Have you tried a Google search? It turns up quite a bit of info.
In case it helps: The dry adiabat is the rate at which unsaturated air cools when lifted. (Ballpark 3 deg C / 1000'). The moist or saturated adiabat is the rate at which air cools when lifted, once saturated. (Ballpark 1/2 of the dry adiabat in the lower atmosphere). If you lift a parcel of air from the ground, the level at which it would saturate is the Lifting Condensation Level (LCL). (Ballpark, take the temperature-dewpoint spread and divide by 3, to get the height in thousands of feet of cumuliform cloud bases from daytime heating) If you were to continue lifting the parcel of air beyond the LCL, the point at which the parcel becomes warmer than the environment and rises on its own is called the LFC or Level of Free Convection. It shows altitudes at which you should expect convection and turbulence if enough lift is provided to saturate the air at those levels. Cheers! "Jim Tagliani" wrote in message ... Can someone describe the Level of Free-air Convection (LFC) and how it relates to the different lapse rates (Dry Adiabatic, Wet Adiabatic and especially the Observed Lapse Rate?) Thanks in advance, Jim |
How saturated adiabatic lapse rate varies with temperature | Andrew Sarangan | Piloting | 5 | February 15th 05 02:38 PM |
Atmospheric stability and lapse rate | Andrew Sarangan | Piloting | 39 | February 11th 05 05:34 AM |
Revisiting lapse rates (From: How high is that cloud?) | Icebound | Instrument Flight Rules | 5 | November 26th 04 09:41 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
