she'd go, and you're just not admitting it to us all here? :-)) Regards, John Hello John! You know, the thing 'was' dumb because like yourself and a few others here in RAS, we've flown the real thing and here I was soooooo anxious to get going, I simply didn't stop for the millisecond it would take to apply the real McCoy itself to the 3 lever yoke! Dumb and so admitted! Then I figured, like ALL of us once were, hey, newbies to the hobby ad perhaps they'll be going nuts trying to figure out what's the 'problem' with the new USB yoke when often it's just a matter of zeal versus prudence. Hey, WHO among us hasn't been 'under the hood', machine or sims, and when the machine didn't work, we stare at it, claim that that there is no earthly reason why I shouldn't be humming along ...only to find out we forgot a simple power connection in a maze of drives ...or whatever setting in the sim. Hey, even ol' Dean B. admitted to forgetting the AP was still engaged...as MOST of us have on occasion! I won't even mention wheels-up landings! It happens! Ditto with the Intel clamp...2 of which cracked in my hand until I moved to the metal CPU/heat-sink hinges. And so it goes. Hey, has Al B. been around? The helo instructions still beckon! You know my luck with those egg beaters...to wit...whoop,whoop,whoop...CRASH...[RESET] Whoop,whoop,whoop....CRASH! Doc Tony ;-) "Dr. Anthony J. Lomenzo" wrote in message ... Well, it's not an 'award' that I particularly relish, to be sure, but when one does dumb things, hey, you pass on the experiences when the zeal to get going totally overrides both common sense and the HITK [read: Head In The Keester!] syndrome. Recognizing that the RAS newsgroup has both experienced old-hands --and-- most likely new folks to the hobby, well, if I save the newbies some grief I'll do a form of active penance so to speak...which is of interest in itself since I'm a agnostic! Anyway, to business: I already mentioned the Nvidia driver thing and I'll repeat that this was 'not' a matter of making any technical declaration! I don't know why it worked [tinkering with the drivers as explained in the post] and thus I could only speak positively about the 'results' and not the 'why' of it! So here goes... First 'bonehead' move in terms of flight sim zeal to get going taking precedence over common sense: For some time I was using the CH Virtual Pilot Pro yoke with excellent results. Then comes the advent of the newer motherboards offering support for 800MHz FSB and related updated goodies but what's this after I put the thing together [with a now greatly reduced in price P4 Intel 3.02 gig [w/800 FSB] CPU with hyperthreading ], where's the 15 pin gameport 'socket' in which to connect the yoke? Yeah...various of the updated mb's don't have them in favor the latest thing, USB slots! So, ahhhhhh, why not go for the equally updated CH USB yoke with the 3 levers for throttle, prop and mixture! So I did and caught a great sale to boot and XP recognized the yoke instantly. Box comes with a driver disk for those 'not' using Windows XP [I use XP-Pro] and that's it....no other instructions no doubt on the theory that one savvies the controls. Cutting to the chase...6 take-offs, ALL aborted because of engine failure! Hours of checking and re-checking as to what possibly could be wrong! Are you ready? And THIS from someone who can trace his sim roots back to FS5 for crying out loud...take a wild guess who stupidly...yes, STUPIDLY, forgot to ADVANCE both the prop and mixture levers on the yoke! Even in the real McCoy, it should have dawned on me immediately that the throttle is a 'push' and the prop/mixtures are a 'pull' ! Hence, and with the prop and mixture levers 'not' being placed 'to the wall' as they say or pushed FORWARD before flight, the plane simply died from sim pilot error! In effect, when I advanced the throttle to take off, the plane labored because the prop pitch was 'reversed' and the mixture was 'lean' and so it sputtered out shortly after take-off! Dumb, yes? Yes. :-( So, newbies, throttle lever back and the other two [prop and mixture] fully forward! Talk about haste and zeal taking over! Whew! And this! Periodic system shutdowns no matter where from program to Internet to whatever! Baffling! Things checked out OK including any heat issues with the CPU, coolers, etc. Sometimes a plane simply sitting on the runway for perhaps 5 minutes or so [hey, when nature calls!], come back, system restart! So I finally decided to READ all that fancy system program data that breaks down with facts and data on literally everything from CPU to CD to DVD to machine memory to you-name-it and while reviewing my memory [two PC3200 3.0 CAS DDR 184 pin modules] I read in the data area, "...does NOT support Bank 4 Interleave...] although I had it set for 'Bank 4' in BIOS because most places you go suggest to use that [versus Bank 2 or disabled] for 'faster response' but the memory was 'not' [per the data] Bank 4 Interleave [whatever that does!?] compliant and when I disabled the interleave, I've had no problems since 'nor' any disernible loss of overall machine speed whatsoever. As a check, I fired up FS04 and left the plane just sitting there running for 20 minutes or so...fine...where before the machine would have re-started within 10 minutes. Cure? I simply remained within the specs of my memory...while awaiting, BTW, for April 14 for the release of Kingston's 'PC3200' DDR HyperX memory which they ran a 'promo' and $50 off because 'PC3200' HyperX DDR memory , specifically, at 'that' speed, will not be available from Kingston until April 14th while other memory speeds have already been on the market. And finally this...do NOT trust those clamps [metal or plastic] on the CPU/Heat Sink thing. BE ABSOLUTELY SURE the heat sink FULLY makes contact with the CPU and 'then' apply the normal requisite pressure to seat the fan/heat sink and metal/plastic clamp assembly! If the heat-sink does not sit perfectly square on the CPU, you're just begging for heat issue troubles...and a high reading for CPU temps! If you're in the 50's [degrees] CELSIUS range or over 115+ degrees FAHRENHEIT, check your heat-sink seating [might be worth another dose of Arctic Silver or whatever you use between the CPU and heat-sink] and the CPU fan RPM! And careful with the Intel supplied plastic clamp to hold everything in place ..they snap 'VERY' easily or usually one of the L/R retaining levers pops out and then you get uneven pressure on the CPU [if you're tempted to let it go figuring one lever 'looks' secure enough] and heat-sink! Careful! There you have it! Doc Tony |
![]() John Ward wrote: Hi Doc, Good points, and well made. No he hasn't, for a while now. Ahhhh, he'll show up! John...the cat on the monitor, still doing 'co-pilot' service? ;-) As for machine ventures to strive for that great problem-free flight, I 'briefly' tried tinkering not with O/C stuff [the 3.2 w/800 MHz FSB is fast enough] but with SATA drives and a RAID array. John, trying my hand at Egyptian hieroglyphics would quite possibly be easier than trying to figuring out how to get SATA drives perking + a RAID array! I think they write those SATA drive and RAID tech pieces for folks with the proverbial MIT credential! I gave up [for now anyway...] and returned forthwith to my IDE UDMA 133 drives! Doc Tony ;-) Regards, John "Dr. Anthony J. Lomenzo" wrote in message ... John Ward wrote: Hi Doc, Hehe, always an adventure redaing your posts, and, BTW, great to see you posting again! :-) Are you sure you weren't tempted to have a crack at o/clocking your new system just a "tad', just to see how far she'd go, and you're just not admitting it to us all here? :-)) Regards, John Hello John! You know, the thing 'was' dumb because like yourself and a few others here in RAS, we've flown the real thing and here I was soooooo anxious to get going, I simply didn't stop for the millisecond it would take to apply the real McCoy itself to the 3 lever yoke! Dumb and so admitted! Then I figured, like ALL of us once were, hey, newbies to the hobby ad perhaps they'll be going nuts trying to figure out what's the 'problem' with the new USB yoke when often it's just a matter of zeal versus prudence. Hey, WHO among us hasn't been 'under the hood', machine or sims, and when the machine didn't work, we stare at it, claim that that there is no earthly reason why I shouldn't be humming along ...only to find out we forgot a simple power connection in a maze of drives ...or whatever setting in the sim. Hey, even ol' Dean B. admitted to forgetting the AP was still engaged...as MOST of us have on occasion! I won't even mention wheels-up landings! It happens! Ditto with the Intel clamp...2 of which cracked in my hand until I moved to the metal CPU/heat-sink hinges. And so it goes. Hey, has Al B. been around? The helo instructions still beckon! You know my luck with those egg beaters...to wit...whoop,whoop,whoop...CRASH...[RESET] Whoop,whoop,whoop....CRASH! Doc Tony ;-) "Dr. Anthony J. Lomenzo" wrote in message ... Well, it's not an 'award' that I particularly relish, to be sure, but when one does dumb things, hey, you pass on the experiences when the zeal to get going totally overrides both common sense and the HITK [read: Head In The Keester!] syndrome. Recognizing that the RAS newsgroup has both experienced old-hands --and-- most likely new folks to the hobby, well, if I save the newbies some grief I'll do a form of active penance so to speak...which is of interest in itself since I'm a agnostic! Anyway, to business: I already mentioned the Nvidia driver thing and I'll repeat that this was 'not' a matter of making any technical declaration! I don't know why it worked [tinkering with the drivers as explained in the post] and thus I could only speak positively about the 'results' and not the 'why' of it! So here goes... First 'bonehead' move in terms of flight sim zeal to get going taking precedence over common sense: For some time I was using the CH Virtual Pilot Pro yoke with excellent results. Then comes the advent of the newer motherboards offering support for 800MHz FSB and related updated goodies but what's this after I put the thing together [with a now greatly reduced in price P4 Intel 3.02 gig [w/800 FSB] CPU with hyperthreading ], where's the 15 pin gameport 'socket' in which to connect the yoke? Yeah...various of the updated mb's don't have them in favor the latest thing, USB slots! So, ahhhhhh, why not go for the equally updated CH USB yoke with the 3 levers for throttle, prop and mixture! So I did and caught a great sale to boot and XP recognized the yoke instantly. Box comes with a driver disk for those 'not' using Windows XP [I use XP-Pro] and that's it....no other instructions no doubt on the theory that one savvies the controls. Cutting to the chase...6 take-offs, ALL aborted because of engine failure! Hours of checking and re-checking as to what possibly could be wrong! Are you ready? And THIS from someone who can trace his sim roots back to FS5 for crying out loud...take a wild guess who stupidly...yes, STUPIDLY, forgot to ADVANCE both the prop and mixture levers on the yoke! Even in the real McCoy, it should have dawned on me immediately that the throttle is a 'push' and the prop/mixtures are a 'pull' ! Hence, and with the prop and mixture levers 'not' being placed 'to the wall' as they say or pushed FORWARD before flight, the plane simply died from sim pilot error! In effect, when I advanced the throttle to take off, the plane labored because the prop pitch was 'reversed' and the mixture was 'lean' and so it sputtered out shortly after take-off! Dumb, yes? Yes. :-( So, newbies, throttle lever back and the other two [prop and mixture] fully forward! Talk about haste and zeal taking over! Whew! And this! Periodic system shutdowns no matter where from program to Internet to whatever! Baffling! Things checked out OK including any heat issues with the CPU, coolers, etc. Sometimes a plane simply sitting on the runway for perhaps 5 minutes or so [hey, when nature calls!], come back, system restart! So I finally decided to READ all that fancy system program data that breaks down with facts and data on literally everything from CPU to CD to DVD to machine memory to you-name-it and while reviewing my memory [two PC3200 3.0 CAS DDR 184 pin modules] I read in the data area, "...does NOT support Bank 4 Interleave...] although I had it set for 'Bank 4' in BIOS because most places you go suggest to use that [versus Bank 2 or disabled] for 'faster response' but the memory was 'not' [per the data] Bank 4 Interleave [whatever that does!?] compliant and when I disabled the interleave, I've had no problems since 'nor' any disernible loss of overall machine speed whatsoever. As a check, I fired up FS04 and left the plane just sitting there running for 20 minutes or so...fine...where before the machine would have re-started within 10 minutes. Cure? I simply remained within the specs of my memory...while awaiting, BTW, for April 14 for the release of Kingston's 'PC3200' DDR HyperX memory which they ran a 'promo' and $50 off because 'PC3200' HyperX DDR memory , specifically, at 'that' speed, will not be available from Kingston until April 14th while other memory speeds have already been on the market. And finally this...do NOT trust those clamps [metal or plastic] on the CPU/Heat Sink thing. BE ABSOLUTELY SURE the heat sink FULLY makes contact with the CPU and 'then' apply the normal requisite pressure to seat the fan/heat sink and metal/plastic clamp assembly! If the heat-sink does not sit perfectly square on the CPU, you're just begging for heat issue troubles...and a high reading for CPU temps! If you're in the 50's [degrees] CELSIUS range or over 115+ degrees FAHRENHEIT, check your heat-sink seating [might be worth another dose of Arctic Silver or whatever you use between the CPU and heat-sink] and the CPU fan RPM! And careful with the Intel supplied plastic clamp to hold everything in place ..they snap 'VERY' easily or usually one of the L/R retaining levers pops out and then you get uneven pressure on the CPU [if you're tempted to let it go figuring one lever 'looks' secure enough] and heat-sink! Careful! There you have it! Doc Tony |
John Ward wrote: Hi Doc, Good points, and well made. No he hasn't, for a while now. Ahhhh, he'll show up! John...the cat on the monitor, still doing 'co-pilot' service? ;-) Oh gawd - there's more than one?? (:-)) I think they write those SATA drive and RAID tech pieces for folks with the proverbial MIT credential! I gave up [for now anyway...] and returned forthwith to my IDE UDMA 133 drives! Rumor has it the spec's or expect's for the SATA's are as trustworthy as if uttered by Geo. W. himself! In other words, if it sounds good, say it, you lie, I'll swear to it................... Cheers'n Beers Doc.. [_]) Don |
