"Scott" wrote in message ... I know someone has an answer. I need to find out if I'm drawing power when my master switch is off. Something is quirky and I want to be able to hook something up in the batteries position to find out if anything is drawing little bits of power. Any one know of a simple instrument? __________________________________________________ ________________ scott Yes. An ampmeter in series with the battery with the master switch off should show zero current. Try the larger ranges (10 Amps, for example) first, so you don't pop the fuses in your meter. Tim Ward |
my master switch is off. Something is quirky and I want to be able to hook something up in the batteries position to find out if anything is drawing little bits of power. Any one know of a simple instrument? __________________________________________________ ________________ scott ICQ#: 34312461 Current ICQ status: + More ways to contact me __________________________________________________ ________________ --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.524 / Virus Database: 321 - Release Date: 10/6/2003 -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
"Scott" wrote in message ... thank you Just to be sure there's no confusion, you will need to remove one lead from the battery, doesn't matter which one. Then set the multimeter on its highest amp range and hook one meter lead to the battery terminal and the other to the wire you removed. With master off the meter should read zero. Switch to the lower current ranges and the reading should still be zero. Don't have an ammeter (some cheaper multimeters don't), no problem. Just hook a resistor (a car tail lamp bulb will do) between the battery terminal and the wire you removed from that terminal. Set the meter to read DC voltage and hook one lead to the battery terminal and the other to the wire (this would be in parallel with the resister or bulb). There should be no voltage drop across the resister and thus the meter should read zero volts. If you get the desired zero reading, then the battery voltage is dropping for another, perhaps more likely, reason. Sealed lead acid batteries of the type normally used in gliders, have a life expectancy of no more than 5 years. They lose capacity as they age. If your battery isn't holding a charge, then perhaps it's time to replace the battery? -- bumper - ZZ "Dare to be different . . . circle in sink." to reply, the last half is right to left --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.521 / Virus Database: 319 - Release Date: 9/25/2003 |
thank you
"Tim Ward" wrote in message ... "Scott" wrote in message ... I know someone has an answer. I need to find out if I'm drawing power when my master switch is off. Something is quirky and I want to be able to hook something up in the batteries position to find out if anything is drawing little bits of power. Any one know of a simple instrument? __________________________________________________ ________________ scott Yes. An ampmeter in series with the battery with the master switch off should show zero current. Try the larger ranges (10 Amps, for example) first, so you don't pop the fuses in your meter. Tim Ward --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.524 / Virus Database: 321 - Release Date: 10/6/2003 -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
Absolutely correct...
A simple test also is to as John mentioned remove one battery cable terminal from the battery... take a voltmeter set to 12 v and attach one lead to the battery terminal and one lead to the cable. If it reads 12v then you have a current draw... start removing fuses or breakers until the meter no longer reads 12 v and you will have the source of the draw. By the way... I am sure that you know how electrons work. I have discovered that they run on smoke... when you break them all the smoke comes out. They don't call me Stevie Zappo for nothing. "John Morgan" wrote in message ... "Scott" wrote in message ... thank you Just to be sure there's no confusion, you will need to remove one lead from the battery, doesn't matter which one. Then set the multimeter on its highest amp range and hook one meter lead to the battery terminal and the other to the wire you removed. With master off the meter should read zero. Switch to the lower current ranges and the reading should still be zero. Don't have an ammeter (some cheaper multimeters don't), no problem. Just hook a resistor (a car tail lamp bulb will do) between the battery terminal and the wire you removed from that terminal. Set the meter to read DC voltage and hook one lead to the battery terminal and the other to the wire (this would be in parallel with the resister or bulb). There should be no voltage drop across the resister and thus the meter should read zero volts. If you get the desired zero reading, then the battery voltage is dropping for another, perhaps more likely, reason. Sealed lead acid batteries of the type normally used in gliders, have a life expectancy of no more than 5 years. They lose capacity as they age. If your battery isn't holding a charge, then perhaps it's time to replace the battery? -- bumper - ZZ "Dare to be different . . . circle in sink." to reply, the last half is right to left --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.521 / Virus Database: 319 - Release Date: 9/25/2003 |
A simple test to determine if it is a faulty battery, is simply to
disconnect one lead from the battery for a period of time, say a week, and see if the charge leaks off. If so, they the battery has developed a reduced internal resistance and needs to be replaced. -- John Scott |
"John Morgan" wrote
Don't have an ammeter (some cheaper multimeters don't), no problem. Just hook a resistor (a car tail lamp bulb will do) between the battery terminal and the wire you removed from that terminal. Set the meter to read DC voltage and hook one lead to the battery terminal and the other to the wire (this would be in parallel with the resister or bulb). There should be no voltage drop across the resister and thus the meter should read zero volts. This isn't going to work for a slow leak (anything less than about 50 ma) because at low current, the resistance of a tail light is nearly zero. The typical glider battery is about 6 Ah, which means a 50 ma leak will drain the battery flat in about a week. There are all kinds of problems that cause slow leaks. A friend of mine once discovered about a 20 ma leak in his installation where the leakage was through the battery box grommet. Michael Please do not send email replies to this posting. They are checked only sporadically, and are filtered heavily by Hotmail. If you need to email me, the correct address is crw69dog and the domain name is this old airplane dot com, but remove the numbers and format the address in the usual way. |
| Thread Tools | |
| Display Modes | |
| Fine example of Tarver Engineering release for service | running with scissors | Military Aviation | 79 | March 3rd 04 02:48 PM |
| Fine example of Tarver Engineering release for service | B2431 | Military Aviation | 1 | February 29th 04 08:38 AM |
| PS Engineering Report | Jeff | Owning | 44 | December 8th 03 12:24 AM |
| PS Engineering | Hankal | Owning | 0 | December 5th 03 01:25 AM |
