Branko,
Do you know if it will run correctly under the "DOS Window" of various flavours of Windows, or does it need a pure DOS environment ? John G. "Branko Stojkovic" wrote in message . .. | Hello, | | Sme 10 years ago I wrote a program for DOS named "Polar Explorer" - designed | for analyzing both theoretical and practical aspects of glider performance | in any conditions. The program was advertised in the Soaring magazine for a | couple of years by CuSoft Research Inc., and some 30 odd copies sold for USD | 99 each. | | If anyone is interested in this program (see the short description below), I | will consider posting it on my current company's website: www.trimill.com | | Sincerely, | | Branko Stojkovic | | ----------------------------- | | SHORT DESCRIPTION | =================== | Polar Explorer is designed to answer many `specific` questions about glider | performance. As a result, you can use it for many different purposes. The | following are a few examples of what you can do: | | Complement the books and articles on glider performance and soaring tactics | by working out practical examples. | | Find out the `optimum circling technique` for any glider at any altitude and | wing loading. | | Plan and analyze cross-country flights and final glides. | | Optimize configuration and wing loading in any weather conditions. | | Apply `generalized speed-to-fly theory` to maximize cross-country | performance when using ridge lift or waves. | | Compare circling and cross-country performances in addition to comparing | polars. | | Design and test speed rings and final glide computers, for any altitude and | wing loading. | | Enter and analyze any glider polar that you come across. The glider polar | library that comes with the program already contains 150 polars (see below). | | If you are contemplating any modifications to your sailplane (e.g. adding | winglets), you can use Polar Explorer's advanced features to estimate the | performance gains. | | Polar Explorer 2.1 ? Polar Library | ========================= | | Sources of Polars: | | (J) Flight Test Evaluations of... by Richard H. Johnson published in the | Soaring magazine. | | (D1) Flugmessungen mit 25 Segelflugzeugen by H. Laurson and H. Zacker, DFVLR | Institute, Germany, (1972) | | (D2) Flugmessungen an 35 Segelflugzeugen und Motorseglern by H. Laurson and | H. Zacker, DFVLR Institute, Germany, (1976) | | (D3) Flugmessungen mit Segelflugzeugen von 12 bis 13 M Spannweite by Hans | Zacher, DVL, München-Riem, Germany, (1965) | | (D*) German Test Data | | (M) Flight performance measurements on twelve sailplanes by H. J. Merklein | and H. Zacher, Scientific Flight Research Establishment Munich , (1964). | | (C) Calculated polar published by the manufacturer | | 1. Ahrens Delphin V2 (D3) | 2. AK 1 /D KEUL (D2) | 3. ASH 25 /N80WK/#4 (J) | 4. ASH 26E (C) | 5. ASK 13 /D 2018 (D1) | 6. ASK 16 /D KEIK (D2) | 7. ASK 21 /N362KS/#225 (J) | 8. Astir CS /D 7290 (D2) | 9. ASW 15 /D 0510 (D1) | 10. ASW 15 /D 0791 (D1) | 11. ASW 17 /N45JD (J) | 12. ASW 17/20m /D 1110 (D2) | 13. ASW 17S/21m /D 2119 (D2) | 14. ASW 19 /D 4525 (D2) | 15. ASW 19 /N19KL (J) | 16. ASW 20 /N104WR/#17 (J) | 17. ASW 20 [ 9] /N104WR/#17 (J) | 18. ASW 20 [8,0] /N104WR/#17 (J) [Flaps +8 & 0 deg] | 19. ASW 22/22m /N2702J/#15 (J) | 20. ASW 22/24m /N2702J/#15 (J) | 21. ASW 24 (D*) | 22. ASW 27 (C) | 23. Bergfalke II /D 1217 (M) | 24. Bergfalke III /D 1737 (D1) | 25. Bergfalke IV /D 1005 (D2) | 26. Blanik L 13 (C) | 27. Bocian /D 1578 (M) | 28. Calif A 21 S /D 2176 (D2) | 29. Cirrus /D 0471 (D1) | 30. Cirrus /D 0471 (D2) | 31. Club Libelle /D 3695 (D2) | 32. D 34 b Aphrodite/D 4607 (M) | 33. D 34 d (D3) | 34. D 34 d /D 4607 (M) | 35. D 36 V1 /D 4685 (D1) | 36. D 37 Artemis /D 2278 (D2) | 37. D 37 Artemis /D KEDD (D2) | 38. D 38 /D 0938 (D2) | 39. DG 300 /N33HB/#E47 (J) [Sealed, clean holes] | 40. DG 100 /D 1076 (D2) | 41. DG 100 /D 7099 (D2) | 42. DG 101 G /N101TX/#E168 (J) | 43. DG 200 /N200GA/#2 101 (J) | 44. DG 600/15 /N70205 (J) [15m; No winglets] | 45. DG 600/15W /N70205 (J) [15m; With winglets] | 46. DG 600/17 /N70205 (J) [17m] | 47. Discus A /N52XX/#33 (J) [sealed) | 48. Discus A [W] /N52XX/#33 (J) [Ballasted] | 49. Elfe S3 /HB 902 (D1) | 50. Elfe S4 /D 6301 (D2) | 51. Elfe S4 /D 6668 (D2) | 52. FK 3 /D 0292 (D1) | 53. FS 24 Phonix T /D 8385 (M) | 54. FS 25 Curevo /D 8141 (D1) | 55. FS 29 13.8m /D 2929 (D2) | 56. FS 29 16m /D 2929 (D2) | 57. FS 29 19m /D 2929 (D2) | 58. FS 29 all /D 2929 (D2) | 59. Glasflugel 604 /D 8085 (D2) | 60. Glasflugel 604 /N57L (J) | 61. Glasflugel 604 mod./N57L (J) [Corrected profile] | 62. Grob 102 Club IIIb/N3981A (J ) [/#5610 Sealed] | 63. Grob 103 Twin II /N427BG (J | 64. Grob 103 Twin II mod. (J) [Mod. wheel fairings] | 65. Grob 103C Twin III (J) [#34107] | 66. Grob 109B /N300BG/#6390 (J) | 67. H 101 Salto /D 2040 (D1) | 68. H 201 St.Libelle/D 0082 (D1 | 69. H 301 Libelle /D 9412 (D1) | 70. H 401 Kestrel /D 0245 (D1) | 71. Hi 25 Kria (D3) | 72. Hornet /D 7816 (D2) | 73. J 4 Javelin /N5TF (J) | 74. Jantar 1 /N46DB (J) | 75. Jantar 2A /N980 (J) | 76. Jantar Std. /N51AS/#880 (J) | 77. Jantar Std. /SE TOI (D2) | 78. Jantar Std.2 /N45AS/#863 (J) | 79. Janus /D 3111 (D2) | 80. Janus /N468F (J) | 81. Jaskolka Z O SZD 8ter (M) [FFM /HB 604] | 82. K 7 /D 1800 (M) | 83. K 8 /D 1590 (M) | 84. K 8 KM 48 /D KIBO (D1) | 85. Ka 6 BR/S /D 8390 (M) | 86. Ka 6 CR (D3) | 87. Ka 6 CR /D 1810 (D1) | 88. Ka 6 CR /D 1810 (D2) | 89. Ka 6 CR /D 4390 (M) | 90. Ka 6 E /D 3657 (D) | 91. Kestrel /D 0475 (D2) | 92. Kestrel 19(T59D)/D 5999 (D2 | 93. KORA 1 /D KORT (D2) | 94. Kranich III /D 1398 (M) | 95. LCF 2 /D 6446 (D2) | 96. LS 1 C /D 0558 (D1) | 97. LS 1 F /D 3252 (D*) | 98. LS 1 F /D 3252 (D2) | 99. LS 3 /N45EW (J) | 100. LS 4 /D 2628 (D*) | 101. LS 4 /D 2628; W/S=34.4 (D | 102. LS 4 /D 6680 (D*) | 103. LS 4A /N274W/#321 (J) | 104. LS 4A /N430RH/#384 (J) | 105. Mini Nimbus /N871T/#16 (J) [Seals installed] | 106. Mistral /D 4998 (D2) | 107. Mosquito /N46898 (J) | 108. Mu 22 b /D 1848 (D1) | 109. Mu 26 /D 0726 {1971} (D1) | 110. Mu 26 /D 0726 {1972} (D1) | 111. Nimbus 3/22.9 /N49JD/#19 (J) | 112. Nimbus 3/24.5 /N49JD/#19 (J) | 113. Nimbus 3/24.5 Mod. (J) [Profiled wing] | 114. Nimbus II /D 0107 (D1) | 115. Nimbus II /D 0699 (D1) | 116. Nimbus II /D 2111 (D2) | 117. Nimbus II Smooth /N45DJ (J) [Smoothed wings] | 118. Phoebus C /D 0559 (D1) | 119. Pik 20 A /OY XCR (D2) | 120. Pik 20 A.I. /N100DC/#8 (J) [With ail. interconn] | 121. Pik 20 B Mod. /N46JD (J) [Mod. wing leading edge] | 122. Pik 20 D 78 /N19YZ (J) | 123. Pik 20 No AI /N100DC/#8 (J) [No ail. interconn.] | 124. Pilatus B4 PC11 /HB 1127(D2 | 125. RF 5 B Sperber /D KOKS (D2) | 126. Sagitta /PH 319 (D1) | 127. Salto 15 mod. /D 2220 (D2) | 128. SB 10 /D 6085 (D2) | 129. SB 8 V2 /D 6085 (D1) | 130. SB 9 /D 6085 (D1) | 131. Schweizer 1 26E /N33904 (J) [#634] | 132. Schweizer 1 35 /N17976 (J) | 133. Schweizer 1 36 /N362IT (J) | 134. SF 27 A /D 6068 (D1) | 135. SF 28 Tandem /D KFAJ (D2) | 136. SF 30 Club Spatz /D 3697(D2 | 137. Skylark 3 F /RAF 146 (M) | 138. Std. Cirrus /D 0483 (D1) | 139. Std. Cirrus /D 3261 (D2) | 140. Std. Cirrus B /N5CC (J) | 141. Std. Cirrus/16m /D 3261 (D2 | 142. SZD 30 Pirat /D 3660 (D1) | 143. SZD 55 1 /N3176T (J) | 144. Vega /N3751Q/#1927 (J) | 145. Ventus A /N47JD/#29 (J) | 146. Ventus A/16.6 (J) [Original wing] | 147. Ventus A/16.6 Mod. (J) [Profiled wing] | 148. Ventus B /N139P (J) | 149. Zuni /N14XZ/#14 (J) | 150. Zuni [ 8.8] /N14XZ/#14 (J) [Flaps 8.8 deg]) | 151. Zuni [0] /N14XZ/#14 (J) [Flaps 0 deg]) | | |
Commercial polar routes? | General Aviation | 6 | January 28th 05 08:03 PM | |
Jon Johanson..Long delete if not interested | Jerry Springer | Home Built | 0 | December 21st 03 05:55 PM |
LX 1000 polar calibration | Vignaud Frédéric | Soaring | 0 | July 14th 03 05:14 PM |
